My Build 1984 Z-28 L69/Street strip
Old Feb 24, 2013 | 02:25 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
1984 Z-28 L69
After a long hard search I found the car to fit my needs. I've been searching for an 84-87 Z-28 White, carbureted, hardtop without A/C and no power options. I purchased this car in April of 2012 with only 11,531 miles. I will post pictures of the day I brought it home.
Hope you enjoy
Frank
Attached Thumbnails My Build 1984 Z-28 L69/Street strip-152.jpg   My Build 1984 Z-28 L69/Street strip-138.jpg   My Build 1984 Z-28 L69/Street strip-166.jpg
Old Feb 25, 2013 | 06:07 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Re: My Build 1984 Z-28 L69/Street strip
Her are some more pics of engine bay before the clean up. Take note of the rusty jones under coating that was sprayed all over engine compartment. Came off pretty easy with a little elbow grease and some mineral spirits.
Attached Thumbnails My Build 1984 Z-28 L69/Street strip-139.jpg   My Build 1984 Z-28 L69/Street strip-142.jpg   My Build 1984 Z-28 L69/Street strip-137.jpg
Old Feb 25, 2013 | 06:25 PM
03_z's Avatar
Car: 84 z28
Engine: 406ci
Transmission: th350
Nice. Look forward to updates.
Old Feb 25, 2013 | 06:27 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Some more
Original Eagle GTs and there not dry rotted!
Take note of the dirt from sitting
Attached Thumbnails My Build 1984 Z-28 L69/Street strip-151.jpg   My Build 1984 Z-28 L69/Street strip-155.jpg   My Build 1984 Z-28 L69/Street strip-145.jpg
Old Feb 25, 2013 | 06:38 PM
gt4373's Avatar
Transmission: 5-Speed Manual
FJA1791 Is This In Addition To The One That You Already Have
Old Feb 25, 2013 | 06:43 PM
LivinLarge's Avatar
Great looking car! What are your plans for a motor and trans?
Old Feb 25, 2013 | 07:05 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I spy a camaro conteur interior in that thing! Can you get some pictures of the interior. That car def a rarity with that interior along with the powertrain. Since its a HO and a 5 speed you have a fairly good chance of having 3.73 gears in the rear. Not sure if you checked that or not yet.
Im going to add a bit to this and say that since its a rarer car and low mileage you might consider only doing the mods that you can change back to stock should you feel like it. In other words instead of weld in SFC buy the bolt in type. Things like that. The value of that car is in its originality.
Old Feb 25, 2013 | 08:27 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Same one...I just decided to start a build thread of everything I have done since April. I should have started it sooner. I given bits and pieces of the car but decided this would be best to show TGO my build in order.
Old Feb 25, 2013 | 08:33 PM
subroc's Avatar
Engine: 355 TPI
If thats the case you dont have a 700r4 in that car. That would be the 4 speed auto. You have a T5.
Old Feb 25, 2013 | 08:51 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
I will use the L69.
Old Feb 25, 2013 | 09:08 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
You are correct...I will post some pictures soon. It did come with 3:73 gears
As far as modifying this low mileage car it was not an easy decsision. Car was so original down to spark plugs, plug wires, brakes, belts, hoses and tires. I have saved every nut and bolt to be able to be put back to original. Everything I do will be bolt on. As rare as this car is it will never be a 69 Z-28. I plan to keep this car for a while and maybe pass it down to my boys some day.
Old Feb 26, 2013 | 05:21 AM
subroc's Avatar
Engine: 355 TPI
You are correct...I will post some pictures soon. It did come with 3:73 geras but I had changed them to 4:10...After seraching long and hard for a Dana 44 I finally found one. I will be posting my progress with that soon.
As far as modifying this low mileage car it was not an easy decsision. Car was so original down to spark plugs, plug wires, brakes, belts, hoses and tires. I have saved every nut and bolt and only thing I had to do that concerned me was useing the hole saw to cut opening for auto shifter gromet. Everything I do will be bolt on. As rare as this car is it will never be a 69 Z-28. I plan to keep this car forever and pass it down to my boys some day.
Sounds like you got a good plan going for it! As for the dana 44 im jealous. Ive been looking on and off for a few years now with no luck so i gave up and rebuilt my 9 bolt completely instead. If it goes out again in a few years then ill give up on it and seriously start the hunt again for a D44. If you ever change direction and want to sell that dana let me know!
Old Feb 26, 2013 | 06:36 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Very nice car. Enjoy it!
Old Feb 26, 2013 | 08:28 AM
Jutlee's Avatar
Car: 84 z28 t-top
Engine: 355
Axle/Gears: 10bolt 2.73
Gotta love how the "original" pops out and waives at ya. Kool find.
Old Feb 26, 2013 | 08:36 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Interior shots before clean up
Attached Thumbnails My Build 1984 Z-28 L69/Street strip-162.jpg   My Build 1984 Z-28 L69/Street strip-163.jpg   My Build 1984 Z-28 L69/Street strip-164.jpg
Old Feb 26, 2013 | 08:41 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Some more
Attached Thumbnails My Build 1984 Z-28 L69/Street strip-178.jpg   My Build 1984 Z-28 L69/Street strip-170.jpg   My Build 1984 Z-28 L69/Street strip-img_4072.jpg
Old Feb 27, 2013 | 05:04 AM
subroc's Avatar
Engine: 355 TPI
That is one clean interior! Gotta love the conteur interiors of the early z's.
