Broke an ARP damper bolt
Old Oct 23, 2025 | 09:32 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
I know I’m F’d, but how bad I don’t know yet. While installing an ATI harmonic balancer I broke the ARP damper bolt in the end of the crankshaft while trying to seat the balancer. The interference fit on these things is ridiculous (.009”) and I kept thinking it needed to be deeper and then the bolt exploded. Any suggestions short of pulling the motor?, that is already being discussed. Has anyone seen or heard of anything like this? To add insult to injury, I dented the top of the left fender with the breaker bar on my way down to sitting my *** on the floor.
Old Oct 23, 2025 | 09:35 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Broke an ARP damper bolt
Sorry, that sucks.
Without clamping load behind the bolt head, wouldn't the threads be relaxed and easy to spin out?
Old Oct 23, 2025 | 10:04 PM
soloc4's Avatar
Originally Posted by QwkTrip
Sorry, that sucks.
I don’t know yet. I was so frustrated and angry with myself that I just packed up and went inside. I am hoping that will be the case, but it is 4 inches inside face of the damper.
Old Oct 24, 2025 | 08:00 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Man that sucks. Even if you remove the balancer, the piece in the crank will be difficult to remove. Since the top of the broken piece is jagged, you will not be able to drill it for an easy-out. The drill bit would just keep slipping off-center. Assuming you could find a drill bit long enough.
Good luck,
Fred
Old Oct 24, 2025 | 08:27 PM
soloc4's Avatar
Good luck,
Fred
Thanks Fred. To exasperate the situation, the engine is in the car and the anti-sway bar is in front of the center of the balancer. I have to jack the engine up 6 inches to gain access to the center of the damper, but can’t get my head in there to evaluate the damage. I’ll need all of the luck I can get.
Old Oct 24, 2025 | 08:51 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Why were you using that bolt to seat the damper?? That's what an installer tool is for.
I am surprised that a ARP bolt broke though...
Old Oct 24, 2025 | 09:18 PM
soloc4's Avatar
I did use an installation tool to draw the damper on to the point that I could turn the draw nut with a wrench. Unfortunately I felt it needed more and broke out the 3 foot breaker bar and used the bolt to draw it in more. I should have just torqued it to 235 ft/lb and been done with it. I also thought that there would be no way for me to break an ARP bolt this size. We now know that it can be done, I just didn’t want to be the guy to prove it.
Old Oct 24, 2025 | 09:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Well, you do have something that mates up perfectly to the broken piece in the crank....
Maybe grind off the threads from the broken piece and put a small dab of epoxy or JB weld on the end. Slip it into the crank and mate up the ends and let it set. Then turn it out.
I don't know if it will work but trying is free. Just don't JB Weld it to the crank
Old Oct 24, 2025 | 10:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Look how far those threads have stretched! Wowza
had to have been some serious tq on the bolt to do that.
could make a sleeve/bushing to fit down the balancer to center a reverse drill bit
Old Oct 24, 2025 | 10:14 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
^^^ That's a better idea. The more I think about it the two bolt halves won't make contact because they have shrunk.
Old Oct 24, 2025 | 11:09 PM
soloc4's Avatar
could make a sleeve to fit down the balancer and center a reverse drill bit
Best idea I have been given so far. A friend suggested the reverse drill bit, but the centering bushing is brilliant. Thanks.
Old Oct 25, 2025 | 06:59 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
X2
Old Oct 25, 2025 | 01:36 PM
Fred SS's Avatar
Transmission: 2004r
Centering bushing is great idea.
Fred
Old Oct 25, 2025 | 06:33 PM
soloc4's Avatar
Hopefully this will get it done
I was able to look inside at the end of the bolt and it appears to have a thread exposed, so it didn’t snap off inside the threaded hole. This is encouraging so I found a 1/4 LH drill bit and extension and made a wooden drill guide that fits in the end of the balancer. It would be great if the drill bit is successful in backing the broken bolt out, but I have an extractor on hand just in case. I will find out tomorrow and report back here with the results. On a side note: the damaged area on top of the fender is a chip in the clear coat. No dent and the paint was untouched. That should be an easy repair. Wish me luck.
Old Oct 25, 2025 | 07:21 PM
T.L.'s Avatar
We're all crossing our fingers...
Old Oct 26, 2025 | 03:58 PM
soloc4's Avatar
SUCCESS!!!
I can’t believe I got this out without having to remove the balancer. It took over 3 hours turning it by hand with a pair of needle nose pliers and a magnetic pickup tool. The LH drill bit and wooden guide would have worked perfectly if not for the shaft spinning in the chuck of the 90 degree drill. The important thing is that it came out. That bolt has more stretch than a cheese pizza, it’s amazing that I got it out. I want to thank everyone here for talking me off the ledge. I was so stressed out over this. I will install the new bolt when it arrives and move on.
Old Oct 26, 2025 | 06:02 PM
Fred SS's Avatar
Transmission: 2004r
That is great news. Enjoy your success.
