My 1986 Z-28 build thread *PIC HEAVY*
#351
Re: My 1986 Z-28 build thread *PIC HEAVY*
Thanks for that.
I had been running the OEM Vortecs and Air Gap intake for years with the MS 90131 and had no problems. When I moved on to the RHS Vortecs (Pro Torker), I started using a ton of oil. 6 and 8 plugs are oil fouled (the engine is fresh) so it looks like the gasket gave up or doesn't quite fit the new heads or the slightly decked block (.015").
I like the looks of the 1255. There's only one report I've read where even though the gasket appears to have sealed the port completely, oil getting past it was still a problem.
Having said that, I'm encouraged by your choice of the 1255. From the looks of things, you and your shop appear very thorough. Your build is excellent.
I ordered a 1255 last week but am still investigating what peoples experiences are. I'll order new bolts too. Still debating whether to choose the Edelbrock spec (8516) or the ARP 134-2103.
Thanks again.
Keep up the good work.
#352
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Get some red brush on Hi-tack, glue the head, and both side of the gasket. Mine held 14" of crankcase vacuum without a single issue. I also do a bead of right stuff around the coolant passages on both sides of the gasket. Also, my block has been decked about 0.022" and the heads around 0.007". Felpro MLS 0.040" head gasket.
#353
Looks like more shopping for the brush on variety of sealer.
Just a thought. I don't suppose you spent too much time at idle (on the dyno) where your manifold vacuum is highest. This would have been largely offset by the vacuum pump although having said that, I suppose at WOT, when manifold is at or near zero, there's quite a pull from the pump (14").
I'm not sure when my gasket packed it in as it's been using oil from the onset. At cruise, when coasting down a hill, my manifold vacuum is above 20".
I hope the 1255 and High Tack are up to the task.
Thanks again.
#354
Car: 1979 Malibu
Engine: Blown LSx
Ive had enough bleeding finger tips scraping these gaskets off with a razor blade to know they arnt going anywhere. Provided your angle's are correct.
#355
What do you use for a torque spec? I used the same parts on my engine but ignored the OEM 10 ft/lbs spec. I torqued mine to 23 ft/lbs with liquid teflon on the threads as per a tech guy @ ARP.
Build is looking great BTW, can't wait to see this thing finished!
#356
Car: 1979 Malibu
Engine: Blown LSx
I used my best judgement when I tightened them. Never had a problem.
#360
Car: 1984 Z28
Engine: Vortec 350, hotcam
nicely done! are you going to be making an aluminum dash panel? Or running the bars up front through the stock dash?
#361
Car: 1979 Malibu
Engine: Blown LSx
Stock dash, Thats why we tucked the a pillar bars so tight so the amount I had to trim the dash pad was minimal.
#363
Car: 1979 Malibu
Engine: Blown LSx
Hello??? this thread seems kinda dead.
Spent a few hour's last night getting the bellhousing aligned, Also ended up making a custom alignment tool for the clutch disc. but at the end of the night I have the engine ready for the transmission. The Flywheel is a lightweight RAM billet steel, the clutch is a RAM powergrip HD, and the scattershield is a lakewood.
#364
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Pulling that scattershield looks like it would be a PITA to pull when the engine is in place. WOW.
#365
Car: 1979 Malibu
Engine: Blown LSx
Yah, thats why I decided to do it before it went in the car.
#369
Car: 1979 Malibu
Engine: Blown LSx
Major milestone, transmission meets engine.
#370
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
how did you get the roll cage in the car since it looks like its put together outside the car??
#371
Car: 1979 Malibu
Engine: Blown LSx
It's getting partially welded in 2 pieces then put back in the car for final welding
#372
#373
Car: 1979 Malibu
Engine: Blown LSx
Cage is 95% welded. Just gotta weld the plate to the floor and the finish welding the cage to the plates.
#374
Car: 1979 Malibu
Engine: Blown LSx
Cage is 100% done. Glass will be going in soon!
Started mounting the nitrous fuel cell
Threw on a front tire to check clearance on the fuel cell.
#375
Car: Pontiac GTA
Engine: 5.7L TPI
phenomenal build, ust took over 45 minutes to read through it, absolutely amazing man.
#376
Car: 1979 Malibu
Engine: Blown LSx
more updates!
nitrous fuel cell roughly mounted, may have to shorten up the cell a bit. Goign to put on the front fender and see how it fits.
Started removing the old front suspension
Driver side seat partially mounted
#377
Car: 1986 IROC
Engine: 2000 Vortec 5.7
Wow talk about some serious work being done to a car. Its pretty rare you see someone doing everything right. Most people bolt in a some crazy HP motor into a car, be damned stock rear, suspension, transmission, brakes or anything else. Your car should be a shrine to all 3rd gens when its done! Just watch out for deer! I just tagged one with my truck and seems like everyone i know is hitting them left and right!!!
#378
Car: 1979 Malibu
Engine: Blown LSx
More updates!
Rear bumpstops cut off and plated.
Kirkeys mounted.
Painless switch panel mounted on the halo bar.
Kirkeys mounted.
#379
Car: 1979 Malibu
Engine: Blown LSx
Well, more updates... Last night was quite productive.
Brought the hood and front fenders to check clearance on the top of radiator.
Cut out some floor in the rear to make room for the fuel cell
Kirkeys
Radiator fits!
Nitrous fuel cell.
Welded a sump into the fuel cell
Rear wheel wells all cleaned up
Shot from the rear
Kirkeys
Radiator fits!
Nitrous fuel cell.
Shot from the rear
#380
Car: 1979 Malibu
Engine: Blown LSx
Custom made master cylinder adapter
Torque arm bolted to the rear end.
Removable upper rad tie bar to make engine installation/removal easier
REAR END IS IN!
REAR END IS IN!
#382
Wow. That's a lot of work.
When do you anticipate being done?
#389
#390
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
who makes that master cylinder?
#391
Car: 1979 Malibu
Engine: Blown LSx
It`s made by strange engineering, copy of an old dodge piece.
#392
Car: 1979 Malibu
Engine: Blown LSx
Made the car a roller again last night, so I can bring it home tonight. Nolan is gone for a week, so im bringing it home to keep going hard on it until he gets back to finish the fab work
New front steering loosely bolted in to make rolling it around easier.
Outside for the first time in a while
A picture a took when I was sitting in the car making engine noises.
#394
Car: 1979 Malibu
Engine: Blown LSx
Updates! the pictures are self explanatory
#396
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
I can't wait to see the final product.
I'm forever checking in on your build. This car is/going to be truly amazing.
#399
Car: 1979 Malibu
Engine: Blown LSx
Power steering dosnt make it go any faster. I'm used to driving lots of old cars, manual steering, manual brakes, three on the tree etc. I'll manage
