My engine bay (Start to finish) thread
Subscribe
Dec 6, 2009 | 02:00 PM
  #201
Re: My engine bay (Start to finish) thread
Quote: Hey FueledSoul--They say "a picture is worth a thousand words"...
I for one would be beating down your door when this is finished and hand you mine!! I'd want you to re-wire // route the wires & build me some SFCs then..............
Does TGO have a cover car..?..
Quote: FueledSoul, you do incredible work, I really enjoy watching your progress. Hopefully mine will turn out 1/2 as nice as yours is. Beautiful job!!!!!
Thanks Anything you put work and time into will turn out nice sometimes its more about having patience
Quote: Any update, I just got done reading the whole thread about 2 hrs for both
updating right now
Quote: may i ask wich march pulley set you are use?
i was looking for thinking almost the same setup
i have found a march number that i think that i must have 22007-09
i like the silver coating (low cost custom style) but i can`t find it were to buy it!
i think i need that part nr because i think i have the saginaw press fit SP pulley
i have a original sepentine setup from a 88 camaro!
do you now wich one i need!
thanks dennis ( nice engine bay )
The one your looking for is http://www.summitracing.com/parts/MCH-22021-09/ if your running a belt driving water pump
Quote: Very nice, very inspiring!
i have a couple question tho, did you get rid of the bulkhead connector?? where did you run the wires for the headlights and turn signals and stuff.
Great job on everything, this is immaculate
yea i got rid of the bulkhead, headlight wires etc all post a pic shortly showing where i routed them.
Reply 0
Dec 6, 2009 | 02:33 PM
  #202
So after getting the engine harness done it was time to start on the board i used a sheet of 14ga aluminum and had drawn up some dimension and had a friend brake it since i don't have a brake. started with the fuse blocks and relays. i decided i didn't need the painless anymore since i already this far and we have been redoing the entire cars wiring anyway.
Reply 0
Dec 6, 2009 | 02:36 PM
  #203
Reply 0
Dec 6, 2009 | 02:50 PM
  #204
I started to finish painting the firewall and the rest of the inside. i also decided not to block off or weld a plate in place of the fresh air flap, instead i utilized it for a pressure relief to keep my gaskets from blowing out when i shut the doors or hatch. i would have left the vacuum diaphragm but it ended up interfering with the fuse board i had made up so i took it out and ran a spring.
Reply 0
Dec 6, 2009 | 03:01 PM
  #205
I forgot to add to when i was coming up with the board i also wanted to bolt my msd to it so i had it wrap in. i also finished making a fibber glass excess panel for my tranny lines.
Reply 0
Dec 6, 2009 | 03:08 PM
  #206
Wires still look messy but it will be better looking then any factory 80's wiring. Heres how i ran the headlight etc wires.
Reply 0
Dec 6, 2009 | 03:29 PM
  #207
I got it running this summer but had some AFR issues which later turned out to be dirt in the carb i completely rebuilt it with in the last month also picked up a ultrasonic cleaner which help clean it all up even all orifices and cut rebuilding times down. i turned the fuel pump on and had gas from the front lines pumping into a shop rag and i got a lot of particles in the rag i don't know yet if its in just the lines that have stuff in them or somethings going on in the tank so im just going to cycle the fuel and add new gas and see if i still get anything coming out, im running a factory in-line fuel filter too so will see.
I still have to make a radiator hose, brackets for the carb and a braided kick down, finish the radiator top plate and im still stuck on what to do brakes I.E booster and master, but. . .
For your entertainment heres some videos
Note: The video and sound isn't greatest quality.
Reply 0
Dec 7, 2009 | 10:09 PM
  #208
wow what a wire tuck!!!! awsome job
im just curious to know how you are distributing your + power. I cant seem to make it look nice. Is that thick black wire your positive from the battery or starter?
Keep up the amazing work.
Reply 0
Dec 8, 2009 | 05:28 AM
  #209
good to see you got it running!
Reply 0
Dec 9, 2009 | 10:44 AM
  #210
Since you have allready come this far with your build, I would recommend using a pre-fabbed locking metal access panel (hinged with a latch) for your trans line access.
Summit and Jegs carry them in stock....
Reply 0
Dec 10, 2009 | 07:22 PM
  #211
i move the bat to the rear of the car i have a main power wire going to the front of that panel its just not hooked up in that pic, the one you see goes to the starter. thanks
Quote: good to see you got it running!
