91 camaro RS from belgium
Old 11-23-2011, 11:32 AM
  #101
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: 91 camaro RS from belgium
the pic of google maps is from 3 years ago.
BUt thi summer my hood popped open against 70mph.
so a new hood + fenders are on the way and should be arriving any day now.
and thats the reason not to many people own an american car over here.
be honest, for the same money you can drive a mercedes or beemer witch has better support over here then an american car.
GM wants to bring a new cadillac to europe, but if that new caddy aint gonna be equiped with a 2L Diesel engine, nobody is gonna buy those in belgium. thats just the facts.
Old 02-17-2012, 03:24 PM
  #102
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
this happened this summer when to hood popped at 70mph
we are now rebuilding the car. starting with the engine.
it got a new cam, heads shaved 0.5mm. pacesetter headers will arrive next week. iroc intake, 34 en 23 mm swaybar
it gets a shiftkit installed.
after that it will go to the bodyshop for some allignement issues. where the car will get new fenders and a new irocZ hood.
also I probably gonna ask if they will paint the stripes instead of using stickers.
Old 03-06-2012, 05:03 PM
  #103
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Looking over your thread and that is a great looking car. Sorry about the hood, that bites. Good luck with it, I'm sure you won't quit till it looks good again.
Old 03-07-2012, 02:28 AM
  #104
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
nope, I wont quit.
I installed a ( gm ) 34mm en 23mm swaybar
my sherman iroc hood and fenders finally arrived last month after waiting for 20 weeks. ( ordered them in september )
I installed the comp cams 262 cam kit + timing chain and gear and shaved the heads 0.5mm
I also polished the intake slightly.
engine also seems to be a 3.4 instead of a 3.1..
last I installed some pacesetter headers.
still need to put in the airpump delete pulley.
we are now busy with installing crank dampner
now we need to put the lifters back in and build up the intake + brackets. but it looks like im missing 2 bolts. ( those that hold the ac and steeringpump against the heads.
need to search for those again.
also done,calipers painted
arrived not yet installed, new airco condensor + dryer, ATP transmission shift kit, new parking brake shoes, transmission cooler.
I hope that by the end of the month we it can go to the painter/bodyshop.
car will be painted the same color of red, but the stripes wil become painted in an 86 silver. ( instead of stickers )
and the black eyelids will be a 91 black color.
frame will also get pulled straight ( I knew this for a couple of years, now want to do something about it.
and lastly, new uniroyal rainsport tires. ( our cars don't drive well in the rain so they need every little bit of help they can get.
plans for next year. new floorpans
BMR or Umi subframeconnectors. ( maybe a set of alstons 2 but only bolted in )
koni+eibacks+ founders strut mounts.
extra: torson differential if I find one.
Old 03-13-2012, 04:05 AM
  #105
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
slow and steady its all coming along
Old 03-14-2012, 05:57 PM
  #106
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Keep up the great work, car looks awesome!
Old 03-19-2012, 07:08 AM
  #107
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
and we just keep on building ( for got sake I hope I dont have an internal leak. I already found 2 seals that werre leaking ( waterpump seal ) and thermostat housing seal.
I took both of them back of and used some blue liquid gasket enhancer around the enitre area to make sure its really sealed ( it is now ).... ( did use fel-pro gaskets, so those should have been okay )
anyway, some new pics.
Old 05-24-2012, 03:27 PM
  #108
Awesome-X's Avatar
Car: 87 Camaro
Are those 18 inch torque thrusts? Those look awesome!
Old 05-24-2012, 03:30 PM
  #109
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
17" TT2, 235/45 front 255.40 rear
Old 07-16-2012, 02:17 PM
  #110
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
forgot to update this thread.
wel we got the engine together again and up and running.
we still need a wee little bit of tuning here and there.
it seems that we cant run the car on more then 8 degrees of base timing.
else the engine will bog when you try to start it with the ESC cable plugged in again.
here is a movie where we where checking some of the last funky problems.
for some reason I still got some engine knock when I rev it quickly behind eachother.
still to be installed on the car is bigger injectors and a flowmaster muffler ( scavenged it of a broken down camaro.)
also found myself some electric mirrors with the complete wiring for it.
but we are still waiting for the car to come back from the bodyshop. they straightened the frame now, and now they are cleaning the body for painting etc. this painting + framepulling will cost me 5K+ but when its done, its gonna be suweet.
Old 08-01-2012, 06:23 AM
  #111
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
so I finally got some updates from the bodyshop.
not that you can do everything done on a car x2 in price since all the parts need to be shipped from america to belgium. and everything here is almost double as expensive.
Old 08-01-2012, 06:26 AM
  #112
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
the light blue is a new ducktail spoiler and the darker blue is a set of electric camaro mirrors
Old 08-01-2012, 06:28 AM
  #113
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 08-01-2012, 06:29 AM
  #114
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
score of the day,
a flowmaster muffler with new exhaust tips
Old 08-24-2012, 02:12 PM
  #115
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
keeping to tease.
Old 09-06-2012, 04:04 PM
  #116
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 09-06-2012, 04:05 PM
  #117
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 09-07-2012, 07:56 AM
  #118
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
car looks great. the front turn signal can be polished out to make them look better. What i did was remove them held it in one hand and sanded it with 2000 grit wet sand paper until the light felt smooth took about 15 minutes for mine. then i took my buffing wheel with a wool pad and alittle polish not for lenses but for the body laid teh buffer on the floor held it with my foot pushed the button with my foot then with my hands ran the lenses against the buffer being carefull of heating it up to much and holding the part tight so it doesn't fly out of my hands. they now look brand new cost me nothing to do.
