I picked up some Camaro SS wheels
Old Aug 14, 2009 | 03:00 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I just picked up a set of Camaro SS wheels They aren't in the best condition though. They will need to be repainted. One tire has a nasty gash in the side wall and another has a chunk missing from the shoulder which I don't think would be safe to drive on. The wheels are 17x9" and the tires that came on them are 285/40/17 Nitto NT555's. At least two of them are decent with a little tread on them.
What was funny is that a couple of days ago I made up my mind that I wanted to get some different wheels and SS wheels were near the top of the list, so I hopped on Craigslist to see if anyone was parting out any cars and BAM! the first listing was for some SS wheels for $200. Talk about good timing.
There is some curb rash and a couple iffy slight bends in the outer lip so hopefully they all hold air. If so, then I'll be one happy camper. If they don't, I just found out one my friends has a couple sets of SS wheels so I wont be SOL. Either way I think they'll compliment my Ground Control kit nicely. I was also thinking of painting these either gunmetal, silver or satin black. What do you think?
I now need some wheel adapters! If anyone has any they are looking to sell PM me. I was also debating about what size I would want to get. Everyone keeps saying 2" all around but I want my wheels to be nice and flush with the fender lip yet still not rub when I lower my car 2+". Any suggestions?
I tried cleaning these as best I could. Looks like I'll be getting one of those Mothers powerball.
Old Aug 14, 2009 | 09:11 PM
keith_AE2010's Avatar
Car: 98 Camaro, 89 Camaro RS
Engine: 3.8l & 2.8l V6
Transmission: 4l60e & T5
Axle/Gears: Open 3.08 & lsd 3.42
Re: I picked up some Camaro SS wheels
Man, I want a set of those for my 98. Paint them gunmetal.
Old Aug 16, 2009 | 04:44 PM
longmire92RS's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: Stock Automatic
Axle/Gears: Stock
Good buy for 200 bucks dude!! The SS wheels are one of three possible options im trying to decide on. The other two are The ZR1's in Hyper Black, or a set of ZO6's in Silver.
As far as what color to go...if you go straight satin black..you wont have much contrast with a black car. Atleast it looks black in your sig. I found this pic of the centers painted black. You may like it having a black car, and it just might look good, without having toooo much black.
Or you could paint them a nice and clean silver, and get a set of black center caps...along with a billet grill and a two inch drop...that would clean.
Just some ideas for ya to ponder on.
Old Aug 17, 2009 | 10:35 AM
1Aauto's Avatar
Former Sponsor
Those rims should look great.
Old Aug 18, 2009 | 07:09 AM
DBLTKE's Avatar
Engine: LB9, LB9
The above picture looks great. I am also considering painting just the face black or gunmetal and leaving the sides of the spokes silver.
Old Aug 19, 2009 | 01:12 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
definitely 2" spacers. sits nice and flush with no rubbing issues. that's what i have. look a link in sig for many many more pics. i also have eibach springs lowered it about 1 1/2 in up from and 1 rear. i might get bored one of these days and paint my spokes black. good deal by the way.
Old Aug 19, 2009 | 04:16 PM
DBLTKE's Avatar
Engine: LB9, LB9
You know Dave, your car was what made me decide to get SS wheels.
Old Sep 15, 2009 | 10:43 PM
DBLTKE's Avatar
Engine: LB9, LB9
So I ended up buying two new tires through America's Tire Co. First I tried ordering through their website and price matching onlinetires.com but I got an email back saying that they wouldn't price match them but would make me a offer at $145 per tire. So I went to the store in person and they price matched the online source without a problem.
I also received my wheel adapters yesterday, so you know what that means. I installed my SS wheels. It definitely didn't go as planned though. Apparently the center bore of the adapters were a few thousandths too small. I ended up using a Dremel, some grinding stone bits, a can of WD-40 and a few hours of my time to grind them down enough to squeeze them on, not something I'd want to do again. I wish there was a easier way.
Another problem I ran into occurred when I aired up my rear tires. I now know why I got these wheels so cheap. the right rear wheel wouldn't hold air. The inside lip was bent a little bit but enough to have a substantial air leak. after much of this , I broke out the sledge hammer and rubber mallet. After about 2 hours of continuous beating it now hold air at the recommended 34psi. If it ever starts leaking again I'll bring out the propane torch to heat it up slightly and have at it again so I'm crossing my fingers on this one.
So the front tires are now perfectly flush with the fenders. They only fit because of the negative camber that was a byproduct of the lowering I did. I had to take my fender liners out or else my tires would be sitting on them. Taking them out gave me more clearance to have vertical travel. I'm going to cut a portion of the old liner and place it back inside the well to prevent debris and water from traveling back towards the door hinges and possibly into the drivers compartment. I also definitely need to roll my fenders. I have less that a 1/4" before they rub on bums. The only place I noticed any rubbing turning lock to lock is on the battery tray. This is probably because I have taller than stock tires. I'll just give it the old BFH mod and call it good. The rears have no rubbing or clearance problems whatsoever so I have no work to do back there.
I have a hard time comprehending and calculating offset and such so does anyone know what offset and backspacing I effectively have now with the spacers? This setup is perfect in my eyes and would like to know what it equates to for future reference.
All in all I am extremely happy. Especially since everyone doubted that 285/40/17's would fit up front. I'm here to say they can.
Old Apr 4, 2010 | 03:19 PM
DBLTKE's Avatar
Engine: LB9, LB9
So I did the math and figured out what the effectlive offset is for a 17x9 wheel with a +46 offset with a 2" adapter. It works out to be a -4.5 offset and 4.3125" of back spacing.
Old Apr 4, 2010 | 04:22 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
go satin black.
10-spokes look better on 3rd gens.
Old Apr 7, 2010 | 01:25 AM
Car: 87 iroc
Engine: 410 sbc
so where are the pics?
Old Apr 16, 2010 | 05:03 AM
DBLTKE's Avatar
Engine: LB9, LB9
Old Apr 17, 2010 | 09:48 AM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
Those look just as nice as I have imagined they would on a 3rd gen. I found a chrome set in a junkyard that were flaking really, really bad. I figured I could get them pretty cheap, remove the chrome, and repaint them. That dude must of liked them better than I did cause he said he wanted $400. Two years later they were still sittin in the same place on the same car. But those look awesome combined with the drop in stance.
Old Apr 13, 2012 | 07:29 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Posting here so I can upload pictures of my wheels for others to reference. Originally I painted the wheels, but I ran into some issues with the person who helped me paint them so I decided to just powdercoat them gloss black. Took it to Superior Powdercoating and they should be done by the end of this week.
Old Apr 20, 2012 | 10:05 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Originally Posted by DBLTKE
Holy Crap! They look really nice! They give the car a whole new personality.. I've always believed our original wheels looked best, but wow.. Stone
Old Apr 23, 2012 | 01:15 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Skyler has since parted this car out (I got his gfx!), but another guy in our club is running these wheels (might even be the same ones). The black Z28 is Skyler's current car. Hope he doesn't mind me updating this thread.
Attached Thumbnails I picked up some Camaro SS wheels-dyno20124.jpg   I picked up some Camaro SS wheels-dyno20122.jpg
Old Apr 23, 2012 | 02:22 AM
DBLTKE's Avatar
Engine: LB9, LB9
Nope, I still have those wheels as well.
I just think the Y2K's flow better with the car, the fitment with the SS wheels were spot on though.
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
camaro71633
Sep 1, 2015 10:24 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
