Fuel Pump Line Identification
Old Feb 12, 2024 | 08:44 AM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
I am having issues when fueling up my IROC and I think I plumbed the lines coming out of the fuel pump wrong. At about half full, the pump keeps kicking off. This usually means the tank is not vented correctly. I think I hooked up the lines wrong. Just to be sure, I need a diagram of where each line goes to. The only one I am positive is the fuel line since its has the fitting on it. I need to know where the other three go to. I know the three go to vent, vapor canister, and return line but which is which? I install all new fuel and vapor lines but by the time I did that, the fuel tank was in place and I was not sure which goes where.
Starting with the main fuel line, where do the other three go to?
Old Feb 12, 2024 | 09:01 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Fuel Pump Line Identification
The threaded one is feed, the next largest one is return, the other two go to vent and EVAP (not sure which).
Old Feb 12, 2024 | 09:45 AM
TJQIROC's Avatar
Engine: 6.2 Gen V
OK, that two down and two to go.
These are the last two. I am assuming the right circled one is evap and left is vent.
Old Mar 12, 2024 | 04:21 AM
fuchs's Avatar
Car: T/A
Engine: v8
[1] The thick line with the -6AN adapter on is the fuel supply
[2] Next one is the fuel return
[3] Next one was canister, cap off in the future .... or not... I've read it could function as a vent with a regulated cap
[4] Breather, leave as-is if working.
Maybe your breather is stuck closed?
TJQIROC
Jul 15, 2019 04:27 PM
jbander
Jun 26, 2019 06:41 PM
jeff311270
Carburetors
Nov 25, 2005 06:07 AM
1982TA
Sep 26, 2004 01:35 PM
spodeboy
Apr 21, 2002 12:39 PM
