It's finally in...
Old Jul 14, 2007 | 09:30 AM
IROCZ_L98's Avatar
Car: 1987 IROCZ
Engine: 355, Vortec Heads, Carbed
Transmission: TH350, 2800 stall
Axle/Gears: 3.27 9 Bolt
It's finally in...
After about a year of working here and there and other things taking priority it is finally built and in!!! The specs are as follows...
1987 L98 Block
Bored .030 Over
.030 Flat Top Speed Pro Hyperutectic Pistons
Stock Crank (only required polish)
Vortec Heads, 3 Angle Valve Job, Resurfaced, Screw in studs
New Valve Springs (not sure what brand machine shop sourced them)
LT4 Retainers
Comp Cams XR276HR Cam
Reused Stock Roller Lifters (good condition)
Professional Products Single Plane Intake
Holley 3310 750 cfm
Double Roller Timing Chain
Hasting Chrome Moly Rings
Clevlite Bearings
Fel-Pro Gaskets
Th350 with B&M shift kit, upgraded clutches etc, 2800 stall converter
On to the pics...
And a before pic...
Old Jul 14, 2007 | 11:57 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
Re: It's finally in...
wow man you did a killer job, you could eat outta that bay!!! IMPRESSIVE!!!!!!
Old Jul 14, 2007 | 12:55 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
o wow that looks nice
Old Jul 14, 2007 | 07:35 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Looks sweet, but how did you bend that lift plate. Have put mine through hell and still looks the same + a few scratches.
Old Jul 14, 2007 | 08:02 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
holley 3310 isn't a double pumper carb, and a single plane intake would want a 3500-4000 stall typically as well.
Old Jul 15, 2007 | 10:26 AM
IROCZ_L98's Avatar
Car: 1987 IROCZ
Thanks for all the comments! Put alot of time into the car so far, can't wait to finish it!
You are correct about the carb I meant dual feed not double pumper, the single plane is on there for now, I got it for a steal. I will probably end up selling it and replacing it with an air gap though...pretty simple to swap out after she's running
Old Jul 15, 2007 | 10:32 AM
IROCZ_L98's Avatar
Car: 1987 IROCZ
Haha funny story, the reason the lift plate is bent like that is they went to pick up an engine for the late model from the builder all they had was a truck with a hard cover on the bed so in order for the cover to close they bent the plate I didn't install the engine/tranny with it either...I was going too but was kinda leary with having the vortec intake.
Old Jul 15, 2007 | 11:50 AM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Sweet, I cant wait for mine to be in. let us know what she runs.
What did you use to paint the engine bay?
Old Jul 15, 2007 | 11:54 AM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
thats very clean nice job
Old Jul 15, 2007 | 01:57 PM
IROCZ_L98's Avatar
Car: 1987 IROCZ
Rust Oleum Industrial Enamel, used it plenty of times on suspension components and engine bays, stuff holds up good
Old Jul 15, 2007 | 02:19 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
looks awesome
Old Jul 15, 2007 | 03:18 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Man that is really super clean...........
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
FormulasOnly
Sep 10, 2015 09:07 PM