Quote: Since you have allready come this far with your build, I would recommend using a pre-fabbed locking metal access panel (hinged with a latch) for your trans line access.
its already cut and the fibber glass one was molded to that area fits perfact, just going to used RTV it hold it in place and keep it sealed. never see it undercarpet
Reply 0
Dec 12, 2009 | 01:24 PM
  #212
Looking great man, I also shaved my firewall, and smooted out alot and filled all holes.
Close up
Reply 0
Dec 12, 2009 | 10:42 PM
  #213
Nice job curtiszyz How old are you again? arent you 17? Great work
Reply 0
Dec 13, 2009 | 02:36 PM
  #214
Quote: Nice job curtiszyz How old are you again? arent you 17? Great work
Thanks, and yes I am.
Reply 0
Jan 1, 2010 | 01:35 PM
  #215
dont know how i missed this thread.
pretty slick stuff!
any more progress on your transmission lines cover?
Reply 0
Jan 1, 2010 | 08:11 PM
  #216
LOL and I thought I was making progress, great looking bays, both of you.
Reply 0
Jan 2, 2010 | 01:35 AM
  #217
Quote: Looking great man, I also shaved my firewall, and smooted out alot and filled all holes.
Thanks. yours looks nice! too. what color is that?
Reply 0
Jan 2, 2010 | 01:36 AM
  #218
Quote: dont know how i missed this thread.
pretty slick stuff!
the covers done i just needed to run a bead rtv around it and snap it in place
Reply 0
Jan 2, 2010 | 03:57 PM
  #219
Quote: Thanks. yours looks nice! too. what color is that?
Thanks! Its called Deep Water Pearl. It is used on the 09 Challengers and what not. Its a Chrysler color.
Reply 0
Feb 27, 2010 | 08:49 AM
  #220
any updates?
Reply 0
Feb 27, 2010 | 09:26 AM
  #221
Well i finally decided on what to run for a brake assist.
Brakes:
i bought a LT1 booster and LS1 master cylinder. i just test fitted them on the car. the booster tucks closer to the fire wall and its appearance is much cleaner, i still have to prep it and put on some color, im painting it the same color as the car so it will blend in with the bay a bit more. i will use the stock prop valve with the ls1 master at least that's the plan. the master cylinder is much smaller and more compacted then the 3rdgen master so all in all im much happier plus i gained some brake performance going with a 1" bore ls1 master cylinder.
Carb:
I was having problems with the flimsy crab bracket, im going to order a bracket from loker, i did pick up a braided stainless steel TV cable since its the only one that can be used with that bracket.
Im also going to have to add a fuel fillter close to the carb, i already have one thats inline under the car but im picking up some junk in the carb which caused some fuel problems and flooding i rebuilt the carb entirety a few months back so its all ready to go for round 2. so i might have to re-do some lines and run things a bit differently now.
Other:
I have to paint the top radiator plate and bolt that in, i have to find some clips for the hood release. i still have to mount the 4thgen washer bottle and then find a place to bolt the aftermarket over flow and some other miscellaneous stuff. engine related i also have to make a y-pipe and hook up my exhaust system. then im pretty much done other then doing some small detail work and touch ups and a wash.
Oh and im about 75% done with wiring up the whole entire car thanks to my dad
Reply 0
Feb 27, 2010 | 10:05 AM
  #222
Good to hear from ya FueledSoul!!!
Interesting use for brake booster & master cylinder....
Amazing work...Thanks for adding to inspiration...
Reply 0
Feb 27, 2010 | 11:29 AM
  #223
FueledSoul i have send you a PM
dennis
Reply 0
Mar 7, 2010 | 09:57 AM
  #224
Quote: Well i finally decided on what to run for a brake assist.
Brakes:
Cool idea
Reply 0
Mar 7, 2010 | 10:10 AM
  #225
we need pictures lol
hows the wiring coming along?
Reply 0
Mar 7, 2010 | 10:31 PM
  #226
Quote: FueledSoul i have send you a PM
dennis
PM sent back
Quote: Cool idea
If your talking about the brake setup i might have time to take some comparison pics and post them tomorrow. still haven't got any of it hooked up on the car yet. as far as wiring we have to wire in the door locks, power windows, hatch pull down and wires for the curiosity lights. then its all done for the most part but we'll still have to test everything before i loom it.
