LT1 Swappers - Official Registry??
Old Jan 22, 2004 | 12:45 PM
  #51
Drakar's Avatar
Giving my 96 LT1 form a Roadmaster a freshen up, and taking pics of EVERYTHING I do to help out TexasLT1's swapper guide, small change of plans potentially it will be installed into an 88IROC Vert if the deal goes well instead of my current now for sale 85 Z.
but which ever car I have count me in for having it be LT1 enabled.
Old Jan 22, 2004 | 02:09 PM
  #52
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
that LT1 is going to break your T5 heh heh heh. That's the same motor I have, use an obd1 computer from a 95
Old Jan 26, 2004 | 01:10 PM
  #53
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
My name is Billy from Alabama
90 Formula( 305 TPI/T5)
94 LT1/T56
hotcam kit
SLP 1 3/4 headers and matching y pipe
Ram heavy duty clutch
stock 10 bolt rear with 4.10
I completed my swap in August and I have been driving it with no problems(knock on wood) since then.
Old Feb 11, 2004 | 11:57 AM
  #54
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Name: Neil (6speedIROC)
Car: 1986 IROC, was 305 TPI auto
Engine Mods: 1995 LT1 from Buick Roadmaster, stock cam & heads, 1995 f-body program less EGR/AIR and A/C, 3.5" ported f-body MAF, custom fuel lines, custom self-made wiring harness, All Buick accessories, f-body waterpump, 160 STAT, TB bypass, TB airfoil.
Car Mods: T56 trans, LT4 SLP clutch, Pro5.0, LS1 aluminum driveshaft, 3.23 gears, Lakewood LCA's/Panhard, Flowmaster, MAC Headers & Y, !CAT.
Ran 13.8 @103 with horrible traction, no powershift etc.
Gotta get to a better track with new rubber and get some low 13's!!
Old Mar 24, 2004 | 11:17 PM
  #55
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Ok I finally finished the swap
I have a 1991 RS
LT1 engine ,hooker super comps long tube, egr,ac deleat, SS ram air box for the LT1s and custom ecu
T56 six speed
4th gen rear axle and gas tank
complete 4th gen dash and center console out of a 95
SS ram air hood ported out to be functional
I will try to get some pics up as soon as I can get a good photo shoot
Old May 2, 2004 | 12:05 AM
  #56
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
1991 Camaro V6 RS
95 LT1 and t-56 from a trans am
See sig for mods.
Old May 10, 2004 | 01:36 AM
  #57
Mark P.'s Avatar
Car: '88 Sport Coupe Convertible in Yellow Gold
Engine: '70 LT1, AFR 190s
Does an Early LT1 qualify? Mine is from a '70 vette. It's carbed for now but soon to get a Holley StealthRam MPFI and a Holley 950 programable ECM. Putting in a T56 before I install the 12 bolt disc brake posi.....if this thing hooks up with this much HP my T5 will scatter all over the road. My ported AFR 190s w/ 64cc chambers came off a car that ran mid 10s. MY *** this motor runs like a beast!
Old May 10, 2004 | 01:51 AM
  #58
Mark P.'s Avatar
Re: LT1 Swappers - Official Registry??
Originally posted by Brett
355 4-bolt splayed, all forged, GTP 2 heads, custom ground GTP 6 cam, all Comp Cams valve train, AFR hydra-rev kit. Just got the 42# injectors so I can finally fuel it past 4700rpm.
ATI D-1sc to come in '03
Ummmmmmmm...Fuel delivery problems above 4700 RPM are caused by intake runner length not injector size acording to Holley. That is why I'm going with a StealthRam set up..it makes power up to 5500 to 6000 RPM. check out Holley's web site for more info.
Old May 16, 2004 | 03:15 PM
  #59
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
1987 TA
1995 LT1/accessories 1996 Wiring Auto Wiring Harness
1995 T56
3.73 posi rear
SLP 1 3/4" headers and 3" cat back with an empty cat
No emissions equipment working....gotta fix that soon!
