LSx Swap Wiring
Old Jan 3, 2023 | 10:35 PM
vorteciroc's Avatar
Top Answer: 1
LSx Swap Wiring
LSx Swap Wiring
New Wiring Jumper Harnesses and Wiring Adapter Harnesses for LSx Swap Alternators and LSx Swap Air-Conditioning Compressors are now available.
Most LSx Swap Wiring Harnesses do NOT include the required Resistor for the Alternator Exciter Circuit.
A simple solution is to use a Jumper Harness that includes the required Resistor.
See Images below.
The 2 Images below shows a Sealed Delphi Jumper Harness with the required Resistor...
And it fits ACDelco Models AD230 and AD244 with LSx Wiring:
Also available is the addition of a Third Connector wired in for a SERVICEABLE Resistor (instead of an Inline Resistor)...
Using an ATM sized Blade Resistor in a Sealed Delphi Connector (easily replaced if the Resistor is ever damaged):
For anyone that is using an older GM/ ACDelco Model Alternator (10DN, 10SI, 12SI, CS130, CS130D, CS144, Etc)...
Or are using a Wiring Harness that is NOT LSx based (TPI Engine, Vortec Engine, Carbureted Engine, Etc)...
Adapter Harnesses are also available.
The Image below shows the Delphi Connectors that can be made into Adapter Harnesses (with or without the Resistor):
Motorsports Grade Jumper Harnesses are also available:
Old Jan 3, 2023 | 10:36 PM
vorteciroc's Avatar
Top Answer: 1
Re: LSx Swap Wiring
Most LSx Swap Wiring Harnesses do NOT include the required Diode for the Air-Conditioning Compressor Clutch Circuit.
A simple solution is to use a Jumper Harness that includes the required Diode.
See Images below.
The Image below shows a Sealed Delphi Jumper Harness with the required Diode...
And it fits ACDelco/ Harrison/ Sanden Compressors from the Late-1980s/ Early-1990s through the start of the Gen-V SBC.
The Jumper Harnesses with the required Diode is shown in the Image below:
Also available is the addition of a Third Connector wired in for a SERVICEABLE Diode (instead of an Parallel Inline Diode)...
Using an ATM sized Blade Diode in a Sealed Delphi Connector (easily replaced if the Diode is ever damaged):
The Image above shows an Older Delphi Connector that can be made into Adapter Harnesses (with or without the Diode):
The Image below shows a Motorsports Grade Jumper Harnesses with a Serviceable Diode (inside the Fuse-Holder and Connector):
Old Jan 5, 2023 | 11:20 PM
vorteciroc's Avatar
Top Answer: 1
Re: LSx Swap Wiring
Bootable Connectors for Holley EFI Control-Modules are now available!
Gtta
May 14, 2021 05:01 PM
6DRIP6GOD6
Jun 30, 2019 10:03 PM
jazzdadss
Feb 9, 2013 05:26 AM
blackbeauty89
Feb 28, 2012 06:57 AM
BRobinson
Nov 2, 2004 02:44 AM
