Number five...
Old Jan 17, 2012 | 07:33 PM
hairysox33's Avatar
Old Jan 17, 2012 | 08:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Number five...
you can get a 5.3 for dirt cheap..... even the aluminum ones.
Old Jan 17, 2012 | 09:55 PM
hairysox33's Avatar
Re: Number five...
I'll definitely look at a carbureted 5.3, to run it like that, what else needs to be done along with the obvious (carb/manifold)? That would be a whole new thing for me, so stupid details would be nice lol. Also, without any blatant abuse to the trans, how should the t5 with a decent clutch/flywheel setup do behind an otherwise stock 5.3?
As far as he told me, it was originally a crossfire car, factory auto.
Old Jan 17, 2012 | 10:04 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Number five...
[quote=hairysox33;5153042]Picked up this 82 z28 today, been awhile since I've been on the board here, good to be back .. anyways, it has no motor, bad interior, a clean body, and a flat tire.. BUT most importantly, it has zero rust. $500 delivered to my door and I finally have an autocross project!
My old 1991 z28's thread: https://www.thirdgen.org/forums/memb...-1991-z28.html
I sold this fourth gen after a body resto for a good profit to fund this venture.
what did you do to the nose of this fourthgen??
Old Jan 17, 2012 | 10:10 PM
hairysox33's Avatar
Re: Number five...
Nothing? The headlights buckets are not black anymore...
You must be thinking of a 98-02 fourth gen front end. This is 93-97 (lt1 cars)..
Old Jan 17, 2012 | 10:12 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Number five...
Thats great! Start a restore thread, that way we can all follow. Your 4th gen looked pretty nice.
Old Jan 17, 2012 | 10:19 PM
hairysox33's Avatar
Re: Number five...
Old Jan 17, 2012 | 10:30 PM
Engine: L31 350
Re: Number five...
no the point on the front end seems alot sharper and just different than any others that iv seen.
Old Jan 17, 2012 | 10:37 PM
hairysox33's Avatar
Re: Number five...
Oh, I don't know then. Came off of a 95? Parts car, was maroon.
Old Jan 17, 2012 | 11:36 PM
hairysox33's Avatar
Re: Number five...
For real though, anybody know of anyone that successfully uses a 5.3/t5 as a setup?
Bear on mind, I know an aftermarket trans, or a t56 is a more suitable option. Neither are cheap. If I'm not mistaken non world class t5's aren't good or any real torque, and wc models are only good to like 300lbft. I will be driving accordingly to autocross, no third gear power shifting
Old Jan 18, 2012 | 08:48 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: Number five...
You can mount a 5.3 to a T5. There are two different ways, the way I am looking into is using a 621 bellhousing with an LS1 cluch, pressure plate, and flywheel. Howe racing makes a throwout bearing that will work and you will need an LS7 pilot bearing. One small issue with this is you will no longer have the 17* canter to the transmission and you will need to figure out a shifter to fix that.
The other way, and I am not as familiar with this one, is using the stock bellhousing and clutch, etc. but you will be without one bolt on the bellhousing. Also I am not sure how to make up the difference in depth between the T5 and 5.3. This will also take care of your transmission tilt issue.
Of couse everyone is going to chime in and say you are not smart for using the T5 behind the 5.3, because the biggest issue with the T5 is the case. It is not that strong and it can/will blow out. You can beef up the internals to take the abuse no issues, but the case will not be able to. I plan on putting my T5 behind a pretty stock 5.3 and I will not be beating on it at all, so I have no doubt that it will hold up for me. Good luck on what ever you choose.
Old Jan 18, 2012 | 11:26 AM
hairysox33's Avatar
Re: Number five...
That's all the info I needed! Thanks, I'm in forest lake right now on my way to lakeville for the trans setup.
Old Jan 18, 2012 | 01:35 PM
hairysox33's Avatar
Re: Number five...
Old Jan 18, 2012 | 08:18 PM
hairysox33's Avatar
Re: Number five...
Old Jan 18, 2012 | 09:44 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: Number five...
3.73's are nice...if you don't use them though then go ahead and throw them on craigslist....you can turn a good profit with those. Thread is lookin good!
Old Jan 19, 2012 | 03:45 PM
hairysox33's Avatar
Re: Number five...
I might even use them, I'm going to figure out what ratio this rear end has and go from there, I'll be pulling it anyways to fit the brakes and refinish the housing.
I will probably just be getting reman parts store rear calipers, anyone have a suggestion for an AFFORDABLE upgrade? I'll likely just us stock calipers, stock rotors, and hawks pads.
Old Jan 19, 2012 | 07:42 PM
karl's-92'-z28's Avatar
Car: Too many cars
Re: Number five...