Driveshaft in dire need of rebalancing/replacement after the HELP! company *%(&* my car over bad with mis-manufactured U-Joint Straps....I learned the hard way that GM still makes them, and many dealers still stock them
Drivers Side Door needs to be re-hung, but I am waiting for the money to get the aftermarket replacement....It crunched the quarter panel so it looks like hell
Rear Spoiler is collapsed
***** Drivers Seat.....good 'ol Pep Boys A3 seat since mine was dead, and the cheapest good thirdgen replacement was $150 + shipping + time, where I got the ***** seat, welded togather a mounting bracket, and got to drive my car that day....oh the shame of it all!
MSD 6a ignition + Blaster SS coil.....except, I need the LT1 adapter for the coil so the whole ignition system isn't in the car!
All wiring done by a Computer Science Major and it shows....hey I was in a hurry! I will post some pics when the digi-cam becomes available again!
I came back here today to get the diagram of the PCM which I know is posted here since I am FINALLY going to wire my MAF and EGR properly....the AIR system will still be out for a while though...
Old May 18, 2004 | 11:51 PM
  #60
adonwayne@aol.c's Avatar
Car: 92 formula conv.
Engine: LT1 355 FI
LT1 Swappers-Official
Working on a 92 firebird vert formula,LT1 F.I. .30 over,305 comp cam, 58 mm throtle body,roller rockers,electrict water pump,fulel presuer regulater,high volume fule pump,hooker long tube headers and B&M 700R4 trany.suspention WS6 whith HAL 4 way adjustable shocks ,panhard bar,adjstablel torgue arm and a few other suspention mods,dyno @ AGUSTINOS rated 286 H.P. @ wheels best time 12.99@111.2.This year changing to AFR 180 comp heads,AFR says should produce 330 to350 H.P. @wheels.I have had a lot of work done on this car ANYONE FAMULAR with AFR mods?runing 373's rear gears.Iwill add a bit of advise,#1 when swaping to LT1'S 95's & and under have advantges,E.G. easer to burn mods to computor,every change you make has to be upgraded to the computor,cams e.t. #2 change to high volme fule pump,an EFI&TPI fule pump will not work on an FI#3 FI stock injectors will do the job when changing to mod heads E.G. 180 AFR COMP heads , got lots more imfo,learnd from experience,oh yea whatch out for faulty oilpump pickup units.
Old May 20, 2004 | 09:08 AM
  #61
Engine: LT1 355 FI
LT1/ANYONE using AFR !80 COMP heads need to know results
Old Jun 8, 2004 | 03:32 PM
  #62
iroc2000lt1's Avatar
Car: 1986 Iroc Z28 & 2000 Z28
Engine: 1993 LT1
Transmission: T56 6 Speed
I'm new to the Message Boards But
This is my 86 IROC
93 LT1 T56
Troy
1986 Iroc
2000 Camaro
Old Jun 8, 2004 | 03:39 PM
  #63
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Cool....another Vette Lt1...Can you send me a better pic of the engine...just curious to see how yours looks compared to mine. Also, do you have a M.A.F.? Too hard to tell from the pic.
Old Jun 8, 2004 | 03:48 PM
  #64
Engine: 1993 LT1
Is this better This is a old pic the Lt1 one is pulled out for right now, I having it bord out 30over, Lt4 hot cam and the heads and intake ported. Every thing under the hood that was not in use was removed the AC, Heat every thing, Then repanted under the hood with Base coat clear coat
Old Sep 8, 2004 | 12:24 PM
  #65
FastKitteN's Avatar
Car: 1988 Camaro
Engine: 5.7liter v8 (LT1 carb)
Transmission: th-350 rebuilt with a 2400-2800 stall
Well were pretty much done with the swap. I would like to be on the list now.
1988 Chevy Camaro 2.8 v6 with 700r4 Transmission
Is now:
1988 Chevy Camaro LT1 Carbed with a th350
Engine:
Came from a 94 Caprice police car-changed the cam, roller rockers, springs, and retainers. All Comp Cams
All MSD ignition (Probillet Dist. 6a box and blast II coil)
My husband ported and cleaned up my heads
Transmission
2400-2800 Stall
Complete rebuild kit from Transgo
We were trying to run a Holley carb but the car will not idle so Im using a q-jet
CSI Electric water pump, Hedman headers with y-pipe and 95 z28 muffler with exhaust tips. Taylor plug wires with NGK spark plugs.
