My New 86' IROC-Z (Sig thread + lots of pics)
well i got it a couple days ago. but i been busy lol.
Well heres the story, i bought a 85 silverado custom deluxe for 500$ it would run but it needed work to drive, so i traded straight-up for a 86 iroc-z camaro. it has a 350 and a TH350 from a 87 chevy 2500 model van. when i got it the guy had put a quadrajet(?) intake with a holly 4barrel 600cfm. but he said that all the orginal wiring for the TPI was there, so i got lucky and found a TPI setup at my local junkyard in great condition. the past couple days i been working on getting the TPI setup on. heres some pics ( in order)
Re: My New 86' IROC-Z (Sig thread + lots of pics)
got it home & decided i wanted matching valve covers... so i got to work..
nasty !
let them soak for a few min...
then after about an hour of scrubbing & prepping for paint, got one done..
wallah!
not to throw it on(sort of) wont fix until i get the front brackets off.
but just a quick test...
still a work in progress ill update with more pics and questions soon.
thanks for looking
nasty !
wallah!
thanks for looking
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
lol i have washed parts in the bath tub too my girl for some reason gets mad though. Looks good so far
well today i needed to get the front bracket setup off because it wont work with the TPI
so i got to work..about 2 hours later( broken bolt)
i got it
now to look inside... see something missing??
now to test fit the intake... LIKE A GLOVE !
Cant you see the joy?
now to clean up this mess lol
more tomarro...
i got it
more tomarro...
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
looks like you got a good deal. And looks like a cool car. Good work on the TPI set up.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
There are 2 th350's, a short tail and a long tail. I'm not sure what they measure exactly tho, take a pic and we should be able to tell you which you have. Do you already have a driveshaft for it? Is the torque arm attached properly? Also did you get the fuel lines also? Looks like you need a new o2 sensor and make sure you get yourself a knock sensor for a 350, it'll run like poop with a 305 knock sensor. It still won't be as fast as it would have with that carb on there but tpi setups look so much cooler
ok ill take a pic and show, yea i would of left the holley on it but it wasnt setup at all, nothing was hooked up or anything, besides the TPI looks better lol
There isn't anything missing from under the intake. That's where the spider tray would bolt up if you were running a factory roller cam setup, however you arn't you are running a flat tappet cam. If you wanted to swap to a roller cam in the future all you would need is the cam, lifters, spider tray, cam retainer, correct length pushrods, and the proper timing set. Edit: you could always go back to the junkyard and get all the roller cam parts from that donor car if the prices are cheap there, it will save you a lot of money and time in the future if you decide to convert. I wish I knew where that red donor car is.. I could use some body parts off of it if they were in decent shape
and i might get the cam from the other car, but whats the diffrence?
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Nice car....all she needs is a little love.
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
looks like a nice trade! goodluck
ambainb
Apr 25, 2016 09:21 PM
Linson
Aug 21, 2015 02:12 PM
. so im gonna need to find somebody to come help.
