My engine bay (Start to finish) thread
Old Nov 19, 2008 | 09:52 PM
  #51
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: My Camaro (Start to finsh) thread
Thanks guys
Old Nov 19, 2008 | 10:22 PM
  #52
Curtisyz54's Avatar
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
Originally Posted by FueledSoul
Its time consuming when you want things perfect
yes it is.
Old Nov 20, 2008 | 01:45 PM
  #53
rwdtech's Avatar
Car: 1991 Z28 (sold)
no, its time consuming when you have extreme ADD like you do lol
Old Nov 20, 2008 | 06:14 PM
  #54
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
You say it like its a bad thing...
Havent visited these forums as frequently as I used to (due to new car, new problems, the works), and cant see how when there's work like this going on HERE.
So, anything new...er? Please say yes...
Old Nov 25, 2008 | 12:36 AM
  #55
allenfre's Avatar
Re: My engine bay (Start to finish) thread
I decided to do my entire engine bay to make it look nice. Here is about what I started with, the guy i bought the car from swap in a TBI engine with the worst wiring job i have ever seen. i cleaned up most the wiring, swap to a carb setup added a few bolt on's and that was it. the things that bother me the most is an unclean engine bay and undercarriage of a car. i was always to embarrassed to open my hood
Degrease and power washed
This is what a leaky master cylinder does
Hand sanding really sucks
Patchs for the firewall
Whoa I can see the stressing job of untangling those wiring all over his hood. It goes in all directions. I probably quit the project in the middle of this process.
Old Nov 25, 2008 | 10:38 PM
  #56
FueledSoul's Avatar
All i really need now is to get a new starter!
I used a starter off a lt1 car it pooped out so im going to buy a new one with a warranty. the other things that i need to do is some wiring and making sure both fans work im running my own dual fan setup which all post later in this thread. its really just down to tuning the carb and timing and some other small ods and ends like fabing up a radiator hose out of stainless and the top radiator peace i also need to find a over flow and whipper bottle and im ditching the valve covers that are currently on there. i also have to bolt in the booster and all that kinds of stuff the engine bay hasn't been washed since after the buffing so it maybe a tad dirty but all leave you with some pics anyway for your enjoyment. . .
Old Nov 26, 2008 | 07:03 PM
  #57
allenfre's Avatar
Another Now that's way different already. For how long did it took you to come up with this man?
Old Nov 27, 2008 | 05:47 PM
  #58
FueledSoul's Avatar
the idea or the work?
Old Nov 27, 2008 | 09:31 PM
  #59
Curtisyz54's Avatar
Both.
Beautiful man, Is that the same color GM used on like the 02 camaros?
Old Nov 27, 2008 | 09:46 PM
  #60
hotrod16105's Avatar
Car: 1988 Firebird Formula 350
Axle/Gears: BW 3.27
That is a beautiful engine compartment. I spent a winter on mine and its nowhere near as nice. Great work.
Here is a pic of mine:
Old Nov 27, 2008 | 11:13 PM
  #61
FueledSoul's Avatar
Originally Posted by Curtisyz54
Both.
In all honesty i just wanted a matching bay to the exterior. I never liked half-assing things so once i started to pull the wires and gearbox there was no turning back
i decided to take my time and really make it look great.
iv had this idea in on my mind for a long time. its a close color to that of the 02 birds and Camaros but its not metallic
Old Nov 27, 2008 | 11:18 PM
  #62
FueledSoul's Avatar
Wow your is very nice neat and clean! i like how you painted the strut plates, booster a/c delete box blans together very well with the rest of the bay - did you paint your overflow?
Old Nov 27, 2008 | 11:31 PM
  #63
Axle/Gears: BW 3.27
Thanks. I still have to clean up that wiring mess in the corner of the firewall on the drivers side. I put a new overflow bottle in but the white just didn't look good with everything else so i sprayed it with some trim black. I still have to get a new washer bottle which will also be black.
Old Nov 28, 2008 | 03:30 AM
  #64
wjiroc86's Avatar
Car: 1989 RS
Engine: 305 tbi, junk, freakin slow!
Transmission: 700r4... holds up =]
That bay looks amazing! everything looks so clean i want mine to look like that!
Good job man.
Old Nov 30, 2008 | 12:45 AM
  #65
FueledSoul's Avatar
If anyone wants to know whats currently going on now check out this -
https://www.thirdgen.org/forums/body...-up-start.html
other wise heres a few more pics
Old Nov 30, 2008 | 12:54 AM
  #66
FueledSoul's Avatar
I've been trying to decide on these 2 sets of valve covers
Here's a slight variation of the ones above
Old Nov 30, 2008 | 09:04 AM
  #67
ssean92's Avatar
Car: sold
You have done a great job on this car........