Little bit more fine turning and she will be kicking butt.
Old Sep 13, 2004 | 01:07 AM
  #66
NoUseAbleNames's Avatar
Jeff C
Elmira NY
lt1 powered 92 rs
cc306
ported heads and intake
58mm bbk
crane ignition.rev kit
crane wires
crane coil
soon to come
roller rockers
comp springs
timing set
headers
and a broken t5
Old Sep 27, 2004 | 11:33 PM
  #67
slimdawson's Avatar
Car: 1991 RS
Engine: Procharged LT1
Hi everyone. As you can probably see, I have been a member for a while but never used this site. I wandered back over here yesterday and saw this post. I got my LT1 running in Feb of 2002.
My name is Mike and I am located in NC.
Here are the details:
1991 RS Camaro, blue, ttopped
96 LT1 with an ATI Procharger P600b,
T56 and 4th gen rear with 3.42s,
OBD1 conversion with Tunercat,
1 3/4" SLP headers and ypipe,
3" mandrel bent exhaust with Flowmaster,
CSI electric H2O pump,
Crane gold 1.6rrs,
Poly bushings,
IRS Terminator adj. torque arm,
94 front and rear leather seats,
Chrome 17" Y2Ks
Nothing really to add on the swap details that isn't known already. I did convert the blower kit I had to a front mount intercooler and moved the MAF to after the head unit. I have 4th gen fuel lines so I had to run them and use a 4th gen gas tank(which required some cutting and rewelding of the fuel filler neck). I had to custom fab pretty much everything for the supercharger. Including the s/c bracket, intercooler piping and intake piping. The blower install was more in depth than the motor/tranny swap. I still haven't seen a blown LT1 in a 3rd gen yet, although I am sure there are some.
Well, that is it. I will repost if I find that I missed something later.
Here are a couple engine pics. If it isn't raining tomorrow, I will take some more as I have moved the location of the air filter.
http://pg.photos.yahoo.com/ph/evolve...edrs/my_photos
Old Nov 19, 2004 | 04:02 PM
  #68
TexasLT1's Avatar
Car: '92 RS
Just wanted to say I got all of the new posts added to the registry on my website.
Also, just want to apologize for not having the swap guide completed. I've had to put it on the back burner with school. But one of these days, it WILL get completed.
Old Nov 19, 2004 | 04:58 PM
  #69
vladicore's Avatar
Car: 67 camaro ( project )
Engine: 6.7 408 n a snail
Transmission: 4l80 - stalled
Axle/Gears: 3.25 - narrowd tci kit 9 inch
im not quite finished w/ mine yet but hought id post anyways
tug thompson
member of wtfba.org west tennessee f body assoc.
1991 hardtop z28. originally a 350 tpi 700r4. had all options ext 1le.
have a 96 lt1 out of a impala ss. w/ the f.i.
plenum fully ported, stage 3 port n polished heads, crane gold 1.6 rr. for the lt1, 2.02 1.60 valves, comp springs to match the cam, custom ground cam( higher lift n longer duration thne lt4 hotcam) 28 pd injectors, summit stage 1 rods, forged flat top pistons, steel crank, msd 6al box, msd wires. mid length headers and y pipe, not cats( no inspection in the county) flowmaster duals w/ 4th gen z28 tips. throttle body air foil, k&n filter. i think thats it. i need to get a few more parts befor install. running a 700r4 thats fully built behind it, ceramic clutches updated pump, xtra clutches n steels, banks servo n shift kit, beast sunshell gear, .500 flow valve, running a aluminum driveshaft, 9 bolt 3.23 posi rear w/ updated disc brakes n sloted rotors al the way @.posiblt going to look at a nitrous kit for it too.
previously had this setup in my s10 w/ a 4l60( not 4l60e) running off a 93 ecm n wiring harness. had a 2.73 gear in it and ran a 12.7. all motor 1/4 mile.
Old Nov 22, 2004 | 08:23 PM
  #70
cdxn4950's Avatar
Car: 1986 IROC
Engine: Lt1 soon
Hey this is Chad from central georgia.
