Starters and Heat
Old May 8, 2025 | 06:38 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Starters and Heat
What are y'all doing to protect your starter from excessive heat?? I'm running an iron LQ4 block with a Hooker turbo manifold setup. Everything has been mint up until the last little while where every now and then when I try to start the car it will just click. If I keep trying it'll eventually start but that's annoying.
I've triple checked power at the starter and it's all good. When it clicks and I hit it with a rubber hammer it starts and starts fast. I haven't checked for any corrosion on the connections but will do so tomorrow
Old May 8, 2025 | 09:36 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Re: Starters and Heat
0 gage power and ground cables, remote solenoid, and a DEI starter blanket.
Old May 8, 2025 | 11:10 PM
thatsupnow's Avatar
Do you find the DEI blanket makes a difference?? Ohh you use a remote solenoid too. That never crossed my mind at all
Old May 9, 2025 | 12:19 AM
soloc4's Avatar
I don’t have any data to prove or dispute whether the blanket made any difference, but with the header tubes so close to the starter I felt it was necessary. The battery is mounted in the trunk of the car and the starter solenoid is mounted in the right hand well with the fuel pump relay. The 0 gage cable is strictly for starting the car, there is a 4 gage wire to the alternator that distributes power to the rest of the car. The 0 gage ground cable runs from the battery to four bonding locations along the length of the car. Rear frame rail, chassis behind the door, fire wall, front frame rail, then to the engine block. The entire chassis is a ground cage. All of this successfully isolated the heat from the engine bay.
Old May 11, 2025 | 02:49 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
I just use the factory snap-on solenoid heat shield.
The starters on LS engines are actually pretty good, and don't draw nearly as much current as the big, ugly, heavy SBC starters. Those would really benefit from a heat shield.
Kyler_89RS
May 11, 2022 08:56 PM
matj1990
Carburetors
Apr 27, 2009 03:09 PM
Slow2.8
May 5, 2006 09:33 PM
Layne
Oct 19, 2004 06:36 PM
IROCBlueZ28
Jun 20, 2004 11:10 PM