Old Dec 1, 2008 | 12:32 PM
  #68
Camaroguy6984's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI L03
Transmission: TH700R4 Corvette servo
Axle/Gears: 10Bolt 2.73
I would say go with the first ones since you obviously like things smoothed out, I think the welds on the other ones would prob. bug you and end up going with the first choice anyway. I do think the welded ones look bad @$$ but for the look you are going for I'd stick with the smoothed look.
Old Dec 1, 2008 | 04:42 PM
  #69
Curtisyz54's Avatar
Old Dec 1, 2008 | 05:37 PM
  #70
FueledSoul's Avatar
yea there nice iv been kinda leaning towards the middle ones i posted if i don't like the look of the beads on the covers i can grind them down so i dunno i might just buy both then return the one im not using
Old Dec 2, 2008 | 03:19 PM
  #71
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
The top ones look like the ones I bought, which are IIRC 1/4" - 1/2" taller, allowing for more room for bigger cams and such...ya know.
I also bought FelPro cork valve cover gaskets, which allow for another 1/4" of clearance...so all in all Ill be ready for a ncie big cam setup.
P.S. I have R&M's wire loom on top along with K&N breather and PVC...cant wait to get back into my camaro...
Old Dec 2, 2008 | 03:39 PM
  #72
Curtisyz54's Avatar
yeah personaly for me I like the 2nd ones, but I dont like the center bolt hold downs, I like them on the side.
Old Dec 2, 2008 | 03:42 PM
  #73
tgscooter's Avatar
Car: 1985 Pontiac Trans Am
Engine: 5.7L LS1 FI
Axle/Gears: 3.23 factory 9 bolt
I'd say the top ones would look the best. They would compliment your headers as well as your polished accessory mounts.
But they all look sweet!
Old Dec 2, 2008 | 05:04 PM
  #74
sadler's Avatar
Car: 1988 Iroc-Z
Engine: 5.7l 350 TPI
Transmission: 700R4 Auto
Axle/Gears: 3.43 posi
There is no smiley for jaw to the floor! Do you just have the bare bones on there to get it that clean?
Old Dec 2, 2008 | 05:36 PM
  #75
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
If the top valve covers are the tall ones that is what I have on my 87 bird, I like them alot nice and strong no leaks at all. I have also recieved a number of compliments about them.
Old Dec 2, 2008 | 06:43 PM
  #76
FueledSoul's Avatar
can you post some pics? it be nice to visually see a set on a motor
Old Dec 2, 2008 | 07:49 PM
  #77
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Just noticed the valvecovers. They look great man at first i thought it was just reflecting the blue from everything else.
Old Dec 2, 2008 | 09:51 PM
  #78
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
TransDapt?
Old Dec 3, 2008 | 12:46 AM
  #79
FueledSoul's Avatar
so i found a semi front pic of the middle ones. . .
not really digging the "front of the house" look to these
i can visualizes what the front would look like on the other ones... so i think im going to end up with 2 different sets and once i get them all try them both out and take some pics then decide on what whats are staying with the engine
Old Dec 13, 2008 | 08:07 PM
  #80
FueledSoul's Avatar
Heres my fan setup i talked about earlier in my posts. i
came up with dimensions so i could adapt it on a stock aluminum radiator i had a buddy of my brake a 16ga sheet for me. . . after that i started to look for a set of fans i went with some dual 12" fans that only draw 6 Amps and move 1600 CFM so basically combing both equals 3200 CFM thats a lot of air after i got my fans i had to mock up where i wanted them and where they could go i had to move one up so it wouldn't interfere with the gearbox i planed on off setting them anyways then i layed down some circles and have a close family friend plasma cut some really perfect round holes - then i used a nut surt
so i could bolt the fans to the plate and take them off when ever i wanted too heres some pics - this fan setup is extremely thin and light weight it weighs less then a single 3rdgen fan alone!
i wet sanded it and then hand polished it i will have to go back over it maybe one more time till im satisfied with it
i will post a link to compare all stock 3rdgen and 4thgen eclectic fan setups Vs my own later
just for fun heres a comparison with a can of pop
Last edited by FueledSoul; Dec 13, 2008 at 08:11 PM. Reason: Automerged Doublepost
Old Dec 13, 2008 | 08:27 PM
  #81
FueledSoul's Avatar
i will probably place a few orders this weekend for valve covers and a new starter so i can get going on other things on the engine
Old Dec 13, 2008 | 08:52 PM
  #82
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Very nice!!!