Reply 0
Mar 8, 2010 | 09:18 PM
  #227
Heres some pics
Reply 0
Mar 8, 2010 | 09:20 PM
  #228
4thgen and 3rdgen booster compare
Reply 0
Mar 8, 2010 | 09:21 PM
  #229
LS1 master with 3rdgen prob valve
Reply 0
Mar 8, 2010 | 09:25 PM
  #230
Definitely remembering this when I clean out my bay and do my brake setup. Awesome comparison.
Reply 0
Mar 8, 2010 | 09:30 PM
  #231
Have you considered hydroboost? Alot smaller than that bulky vacuum booster.
Reply 0
Mar 8, 2010 | 09:36 PM
  #232
Something like this, in which they have a bolt in application for us, gets rid of the big ole' brake booster
http://www.hydratechbraking.com/GM_3rdgenF_Body.html
Reply 0
Mar 8, 2010 | 09:52 PM
  #233
or even a hydroboost off a astrovan for the budget minded. Eventually I'll go that route when the engine bay is ready for painting and such.
Reply 0
Mar 10, 2010 | 08:40 PM
  #234
Iv looked into running hydro-boost, pass. iv looked into everything. . . over a year this is what i ended up with its cheap and better looking then the 3rdgen master and booster. i would love to dump the booster and run manual brakes and really clean up the bay but this is going to be driven on the street
Reply 0
Mar 10, 2010 | 09:22 PM
  #235
Good job, you've inspired me.
Reply 0
Mar 11, 2010 | 10:14 PM
  #236
thanks
Reply 0
Mar 11, 2010 | 10:17 PM
  #237
I worked on the prop valve tonight cleaned it put it back together and semi polished it. . .
Reply 0
May 29, 2010 | 05:51 AM
  #238
I'm at the same thing right now, nice work man!!
Quote: Wires still look messy but it will be better looking then any factory 80's wiring. Heres how i ran the headlight etc wires.
Reply 0
May 29, 2010 | 12:23 PM
  #239
Wow its been a long time since I've been to this thread and wow, what an inspiration for me to want to at least work on my wiring harness and fix some of the wires that have been cut and splices before I got the car. Great job!!
Reply 0
Jun 3, 2010 | 02:07 PM
  #240
So how goes the progress Soul, we haven't heard from you in here for almost a year!
Reply 0
Jun 3, 2010 | 02:44 PM
  #241
I'm glad I looked at this thread. I think I need a new booster anyways and really wanted one that sat just a little farther back than the stock one. The tip of my master hits my Spohn strut mount and only lets me set the camber so far in.
Reply 0
Jun 10, 2010 | 08:59 AM
  #242
Wow, great thread! I was looking for how-to's about cleaning the engine bay up...but I don't think I'm ready to rip the motor out and respray it just yet. LoL! I just wanted to clean up the existing bay as there is so much grease and crap, and it's a white car, so it's filthy. Someday I hope to have an engine bay as clean as yours. Great job!
Reply 0
Aug 18, 2010 | 04:29 AM
  #243
How did the car turn out? Did you get it finished?
Reply 0
Aug 20, 2010 | 01:58 PM
  #244
Thanks for all the comments and complements guys! Progress has been some what slow on the bay, iv been busy busting out the body panels, here's whats going on with that
https://www.thirdgen.org/forums/auto...ml#post4647632
Here is some pics of the booster and other parts i installed into the bay.
its not much.
Drilled out and mounted my secondary fan control box
Got some peaces in primmer painted
Reply 0
Aug 20, 2010 | 02:01 PM
  #245
Here is some crappy camera phone pics, sorry for the quality, hope to get some better ones when im done with everything
Reply 0
Aug 20, 2010 | 03:13 PM
  #246
Ah I didn't know you'd started another thread, I like your door handles lol. The engine bay looks amazing, and I really like that color.
Reply 0
Aug 22, 2010 | 10:18 PM
  #247
thanks man
Reply 0
Aug 22, 2010 | 10:32 PM
  #248
Sweet man, I'll have to come down to the cities sometime and check the car out when it's done...I'm just going through your body work thread right now.
Reply 0
Aug 23, 2010 | 07:44 PM
  #249
WOW!
Reply 0
Aug 23, 2010 | 08:04 PM
  #250
That looks great!
Reply 0
