Holley or GM drive by wire pedal
Looking to change over from drive by cable to drive by wire on my build.
I'm using a Holley Terminator X max and see its compatable with 3 different pedals.
The Holley one
https://www.holley.com/products/engi...RoCRxQQAvD_BwE
And these 2 GM ones: 1037 9038 and 1941 7903
And to mount the pedal, I was looking at the Hawks bracket.
https://www.hawksmotorsports.com/82-...t-ls2-ls3-ls7/
Anyone using this bracket with any of the pedals? How do they fit and is the position good?
The Holley one
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Holley or GM drive by wire pedal
The bracket is terrible and had to be trimmed to work, but it's serviceable. Ill have to look at what pedal I am running, as there are a few that work well.
Holley is compatible with most GM pedals. Keep in mind a handful of wire pairs need to be swapped
The holley pedal is for a C6 LS3
10379038 CTSV
19417903 C6 again
Pretty much and GEN IV LS pedal will work with minimal effort. GEN III stuff a little more. I posted diagrams of the most common variants in another thread
I'm running a Monte Carlo LS4 pedal with my build. It's surprisingly close to 3rd gen shape
I wouldn't buy that bracket. Every pedal mounts differently, so you'll be tweaking the thing already
The CTSV pedal is the easiest to custom mount because it's a simple L shape. If you have the skills to drill holes in metal and use a vice to pound flat sheet into an L, then you can handle that fab
10379038 CTSV
19417903 C6 again
