1982 V6 2.8L Carb to LS1 Swap
Old Jan 23, 2022 | 09:03 PM
superg's Avatar
Hi all, from Australia here and finally making the V6 2.8L to LS1 swap happen
I have ordered the hooker engine mounts / trans crossmember as a start and due to parts being out of stock arent due until March, this will solve the engine and trans mounting.
Looking at running a holley terminator x and wiring for electrical.
My next step is fuel i havent had a chance to look at the car in a while but im guessing being V6 Carb i wouldnt have a return line back to the tank?
Anyone used one of these pumps? https://www.holley.com/products/ls_p...m/parts/12-328
Old Jan 24, 2022 | 08:21 AM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Re: 1982 V6 2.8L Carb to LS1 Swap
Search, search, search function! But while I'm here, I might as well help.
The Holley fuel pump/sender you linked has a return line, so if you go that route you will want to find return style "LS" fuel rails.
The Holley terminator x is not quite a complete kit, you need an alternator signal wire with a resistor they sell separately, and also an air intake temp sensor. I used one from a 1994 v6 camaro.
If you have any more questions, pm me
Old Jan 24, 2022 | 04:48 PM
Sculptural's Avatar
Car: 84 Camaro
Engine: 350 Carb
Be advised that the Hooker crossmember is not listed to fit any 82-83 model f-bodies. I believe that the spacing between the rails are different from other year models.
Old Jan 24, 2022 | 08:01 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
From the Hooker Blackheart LS Swap Tech Data sheet:
This crossmember can also be installed in a 1982 or 1983 model year F-body by modifying the location of the stock crossmember attachment holes in the subframe.
So I'd say it will fit between the rails fine. You'll just have to do more work to ensure you have threaded holes for the bolts to work with. It would be worth reading through the original LS1tech thread on when these were announced to see if there was any other details that could help.
rossboss99
Jun 10, 2010 03:10 AM
needls1bad
Feb 9, 2010 02:37 AM
92Birdofprey
Apr 19, 2008 11:50 PM
thewongster
Nov 27, 2006 12:24 AM
Yellow87Cam
Oct 16, 2005 11:59 AM
