Dash harness 89 Firebird
Car: 1989 Firebird Formula
Engine: LS2
Axle/Gears: 8.8 Rear end from hawks
I cannot find any pictures about how to interior/dash harness should lay in the vehicle. If anyone has any it would be a huge help.
Also would like some help wiring in my Holley terminator to work with the dash harness? Idk what to do first time messing with harnesses.
Thanks in advance
Also if someone is looking for a brand new GM OEM harness for a 93 camaro, I also have one for a 2002. I can send pictures if interested. message me -brand new never been use
Thanks in advance
Car: '89 Firebird
Engine: 7.0L
Re: Dash harness 89 Firebird
All the wiring for gauges go through the big connector next to the brake booster (named C100 connector).
You can find ideas in post #188, https://www.thirdgen.org/forums/ltx-...ml#post5825637
Basically the 1998 LS1 Camaro coolant temp sensor and oil pressure sensor are compatible with your gauges.
Tachometer and speedometer will be run by the engine ECM.
Voltage and fuel gauge will continue to work as normal, it has nothing to do with the engine harness.
Engine: LS2