Was: 86' Iroc with 305 TPI and 700-r4
Will Be: Iroc with 95' Transam LT-1 with T-56 also with the 4-gen rear and seats
Just started the swap last week. Got the whole interior of camaro pulled out because it was soaked with water but no rust luckily. Hope to have it done before too long
Old Dec 8, 2004 | 03:42 PM
  #71
Drakar's Avatar
Finally finished, just doing so minor fine tuning, and little clean here and there.
96 Buick LT1 converted to 95 OBDI
AC/AIR/EGR/Charcoal canister delete
LS1 plastic tank and pump
Hooker 2055 Headers
3" Dynomax (24222) Bullet muffler exit before rear tires
Comp Cams 983 Spring Kit
TPI Intake setup (relocated IAT)
T-5
3.73 peg leg!
Custom Tuned PCM
I get some completed pics first chance I get.
First Track times in the spring!
Thanks to everyone that helped.
Old Dec 9, 2004 | 03:16 PM
  #72
slimdawson's Avatar
Car: 1991 RS
I don't see my car in the registry.
Are you still taking cars Texas?
Old Dec 20, 2004 | 03:09 AM
  #73
Crazy3gz's Avatar
Car: 1987 Z28
I have one, have had it for quite a while.
David
Antelope, CA
87 z28
LT1
lots of bolt ons
t56
lt1 rear (moser 12 bolt in the garage)
full 4th gen interior swap
91-91 Z28 apperance
10 spokes
really too much to list
Sitting here waiting to go on very soon, is a full hotcam kit, NX kit, and the 12 bolt.
Best run to date is a 13.4 @108. (should be in the 11s for sure on the bottle by summer)
Old Jan 10, 2005 | 10:48 PM
  #74
Engine: LT1 355 FI
RAIRBIRD RUNIN STRONG!!!
RAIRBIRD LT1
Old Jan 11, 2005 | 01:09 AM
  #75
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
David
Antelope, CA
87 z28
LT1
lots of bolt ons
t56
91-91 Z28 apperance
10 spokes
Pics Please!
Old Jan 11, 2005 | 09:54 AM
  #76
FastKitteN's Avatar
Car: 1988 Camaro
I havent got the chance to run mine yet.. Its getting painted as soon as we get our tax refund.. woohoo.. I got my rearend for it. Came out of a 92 z 3:23 gears with posi and their disc. No more drum brakes.. I love my camaro!!!
Old Jan 11, 2005 | 10:10 AM
  #77
TexasLT1's Avatar
Car: '92 RS
Sure am, sorry I missed it, it's been a while since I've checked this thread or had a chance to work on the registry/swap guide. Should have it updated in the next couple of days.
Old Jan 14, 2005 | 07:19 PM
  #78
z91bowtie1's Avatar
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
1991 Z28 convertible. 305 tpi now has a 96 lt1 out of a trans am.
t5 trans with a 373 rear end.
Old Feb 25, 2005 | 12:08 PM
  #79
mliers's Avatar
Car: 1992 Camaro
Transmission: Auto :(
Axle/Gears: 94 Formula rear end with 3.42s
I'm in the progress of the swap into my 92 RS with a 305 tbi. Doing a few little things to it but I'm a college student so I don't have a lot of money to shell out. Starting from a bare block so most of the stuff will be new but some things I'm just having to get used cuz of money issues. Here are a few things I'm doing:
93 painless harness and computer with modified chip
New stock assembled heads(got really cheap) (may port)
Kmotion valve springs
Comp cam with lifters
eagle cast steel crank
trw speed pro forged pistons
eagle forged rods
stock intake manifold (may port it)
Removing a/c and heater totally
Put in a 94 formula rear end that has 3.23 gears (much better than my limited slip)
Probably will paint block and intake manifold chevy red
I'm taking a class and doing this for credit so it will be done for sure by april and hopefully I can bring it to the gatherings this summer down in atlanta, the one in IL, and the one is bowling green in sept. If anyone is in the Chattanooga area or comes by here we could hook up and cruise to any of the gatherings.
In the future:
tremec 6 speed
total interior restoration
new front end and paint job
complete suspension upgrade
possibly a little nitrous
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
