lm7 swapping my gen 3 z28 camaro
Old Jul 5, 2025 | 09:22 PM
John0129's Avatar
So i have bought a roller 3rd gen Camaro. It has a t5 transmission in it and i am looking for advice on what parts i will need to swap an lm7 into it. i know there are many ways to mate the trans and engine together, i am looking for a more cost affective way. that is why i am using a t5 instead of a t56 transmission. i know that i would need a bell housing adapter or a new bellhousing. I don't know what clutch components go with that i also know that with some of the bellhousings the clocking is wrong and the trans mounts don't work. I would like to know if there is a way to mate the two and have all the stock mounting brackets work and what part combinations work with that.
Any information is very appreciated, thank you in advance.
Edit, i did some digging and found a good bellhousing adapter that will fit and keep the stock bell hosing of the t5 and keep the 22.5 degree angle and has the pilot bushing (Lakewood bellhousing adapter pn #15901LKW) its roughly 350$. I then can use a ls1 style 168 tooth flywheel. the stock lm7 starter should work. the only thing i dont know is what clutch and pressure plate would work with this combo.
Old Jul 8, 2025 | 08:04 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: lm7 swapping my gen 3 z28 camaro
This thread might help a guy out:
https://ls1tech.com/forums/manual-tr...-can-here.html
87.Pos
Aug 29, 2023 07:48 PM
Eli Wallen
Dec 21, 2014 11:49 AM
zjorvis95
Dec 11, 2009 04:57 AM
Breadfan
Apr 1, 2003 05:41 PM
logikal6785
Jul 12, 2002 01:58 AM