What kind of fans are you using (as in brand)?
Old Dec 14, 2008 | 09:40 AM
  #83
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
What starter are you going for?
Originally Posted by The Project
Very nice!!!
They look like they could be flex-a-lite series fans...which has a thirdgen drop in radiator system for $900, but isnt exactly what he has.
Old Dec 14, 2008 | 09:52 AM
  #84
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
will someone pull the plug on this thread. its makes me ill looking at it. i keep drooling all over my clothes and the wife is getting mad. she thinks i would be better looking at ****, at least she would get someting out of that.
you are a perfectionist as are some of those that are posting here too.
you are all making the 3rd gen better than the factory did, and darn better looking too.
Old Dec 14, 2008 | 07:31 PM
  #85
fun Pain's Avatar
Transmission: 4l80e
I now have a big turbo in the way so hear is a N/A (older) pic
and an older posting of pic's with those
https://www.thirdgen.org/forums/alte...etup-pics.html
Old Dec 17, 2008 | 05:27 PM
  #86
Raiderfan's Avatar
Car: '92
FueledSoul you have done a great job so far! 2 thumbs up!!!
Old Dec 20, 2008 | 02:28 PM
  #87
FueledSoul's Avatar
just a LT1 starter there small, light and have a lot of torque
Old Dec 20, 2008 | 03:35 PM
  #88
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
A can of pop. lol We call it coke down here in Houston. good job on the build, been following it for a while.
Old Jan 2, 2009 | 11:53 PM
  #89
FueledSoul's Avatar
Another peace. . .
I had to cut the sides off because the tabs on the raider sit a bit higher then the top of the radiator support so all hopefully all i need to do is box the sides in on both ends of the peace . . .
Old Jan 3, 2009 | 03:04 AM
  #90
rwdtech's Avatar
dont u want as much airflow thru the radiator as possible? why did u block the areas surrounding the fans off?
Old Jan 3, 2009 | 03:29 AM
  #91
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
I love the clean, sanitized look of your engine bay and you obviously have an eye for detail, but for god's sake, can you perhaps check out your local community college and take some courses in English 101 or at least basic SPELLING? We Camaro owners have enough stereotypes to deal with...
Old Jan 3, 2009 | 03:09 PM
  #92
FueledSoul's Avatar
Having fans with out a shroud is very inefficient your not reaping the full benefit of the fans. would your toilet plunger work well with huge holes in it?
well you can stereotype me all you want, i have a learning disability (so does bill gates) - spelling and grammar is just one of my weak points
Old Jan 3, 2009 | 04:02 PM
  #93
Demon355's Avatar
Looks badass FueledSoul, I love the fan setup. It's nice to see others out there not just buying stuff and throwing it in their car and calling it a "mod". Seeing someone actually make something for a purpose is sick.
Old Jan 3, 2009 | 05:16 PM
  #94
FueledSoul's Avatar
Old Jan 3, 2009 | 10:13 PM
  #95
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
Actually I don't see a problem with his spelling or grammar at all in this thread. Maybe in a few places but at least he uses punctuation in his sentences, instead of a full run on. Don't bash him, At least we could read his stuff, I mean who cares what people think about his grammar on a forum.
Old Jan 16, 2009 | 08:20 PM
  #96
tgscooter's Avatar
Engine: 5.7L LS1 FI
Tru Dat, I reck'n Sony summ'd it up perddy good. lol.
FueledSoul, you have done an incredible job. Well done, sir.
Also, life's way too short to worry about stereotypes. (That reminds me, I need to go groom my ******...)
Old Jan 21, 2009 | 09:18 PM
  #97
paveuk's Avatar
Thats what i'm sort of in the process of doing to mine. but what are your plans for your car i see you sealed up the big hole for the a/c and heater core. You don't plan to run heat and a/c? or did you have another set-up?
Old Jan 21, 2009 | 09:37 PM
  #98
FueledSoul's Avatar
Sweet! Plans for the car in terms of driving or just the HAVC? Well i don't plan on running any heat or A/C hences the smooth firewall. I took out everything related. i do plan on fabricating some type of fan with a heated element to at least have some type of defrost and some form of heat even if it will be minimum. . . but im not really to that point yet
Old Jan 22, 2009 | 05:30 PM
  #99
FueledSoul's Avatar
well i finally bought and received my valve covers, im going to put them on the engine tonight take some pics but for now here you go....
  #100
FueledSoul's Avatar
if i end up using the fabbed covers im going to have to knock down the shitty tig welds and smooth them out
Last edited by FueledSoul; Jan 22, 2009 at 05:32 PM. Reason: Automerged Doublepost
