I just bought a bunch of ls parts and included is a 6.0 with 317 heads a carb intake msd controller moroso pan new melling oil pump and new yellow z06 springs and im wondering what is the best cam to work with these springs and motor im kind of on a budget after buying a bunch of parts i didnt need but you cant have too many parts so im looking for a cam to install in this motor. im running a carb for now untill i get the rest of the stuff gathered for fuel injection. I am gonna be running a 150 shot also any help is appretiated.
The only cam that I know off the top of my head to work with LS6 Springs is the GM Hot Cam, but it may be too small for your 6.0 I'd suggest selling off the parts that you don't need and using it to buy a better cam, springs and pushrods.
Matt
Matt
STREETDEMON
close
- Join DateJun 2001
- LocationKansas
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car91 Z28
- Engine6.0L LQ9
- TransmissionT56
- Axle/GearsDana 44 3.92
- Liked:33 Times in 18 Posts
i think the ls6 springs are only good for .570" lift....so keep the cam mild.
On Probation
I think the GM HOT cam is good for this. As for power, Car Craft got 480 HP from a build like this.
I found a comp cam thats 222-224 .566int .568exh on a 112 lobe seperation it seems like this is as big as i should go with the springs i have what do you guys think is it worth 400 bucks it seems just a little bigger than a z06 cam
STREETDEMON
close
- Join DateJun 2001
- LocationKansas
- Car91 Z28
- Engine6.0L LQ9
- TransmissionT56
that might be pushing the limits of the springs....stay away from the hot cam, there are much better choices out there, in my opinion.
get on ls1tech and see if you can find a good 220-224ish cam used....most of the time you can buy them around $250 or less.
You going to be running this car at cordova when its completed? Maybe ill see you at midnight mayhem
btw I think the zo6 cam seems alittle small for the power your demanding, especially on a 150 shot
Quote:
I have a Lunati 218/222 526/.534 lift on a 114. Will work great with stock springs. Make me an offer on it.Originally Posted by ransam
I just bought a bunch of ls parts and included is a 6.0 with 317 heads a carb intake msd controller moroso pan new melling oil pump and new yellow z06 springs and im wondering what is the best cam to work with these springs and motor im kind of on a budget after buying a bunch of parts i didnt need but you cant have too many parts so im looking for a cam to install in this motor. im running a carb for now untill i get the rest of the stuff gathered for fuel injection. I am gonna be running a 150 shot also any help is appretiated. Senior Member
for the peace of mind i would just throw a stock 02-04 ls6 cam in there with those springs and ride that for a while and until you can afford to do it the correct way and buy springs that work with the camshaft
Yes i will be taking my ta to cordova when its finished i just have a couple more small parts to buy to complete my swap and now i am gonna be selling my 5.3 and still trying to decide to go carb or injected as now i have all the parts to do both then i will see how much cash i have for cam and spring kit. Are custom grinds the same cost as off the shelf cams?