So you sold your '91 z28?
Old Jan 19, 2012 | 07:48 PM
hairysox33's Avatar
Re: Number five...
Sadly yes, it became a money pit of epic purportions, had rust, was just turning into a bad deal all around.
Old Jan 19, 2012 | 08:07 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: Number five...
Pretty cool, I really like that 4th gen you had.
I'm also on my 5th 3rd gen, and I got an early 3rd also (83) Can you post more pics of the front bumper on your 82? It looks, different for some reason.
Old Jan 19, 2012 | 08:18 PM
hairysox33's Avatar
Re: Number five...
I will, I suspect it to be the front bumper cover off of a 91/92, it came with that year side ground effects, I think its just missing the front lip is all.
Old Jan 19, 2012 | 08:28 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Re: Number five...
well i have used my t-5 behind my 468 BBC with 590 to the wheels hasn't hurt it yet. but my stock 16's don't hook up either i don't see it being a problem behind a 5.3.
Old Jan 19, 2012 | 08:29 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: Number five...
Oh ok, ya it just looks like a stock 82 z/28 bumper with no chin spoiler. I it were a '91 '92 it wouldn't have the sunken in blinkers in the front.
Old Jan 19, 2012 | 08:39 PM
hairysox33's Avatar
Re: Number five...
I think that should put the t5 arguement to rest... Ha, is it a stock t5?
Ah! Good call, I didn't even notice that.
Old Jan 19, 2012 | 08:55 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Re: Number five...
yes it is a stock world class t-5 i have the lakewood scatter shield and a 11 inch clutch also
Old Jan 19, 2012 | 09:01 PM
hairysox33's Avatar
Re: Number five...
Huh, that's cool. Never would have guessed it would be fine. I'll probably look into a 5.3 then!
Old Jan 22, 2012 | 06:40 PM
hairysox33's Avatar
Re: Number five...
Priced new rear calipers and rotors. Priced for an 85' z28..
Calipers are $60.95/ea (exchange) at orielleys
Rotors are $30.00/ea at napa
Any better options? Seems like for that money I could spend a small bit more and have something upgraded. Like, ls1 car brakes? I just feel like I have a start in this direction, and would rather not change the game up ha. Also, this style brake (one caliper on opposite sides of the housing) seems dumb. Just me?
Old Jan 23, 2012 | 01:10 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: Number five...
It really depends on what you mean by a "small bit more". I have seen complete LS1 front brakes go for $150. You will have to get your rotor turned down into a hub, modify your spindles, and get brackets and bolts and you will have your LS1 brakes. I pieced mine together a few years ago and spent around $400 with modified spindles, hubs, bearings, etc. To me that was a steal and well worth it.
Old Jan 28, 2012 | 10:06 PM
hairysox33's Avatar
Re: Number five...
Alright man, I've been looking and having trouble finding local stuff...
I'll likely stick to a stockish configuration, only with upgraded pads... Lame.
Old Jan 30, 2012 | 09:10 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: Number five...
You are better off looking at the national boards and hoping someone is willing to send them to you. People are upgrading all of the time and just want their stuff gone.
I know a guy that is selling spindles and rotors from his '85 if you are interested in them. One potential issue is him shipping them. He is pretty busy and might not want to ship them and you would have to travel to the St. Paul to get them. Not sure where in Wisconsin you live.
What would you be willing to spend? I will keep my eyes open for you.
Old Jan 31, 2012 | 12:45 AM
hairysox33's Avatar
Re: Number five...
I live right next to Duluth, MN in Superior, WI. Its only two hours of speedy driving to St. Paul! The Front Setup is upgraded or stock? I'd like to keep it under $175, the more the better. If thats realistic, sorry, kid of scatterbrained lol.
Old Jan 31, 2012 | 12:53 AM
hairysox33's Avatar
Re: Number five...
Old Feb 1, 2012 | 10:05 PM
hairysox33's Avatar
Re: Number five...
Old Feb 1, 2012 | 10:26 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Re: Number five...
Looking at a totally o.e. clutch/flywheel setup as of now so I can actually finish the project and not have it drag on forever.
Flywheel:http://www.summitracing.com/parts/ZZZ-50-6525/
Clutch:http://www.summitracing.com/parts/ZZZ-MU56-1/
Trans Mount:http://www.summitracing.com/parts/PTP-7-1604/
Master/Slave setup:????
