Project NightMaro
Old Dec 21, 2010 | 10:20 PM
92RS_T-Top's Avatar
Car: 92 T-Top RS Camaro
Engine: 305 .30 over Mild RV Cam
Transmission: Auto 700R4
Project NightMaro
Well after talking to one of my remote control short course racing friends he menshoned he had a 92 RS T-Top Camaro he HAD to get rid of, I offered a deal and well ended up getting the car. Traded my rcs and $500 for this project car (not the cheap rcs eather)
Before I even had a chance to pick up the car it had the hood stolen, t-top bag stolen, and the headliner and headliner parts, along with the orginal keys!
Now the car is sittin in my barn 65 miles from where it was, it was dark when i got home and the next morning i went out to give the car a good looking over and see what i had got.
So far ive gotten, a bad title (hes fixing it had to file for lost title ext ext) 230,500 miles (YIKES!)
Color code Purple Haze... (and im half way assumeing on that as all the codes on the door are so faded that you can only make out a few little letters here n there.
Unknown if it is a heritage or not, it has had the back hatch replaced at one point (its not purple on the underside) it has the 25 AV badge that says RS instead of Camaro.. Still real lost on what this car truely is but I do know its a RS.
Also had power windows... key word HAD...
The car has been switched over to a carb, no clue why, but they did a DESENT... I stress that... DESENT job... well they got the correct stuff to do the change over but installing it they didnt do such a good job.
What I saw slightly frightened me..... Ok I lied.. it scared the crap out of me.
I'll post what it was in a second but on to the photos. I will try to downsize the photos as i go.
For starters, 65 miles with ALL, not 1, not 2 or even 3 on one wheel.. but ALL the lug nuts on ALL the wheels where finger tight!!! So I snugged them up because there getting replaced soon.
Free dog, please take it, lol i hate that dog.
Dose this look safe to you? Because I know its not lol, real red neck style of work on this car... but luckly no 2x4s or 2x6s like most backwoods camaros lol. Yes that is the fuel line if any of you where wondering... running right over the top of the alt, by the alt fan, and the fuel pressure regulator mounted to the freaking windshild washer fluid box!
Even SAFER!!! (i left these pictures larger to show what i was talking about.
Link to the rest of the photos (let me know if they work for you if not i'll upload them to photobucket instead of facebook)
Photo 1
Photo 2
Photo 3
Photo 4
Photo 5
Photo 6 <----Someone took a bite out of my seat lol
Photo 7 <----Toggel switch to lock the torque converter??? No clue what he was talking about
Old Dec 21, 2010 | 10:33 PM
AmorgetRS's Avatar
Re: Project NightMaro
All 1992 RS's said 25th Anniversary RS. It's the 91s that said "Camaro"
Old Dec 22, 2010 | 08:28 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
carb conversion....the only reason i can think of that they did that is that they were have issues with the TBI....but if changing things why go backwards?.....LS swap? lol
Old Dec 22, 2010 | 08:51 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Looks like you've got some fun ahead. Better to fix it than send it to a scrap yard. And didn't the 92 Camaro's have the third brake light on the inside of the window? If so that hatch is from an older car.
Old Dec 22, 2010 | 09:16 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Look at it this way...the body is in pretty good shape!
Old Dec 31, 2010 | 05:30 AM
DubyaSsixTA's Avatar
I believe the hatch came off an older car (87-90 I think), but still an excellent project car. Correct me if I'm wrong fellow members, but when switching to carb (more specifically, bypassing the computer), you have to make a switch to lock up the converter since the computer did it before. Best of luck with it and keep it rolling!
Old Dec 31, 2010 | 11:17 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
not too bad, how does it run? and I have an extra t top bag you can pm me about.
Old Dec 31, 2010 | 11:28 AM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
the TCC switch is a common cheap mod people do to get that effect of having a more built motor because often you can chirp the tires..... either way i would be happy with motor problems and not body that body looks straight
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Hey man my names Coltin and I live a bit north of you in camdenton, I have the hood off my 92 Z28 with out the blisters but it is primered and ready to be wet sanded and painted, a smog pump delete pulley, and a probably a few other parts laying around if you were interested. Just send me a PM, Im headed back up to St. Joseph in about two weeks for school but I have em here at my parents house. Just let me know
Old Dec 31, 2010 | 11:45 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Looks like a good starting point. Just needs some minor things.
To answer some of your questions:
1 - Yes, the third brake light on the 92's was mounted to the inside of the hatch at the top.
2 - Yes, when swapping to a carb with an automatic transmission the converter lockup will no longer function. The toggle switch on the dash will lock/unlock the converter. Assuming its wired correctly of course. You don't have to worry about the lockup function if you don't want to. It will cost you a few mpg on the highway, but I don't believe it will hurt the transmission.
3 - You'll want to move that throttle return spring in pic #1. Having it hooked on the vacuum line like that is a bad idea.
Old Dec 31, 2010 | 12:13 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I still haven't got the paypal from you for the hood and TTop bag, are you still wanting them?
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
