4th Gen Filler Neck Ground
Old Oct 13, 2023 | 04:49 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
So after hours of breathing gas fumes, I'm finally wrapping up my 4th gen tank swap. I've test-mounted the filler neck and attempted to test for ground. The filler neck is painted so finding a spot on the filler neck to test for ground is a challenge. However, if I touch the unpainted flap on the inside of the neck it is a good ground. So technically, that little flap thing is attached to the rest of the filler neck so essentially the filler neck has to be grounded for that flapper to be grounded. Right? Are the fumes getting to me?
Old Oct 13, 2023 | 07:02 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 4th Gen Filler Neck Ground
You don't need the filler grounded, but it you have it screwed to the body it will be fine
Teddyxb93
Dec 22, 2020 10:37 PM
craig
Carburetors
Dec 5, 2007 10:03 AM
tamatt27
Jul 5, 2004 02:15 PM