Old 09-15-2012, 12:17 PM
  #119
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Freshly painted
Old 01-29-2013, 11:02 AM
  #120
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Originally Posted by Timmie
I got to dissapoint you.
since belgium laws support ricers, all or tuners are al show and no go.
fat exhaust, cold air intake, bodykitt, lowering springs, big rims, spoiler, lexus lights.and big ice installation.
mostly on an opel astra, vw golf, seat ibiza
How is it rice supported? Didn't you say no big wings, wood parts, or changed exhaust? lol
Old 01-29-2013, 12:50 PM
  #121
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
changing echaust not allowed, changing exhaust tip = allowed
ducktape = allowed
stickers = allowed
engine tuning = not allowed
Old 01-30-2013, 09:18 AM
  #122
Jk_Under's Avatar
Engine: 305 5.0L
ducktape = allowed
stickers = allowed
Now it makes sense
Old 05-15-2013, 08:22 AM
  #123
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
time to update this topic again.
since we needed to reweld the floorpans, and then give it the raammat treatment. it was also time to do the rest of the body.
I will let the pictures speak for themselves.
due to waterleaks we had to redo some of the interior.
so.
first up, the doors
we build a new cardboard from scratch and put the ensolite on the back of the panels.
Old 05-15-2013, 08:24 AM
  #124
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
afterwards we needed to put the new vinyl and cloth on it.
we also did the whole roof.
Old 05-15-2013, 08:26 AM
  #125
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 05-15-2013, 08:29 AM
  #126
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
ofcours we also needed some new seats, the old ones where real in bad shape. but we fould some nice 30 anniversary 1997 z28 seats.
followed up was the middle console.
Old 05-15-2013, 08:31 AM
  #127
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
ofcours we didn't stop there.
shopped around ad hawksthirdgen for the small touches on the car.
Old 05-15-2013, 08:35 AM
  #128
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 05-15-2013, 08:39 AM
  #129
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
old
new
old
new
we also changed the inner en outer door handles brand new dorman units
and even the tailights are new.
Old 06-20-2013, 12:59 PM
  #130
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 06-20-2013, 01:01 PM
  #131
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 06-20-2013, 01:03 PM
  #132
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 06-20-2013, 01:04 PM
  #133
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Old 10-20-2014, 12:57 PM
  #134
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
20141011.zip
logging 2014
File Type: zip
Old 04-18-2015, 12:47 PM
  #135
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
actually a long time since I updated this Topic....
anyway...
I'm back driving this car on a weekly basis. ( got a company car for work etc ) and I use this car on sondays etc or whenever it wheater is beautifull.
Specs of the car
rebuild 3.4 V6
comp cams 264H cam kit
pacesetter headers
empty cat
dynomax VT muffler
Y-pipe intake from a 2.8 camaro
-chipping by me
rebuild transmission
-transgo senior shift kit ( ATP )
-medium transmission cooler
-prothane motion black poly rubbers
-34mm front 23mm rear swaybar
-82-92 front koni struts
-93-02 rear koni shocks
to do
-install steering house cooler ( in box at home )
-install new steel brake and fuel lines ( ordered at Hawks )
-rebuild new airconditioning system ( everything is in boxes atm ) to R134A
long term planning
-subframe connectors ( got umi ones ) but my inspections do not approve of this modification so I need to wait....
- truetrac rear ( undecided between 3.23 and 3.73 )
BIG maybe
-1LE brakes ?
- PBR rear ?
Old 05-22-2020, 01:13 PM
  #136
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
my God, I just noticed I havent posted here since 2013....
whew, a lot has changed over the last 7 years.
except the car getting a complete new paintjob, the car also got.
new brakes.
jeggsters bolt in subframe connectors?
97camaro white vinyl seats.
koni shocks front and rear.
detroit truetrac limited slip differnetial.
powerstop disc brakes and pads.
new steeringgear.
astro steering shaft.
airconditioning redone for 134a
double fan setup with low and high speed.
new audio system existing of
sony xav-ax3005db radio. ( android auto + apple carplay)
with a usb connection in the center console.
cerwin vega V1100.5 amplifier
cerwin vega HED 5.25 speakers in the front
cerwin vega VEGA V469 speakers in the rear.
cerwin vega VEGA 8" subwoofer in the spare wheel compartment in a sealed enclosure.
new hella headlights with an extra parklight.
the car also got 2 brothers to keep it company.
and I also took the car on a roadtrip a couple of times to spain.
Old 05-22-2020, 10:04 PM
  #137
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That's a fun mountain road!
Old 05-23-2020, 01:05 AM
  #138
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
its gi-682. A coastroad in the north of spain.
I love it.
its 1 of those roads I always try to drive on holiday
Old 03-03-2021, 10:39 AM
  #139
Want a title? Post!
SanderVDW's Avatar
Car: Jeep Renegade and 83 Camaro
Engine: V6 2.8
Transmission: 200c
Another Guy from Belgium 👌👌
Just bought an 83
Old 03-03-2021, 10:47 AM
  #140
Want a title? Post!
SanderVDW's Avatar
Engine: V6 2.8
Transmission: 200c
Another guy from Belgium 👌👌
I just got my first US car. An 83 V6
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
84z96L31vortec
08-20-2017 12:16 AM
BADNBLK
11-16-2016 09:12 AM
porkenstein
Convertibles
08-31-2015 12:54 PM
Quick Reply: 91 camaro RS from belgium