Fred
Old Oct 26, 2025 | 10:12 PM
T.L.'s Avatar
Excellent. I love a story with a happy ending...
Old Oct 26, 2025 | 10:55 PM
dannyual320's Avatar
Congratulations on getting that broken bolt out of the crankshaft!
Old Oct 27, 2025 | 08:42 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Dodged the bullet on this one. Good job.
Old Oct 29, 2025 | 04:48 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Doesn't look like you used any ARP lube anywhere on that bolt. Supposed to use it on the threads and both sides of that washer. I've taken mine out a bunch and crank it down to 240 ft/lbs every time without issue.
Old Oct 29, 2025 | 04:55 PM
T.L.'s Avatar
Why in the world would it need to be 240 ft.-lbs.???...
Old Oct 29, 2025 | 04:58 PM
thatsupnow's Avatar
Because that's what ARP calls for. Well 235 ft/lbs
For an LS engine with an ARP crank bolt, the correct torque is 235 ft-lbs,
Old Oct 29, 2025 | 05:29 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
HOLY SMOKES! I am just seeing this thread now. It was quite a roller coaster ride to read about all of that, and I want you to know I came so super close to being in this same scenario last year. I put a new ATI super-damper on the 406 this past winter and could NOT get it to seat. I had full body force on it and was ready for a catastrophe.
I used the installer tool and everything. Failed multiple days in a row. One day I took the plunge and read about heating up the damper to a certain degree in the oven, and freezing the crank snout, so I took my freakin nitrous bottle and shot it at the crank snout for a while. then used the tool and some lube and finally finally got it to seat in there. I also deburred the key and keyway a slight chamfer too. what a wild experience you had; real glad you got it removed. Next... whats your plan for getting things back together?
the saga of my damper situation begins at post #563 on Dec 24th 2024 at this link:
https://www.thirdgen.org/forums/tech...nstall-12.html
Old Oct 29, 2025 | 05:57 PM
thatsupnow's Avatar
They usually need a light hone job before installing so they just slip on without issue. The machine shop did it all for me when they assembled my 370 short block. Just baked the hub for 20 minutes on 350* and it went on smooth as butter
Old Oct 31, 2025 | 06:28 PM
soloc4's Avatar
Here’s a follow up. I ordered a new ARP bolt and torqued it to 235 ft/lb. It turns out that the balancer was fully seated. If you look inside the balancer without the bolt installed the end of the crankshaft is supposed to be an 1/8 inch recessed in the hub ( the original balancer was like that). The instructions from ATI specifically stated “Do Not resize or defeat the interference fit of the hub”. I also did not want to heat the balancer and risk damaging the elastomer ring. The belts line up and I am waiting for the steering rack and pump to come back from Turn One before I can put it back together. The chip in the paint turned out to be just the clear coat and I was able to fill and color sand it. I got really lucky and I don’t want to ever go through this again.
Old Nov 1, 2025 | 01:05 PM
thatsupnow's Avatar
Are you using a stock crank with no key?? I have an LSA crank that's keyed and a quick hone job makes life much easier. I don't see how a guy could damage to elastomer rings when all you need to do is heat the hub up separately from the damper, install the hub then bolt the damper on
Old Nov 1, 2025 | 02:03 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That's a change since I last bought an ATI damper about 8 years ago. Back then the hubs were shipped a little tight and they expected you to hone the ID of the hub to proper interference fit to the measured OD of your crank.
My LS7 crank was on the high side of the OD spec which required that I hone the ATI hub or it would have been waaaaay too tight
Old Nov 1, 2025 | 02:38 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Glad you got it taken care of.
That could have been a real nightmare..
Old Nov 1, 2025 | 06:58 PM
soloc4's Avatar
I have an Eagle 4” stroker crank with a key. The interference fit on the hub was .007, within the recommended .006-.009 range, so it didn’t require honing. The A/C pulley is mounted on the back of the hub and uses the three bolts through the face of the damper to attach it, basically sandwiching the hub so I couldn’t install the hub to the crank before assembling the balancer. The fact that I was doing all of this in a rented space with basic hand tools and no air with the engine in the car also complicated things.
The instructions do have a chart listing the acceptable tolerances for various size crank snouts and mine was within range so I didn’t need to hone it.
My tolerance range was .006-.009. I can’t imagine trying to press this on at the high end of that range.
Old Nov 2, 2025 | 06:40 AM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
Are we sure that decimal is not supposed to be one more place to the left as in .0006-.0009 inch interference fit? I have an ATI damper destined for my forever in the corner of the garage project and that range is what I remember.
M
Old Nov 3, 2025 | 03:14 PM
M
This is a very good question. There is a big difference between .0006-.0009" and .006-.009" interference!
Champ198
Oct 25, 2025 04:42 PM
85Iroc-Z
Oct 10, 2021 01:19 PM
rockmebaby
May 27, 2004 09:19 AM
JoshDT91
Dec 15, 2002 11:38 AM
JunkHead84
Nov 13, 2001 07:17 PM