I'm also looking at this neat little upgrade to the T5 while its out of the car, on another forum a guy suggested this saying a road race crew he knows personally has been using this billet aluminum bearing retainer. Since they haven't lost a single transmission. So masybe its worth a shot at $45.00?...
where do you get the retainer at
Old Feb 2, 2012 | 11:42 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: Number five...
i noticed that aswell, like it alot more than the softer rounder features of that gen camaro
Old Feb 3, 2012 | 02:19 AM
hairysox33's Avatar
Re: Number five...
Sorry guys haha, not surr exactly why it seems different. It was a take off at a pick a part.
Old Feb 3, 2012 | 03:17 PM
kmcn47's Avatar
Transmission: 5spd
Re: Number five...
none the less, it looks good
Old Feb 3, 2012 | 04:20 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Number five...
Are you sure its not just a reflection in the paint? The primered picture doesn't really look like it has a point.
Old Feb 3, 2012 | 07:18 PM
hairysox33's Avatar
Re: Number five...
The primered bumper is not the one that was on the car when it was painted. It was a factory bumper, factory color, I'm not sure why it looks so weird lol.
Old Feb 7, 2012 | 01:43 AM
hairysox33's Avatar
Re: Number five...
Old Feb 7, 2012 | 07:36 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Re: Number five...
I was looking at the seats and they look real close to pace car seats also looking at the inside kick panel it is silver i would bet you that was a 1982 indy 500 pace car.
Old Feb 7, 2012 | 08:23 AM
marokid's Avatar
Car: 86 z28,89 iroc
Engine: 350 crate and ls1
Transmission: 700r4/4l60e
Axle/Gears: open diff stock/4th gen posi
Re: Number five...
yup thats a pace car interior ....i got one myself
Old Feb 7, 2012 | 11:10 AM
  #42
hairysox33's Avatar
Re: Number five...
The engine bay is silver too, must have been one! Too bad its not in good shape, even though I don't care for the decals anyways.
Old Feb 8, 2012 | 05:31 PM
  #43
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Number five...
[QUOTE=kmcn47;5169563]Quote:
i noticed that aswell, like it alot more than the softer rounder features of that gen camaro/QUOTE]
It's the same as the rest of the LT1's, it's probably just the angle the picture is at making it more pronounced.
Old Feb 12, 2012 | 01:05 AM
  #44
hairysox33's Avatar
Re: Number five...
Yeah, he, it probably is just the angle. I'll look for another pic of it here to put this thing to rest...
Old Feb 20, 2012 | 06:28 PM
  #45
hairysox33's Avatar
Re: Number five...
So, I got the engine on a stand now, gotta pull the pan and check the guts out... But, I'm probably changing plans a bit and using the t-350. I'd honestly rather go faster by investing more in the engine than go fast and break my trans and be s.o.l on a bunch of money. Lots of guys I've seen use Northern Auto Parts for rebuild kits with very good luck, thats a fact.
If the cylinders are any good, I can get away with this $137.00
http://www.northernautoparts.com/Pro...ctModelId=6827
Includes:
  • Perfect Circle stock style Piston Rings
  • Federal Mogulstock style Rod Bearings
  • Federal Mogul stock style Main Bearings
  • Victor stock style Gasket Set
If it needs machining, this kit goes for $217.00
http://www.northernautoparts.com/Pro...tModelId=26429
  • Silvolite stock style Pistons
  • Hastings stock style Piston Rings
  • Federal Mogul stock style Rod Bearings
  • Melling stock style Oil Pump
Thoughts? That leaves a cam, intake, carb, exhaust, and head rebuild to have a fresh motor.
Old Feb 21, 2012 | 12:26 AM
  #46
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Number five...
Looks like you've got yourself a roller block. The tops of the lifter bores are even machined/clearanced for the dogbones. You can get that whole factory roller hardware kit for cheaper than retro roller lifters. Get the factory roller kit and an LT4 hotcam off ebay and you'll be way, way ahead.
Old Feb 21, 2012 | 12:41 AM
  #47
hairysox33's Avatar
Re: Number five...
Found the cam, what did you mean by the roller kit?
http://www.ebay.com/itm/HOTCAM-SB-Ch...item27c39782f9
Old Feb 26, 2012 | 09:35 AM
  #48
FormerL69's Avatar
Car: 1982 Camaro Pace Car
Engine: LU5 Crossfire
Re: Number five...
Definitely a pace car interior, but I'm curious if someone swapped it or if it's the real deal. Just curious -- does the trim tag on the radiator support show "26G 16L 16U" ?
brandanpyles
Apr 1, 2013 07:53 PM
M3rcury
Mar 26, 2012 08:23 PM
jer4251
Jan 9, 2011 10:52 PM
manifoldsrme
Jan 20, 2010 09:11 PM
83_ta454
Jul 16, 2006 09:31 PM
