Thoughts, on new setup pics HSR
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
New setup is on and in the car...
HSR powder coated "almost chrome"
a bunch of polished alum asse.
268 Nitrous HP cam
36 pound injectors
ported heads, stainless valves, screw in studs
alum, roller rockers 1.6
alot of little things....
268 Nitrous HP cam
36 pound injectors
Transmission: 4l80e
one of those honda civic, hillbilly go faster pieces, by some weird brand...from autozone (from the MAF to the 1000cfm K&N), and from the MAF to the throttle body just a polished alum. 90...from a local performance store...
All put together with stainless pipe clamps from Home deee- POT.....
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Originally Posted by fun Pain
nothing huh...not a you suck or that look like crap...huh
You suck.
Seriously, that really looks pretty good
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Looks nice! Almost ready for a car show! You could use some of the "Made For You" wire looms for your plug wires. It'll help clean it up some more.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
how do you like that cam? im looking into buying that same one for my motor, its a 385 cid with HSR and a 150 shot as well, do you have any sound clips or video of it? thanks
Brandon
Brandon
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'd suggest putting a PCV valve in that empty hole in the valve cover
Transmission: 4l80e
Sorry for the delayed answers...(wasn't notified)
WheelsUp84z: and anyone else that wants to know what happen to the cam...!! follow the link
cc306 - CamaroZ28.Com Message Board
pretty big>>>OOPS
BOTTLEDZr28: I got the coating done at Street Workz... it is right down the street from the Jeg's store on 110b exit... I live in Ohio, I can't find their web site...
Poppa Chubby: the link above should tell you why I don't have anytimes or videos' yet....
and as a new follow up on this she is now sporting
after talking and getting taken care of by a great crew and warrenty dept at
Comp Cams - Performance Camshafts, Valvetrain, & Much More
I bought all Comp products..
08-306-12 290HR-12 CC306 cam
290/307adv 230/244@.5 .510/.540lft w/1.5 112°lobesep
987-16 Dual Springs/ 10' locks/Tit retainers
Hi-tech Chromoly Push rods
Comp double roller chain
the heads are back at the machine shop right now, needed to lower the valve guides and widen the spring seats for 1.430 Dual springs.... I also went back through the ports with a new carbide and sanding rolls in the exhaust sides
pretty big>>>OOPS
CarGuyDennis
137
Dec 6, 2016 11:02 PM