Old Feb 27, 2013 | 09:52 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Wow...That car is/was a true time capsule. If mine were in that kind of shape when I got it, I'd be hard-pressed to mod it. It's true, it'll probably never command top dollar like a 69Z, but I do think it would sell a bit above any LG4 Z of that era. Love the interior too but not the color of it!
Like you, I still have my original engine rebuilt on a stand with less than 5k on it when I yanked it. The ECM and harness, the composite hood, the duel snorkel AC and scoops etc. Sold the rear end though...it was just a POS 3:73 one-wheel peel aluminum drum thing anyways. Good luck with the build!
Old Feb 27, 2013 | 09:05 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Thanks...I also was not sure about interior color but in person it actualy looks really nice against the white exterior.
Old Feb 27, 2013 | 09:30 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
After wash
Attached Thumbnails My Build 1984 Z-28 L69/Street strip-img_4077.jpg
Old Feb 27, 2013 | 09:44 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Her are some pictures of the under carriage. First picture shows the Rusty Jones under coating and I have one with most it already removed. I used mineral spirits and alot of elbow grease Still have more to do.
Attached Thumbnails My Build 1984 Z-28 L69/Street strip-uc.jpg
Old Feb 28, 2013 | 08:19 AM
Confuzed1's Avatar
Car: 83Z28 HO
That sucker looks solid underneath!! My car also had the "Rusty Jones" treatment...I can tell you it doesn't work. Yours is a low mileage car, and its a good thing you're taking that crap off.
Do you plan to spray some real under coating on it? It's looking nice! And where did you get the "test pipe"??? I can't get one here locally...or they won't sell me one. I notice it has the 4 bolt flanges exactly like I need! What diameter is that test pipe?
Old Feb 28, 2013 | 11:34 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
I do not plan on using any undercoating. Car is garage kept and will not be driven in bad weather. I picked up test pipe on eBay...the pipe is 3 inch diameter.
Old Mar 1, 2013 | 12:40 PM
Confuzed1's Avatar
Car: 83Z28 HO
Looked on fleaby and found it. Thx! Never thought about looking there...duh. My radio is identical to that one...except in much worse shape. I replaced it with a Sony long ago...and I might pull that one and get a newer one I could plug my IPOD into...haven't started looking for those yet...
I still have the Rusty Jones tar on my car....just never saw any reason to remove it. Mine is also garage kept, and never sees bad weather or salt. But sometimes you'll get a suprise downpour during the summer...
Old Mar 3, 2013 | 05:54 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Hear are a few shots of engine bay after cleaning and wiping off Rusty Jones undercoating. I also removed air pump and air tubes (saved every nut & bolt). I replaced fuel pump with hi volume Carter and made up new fuel line to help with boiling fuel and vapor lock on hot days.
Attached Thumbnails My Build 1984 Z-28 L69/Street strip-cleaned-2.jpg
Old Mar 3, 2013 | 06:09 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Old Mar 3, 2013 | 06:30 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Beautiful car. I'm looking forward to following your progress.
Old Mar 3, 2013 | 07:06 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Thank you Zane M...
Old Mar 3, 2013 | 07:51 PM
subroc's Avatar
Engine: 355 TPI
So jealous of how clean that car is...and very very jealous of the Dana 44. It puts my built 9 bolt to shame.
Old Mar 16, 2013 | 08:28 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
subroc
Old Mar 16, 2013 | 08:48 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Old Mar 16, 2013 | 08:58 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Old Mar 16, 2013 | 09:04 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Old Mar 17, 2013 | 06:49 PM
subroc's Avatar
Engine: 355 TPI
Oh man is that ever sweet. If you ever decide the D44 isnt enough for that give me first shot at buying it off you would ya? Again beautiful car!
Question...what wheels are those? Im not sure ive seen them before.
Edit..just saw that they were weld drag wheels. Look nice on there!
Old Mar 17, 2013 | 09:46 PM
puma1552's Avatar
Nice car, really nice underneath...but it looks to have had a patch welded in near the driveshaft tunnel?
Old Mar 18, 2013 | 05:08 AM
subroc's Avatar
Engine: 355 TPI
If you look closer you can see that that is a heat shield. Wouldnt make sense for a car with so few miles to have a floor patch.
Old Mar 18, 2013 | 12:44 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Subroc thank you for your response...your dead on with your reply...it's just a heat shield. As far as Dana 44 goes I don't believe it will be for sale anytime soon but you have 1st chance if I ever do want to sell...lol
Old Mar 18, 2013 | 01:32 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Clean car
Gonna be checking this thread out
Old Mar 29, 2014 | 10:27 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Update
Old Mar 29, 2014 | 10:39 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Update
86FyrBrd
Convertibles
Sep 9, 2019 11:18 PM
G92-Z28
Members Camaros
32
Jul 7, 2018 08:55 AM
Ja85z28
Feb 13, 2018 12:34 PM
Linson
Feb 14, 2016 08:36 PM
