Rebirth of a 86 Iroc-z
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Hello all finally getting around to restoring my 86 irocz(yes its an iroc i ran the vin it came from van nuys) has ttops i bought it early last year from a kid that did a rattle can paint job
it has a 355 that seems like its been mildly built(she moves quick at wot) trans shifts good, the rear end is a posi but no longer locks together to spin both
it also has a back yard true dual exhaust system that hangs way to low but plans are to completely disassemble the body get it sanded and smoothed out and repainted a artic white, hood definetly needs replaced looking for cowl induction hood. Want to swap the seats for some nice 4th gens, ill replace all the gauges already add two on the piller but arent hooked up yet, side skirts will get replaced with some 91-92 rs ones, ive already modded some halo lights in place of two of the headlights. Future plans are hopefully by winter ill have the money for a 383 and new rear end but heres some pics as it sits now.
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: Rebirth of a 86 Iroc-z
Your IROC looks like a good platform for a restoration. Body looks straight.
Hey, do you honestly like the way the halo headlights look? IMO they look ridiculous and totally out of place. You dont have a bad looking car. I just hate modifications that look cheap or cheesy.
Good luck with your car!
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
I do like the halos not to keen on the shape of them i may try and mold them into the stock housings to make it seem original its defineltly different from other third gens and i get quite a few looks and compliements bout them but i also get some that say they dont look right but to each there own
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Body looks nice also and would look real good in a white. Good luck on the rebuild!
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
So didnt get much done today got the taillights and spoiler pulled off got some sanding done the taillights definetly need redone I'll post pics up tomorrow. GreenieG I looked into that I guess they did never noticed that but really doesn't matter as mine doesn't even work so I may delete it all together or move it to the top of the window not sure yet
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Got the spoiler prepped with primer, got side skirts off tomorrow going too pick up some side effects off a 91 rs. Got a lot of sanding done to ill post them when i get some taken, got the taillights restored heres the before and after photos of the taillights.
Before:
After:
Before:
After:
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Got the side skirts this morning passenger side is in rough condition not much can be done today due to snow i hate nebraska wheather but heres pics of the side skirt and car as it sits
This is what happens when u kick up gravel thinking mud flaps?
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
title says white but after pulling parts off and sanding some of them were red or black so the cars been put together with different parts then painted im taking it all apart and doing each individual part to make everything match
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Got the side skirts done and prepped checked fitment clearly ill have to drill new holes to get the 92s to fit correctly filled in the "rs" area to have a clean look im also thinking of smoothing out the rear bumber. Also got bored did some custom work on the grille what you guys think?
Engine: 4++,350 & 305 CIs
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Do u guys suggest maybe just finding a new hatch? Because I cant get it to align properly with the rear passenger quarter anyways so it sticks out a lil farther
I have done many of them, one just last week.
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Well i took a closer look and it seems that the previous owner put caulk in between the hatch piece and the glass ill get some pics taken but it looks like it be easier to just replace it with a correct camaro hatch
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Well no updates its been really cold out but heres what i was talking about with the hatch
I was able to remove some of it on the right side looks like moisture got trapped in.
http://www.yourhotcar.com/product/xe...110/23315.html
^are the xenon ones similar to the 86 ones you had one?
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
no mine are original 86 skirts the xenon apears to go higher up on the door and dont stick out as much and have a more gradual slope than a v
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
So found a few issues today one being there is very thin aluminum covering a huge rusted out spot the area where i believe the spare tire would go
another is the interior used to be tan i found this out when i started taking the panels off to get to bolts here which means the panels have spray painted as far as updates go pulled the front nose off to get it all prepped and aligned correct got rid of the latch that was bent and was a pain to open
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Not much today got the side markers working again got the nose properely aligned sanded nd primed the front gfx also got my led lights from superbrightleds for the guages on the piller heres some before after pics
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Todays goal is cleaning up the interior figuring out what i need to replace or fix, ordering some iequiis guages and measuring out for a panel for them. But i do have a question how do i remove the rear seats?
Edit: figured it out
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
Wow, someone really gooberd that car up. Man sorry to say, but I would ditch thoes autozone fog lights so fast it wouldnt even make it in my driveway looking like that.
But hey, you might be on the path to saving another beat iroc.
Looks good.
Looks good.
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
got a lot done today got the hood done need to do a lot of work on the door with all the low spots got the drivers side gfx on i like the look of them. Working on modding the gas cap making it flush fit ill get some progress pics as i go with that also bought an 87 z28 1:25 model kit that i will building as a replica of what mine will look like.
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Working on the fuel door today smoothing it flush to the body plan on fabbing in some kinda way to get it to pop out kind of like how entertainment center doors push in and pop out got the bump cut out heres how it looks now
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Small update tonite got the gas cap smoothed out and primed got the piece fabbed in to "pop" the cap open think it came out pretty good. Updates on the car itself will be done once it warms up probably tuesday. 20 degree weather and wind is not my ideal time to be geting stuff done on it.
looks brand new
And a close up
looks brand new
And a close up
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Alright so youre gonna do my car next right? Ill have a bus sent to transfer you here immediately
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Todays big "for the win" was getting my reverse lights to work big thanks to paulo for helping me! For any others who are having troubles getting them to work heres the thread for it- https://www.thirdgen.org/forums/elec...se-lights.html
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
I'll be keeping an eye on this local home grown Camaro!
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
It looks like its coming along well. Keep the thread going. Can't wait to see the final results.....
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Got bored did some work on the visors the material was sagging and had a crack in the glass i wanted to use some 4th gen visors i had but they were to big so i stripped mine down im thinking about fiberglassing them in so i never have to worry about them sagging again i did use the mirrior covers after cutting and trimming them to work still need a little work.
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Ordered my white faced guages from iequus this morning im getting 3-3/8in speedometer and tach and 2in voltometer, fuel level, oil pressure, and water temp they should be here in a few days.
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Today got the rear bumber smoothed out it still needs sanding then ill post pics also pulled a lot of the interior panels out sanding them down putting epoxy in any cracks dents etc.. finished up the visor cover turned out really good did a flat black with a clear gloss any recomendations on what to use to cover the actually visor with i want something that will be permanant like bondo, bondo glass, bondo jelly, fiberglass i do not want to cover it with fabric heres pics of the visor sits
Car: 1989 Camaro RS--
Engine: MPFI
Great job, just not sure why you are putting 92 ground effects on a Iroc, they didn't make a Iroc in 92. It will look nice! but takes away from the Iroc. I guess i woundn't worry about the hatch looking like a 86 if you do the 92 gfx. You are kicking some A** and doing a great job. I 'm enjoying the restore!
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Car: 1987 IROC-Z
Engine: 5.7L
what do the clips have to do with it?...they look like theyre just from a window louver that was previously installed and removed but they left the clips on...
and why is there two holes at the top of the side sections of the spoiler?
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
i was told the clips were used on a firebird maybe not either way i would like to replace it and not sure i pulled the end caps off and thats what was there
