My '85 Berlinetta transition to IROC clone
Old Jan 29, 2014 | 06:29 PM
  #51
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Re: My '85 Berlinetta transition to IROC clone
you should show the old owner haha
Old Jan 29, 2014 | 06:35 PM
  #52
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I bought the car from a guy in my car club who gutted the interior for his Z28 and then sold the car to me so I never met the previous owners. I asked my buddy to show them the pics if he still has their contact info!
Old Jan 29, 2014 | 06:43 PM
  #53
RSFreak's Avatar
Originally Posted by MY87LT
Very cool. So just some minor hood adjustments and I assume the IROC hood louvers are going on soon?
Yep, got the louvers tucked away along with the fog light grill insert. The louvers need to be repainted and the grill had multiple holes drilled in it when I picked it up at the junkyard. Holes are filled but I still have to sand and repaint it as well. The headlight buckets will get painted black soon after.
Old May 5, 2014 | 11:48 PM
  #54
RSFreak's Avatar
Double post
Old May 5, 2014 | 11:54 PM
  #55
RSFreak's Avatar
A few updates. Been working on the engine bay a little and got Z28 badges on. When we move into our new house next month I will be painting the louvers and grill insert.
Old May 6, 2014 | 03:35 PM
  #56
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Mighty handsome!
Old May 6, 2014 | 06:27 PM
  #57
RSFreak's Avatar
Mighty handsome!
Thanks!
Old Jun 17, 2014 | 11:01 AM
  #58
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Your Berlinetta is looking great! What a transformation! I know how much work it is as I have done the same conversion to my 1984 Camaro Berlinetta.
Old Aug 13, 2014 | 12:13 AM
  #59
RSFreak's Avatar
Another update:
Beautification project
At a local 3rd gen gathering
Took home a class win in '82 - '92 Modified Camaro Class at the Pacific NW Camaro Club show
She's come a long way!
Old Aug 13, 2014 | 01:15 AM
  #60
loopy's Avatar
Car: 1983 Camaro Berlinetta
Engine: L31
Nice car, congratulations. Mines a 83 berlinetta.
Old Aug 13, 2014 | 03:56 PM
  #61
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Oh my.... I dont see how you were able to do that in any sort of cost effective way, so congrats for pulling it off. You cant argue with results, that looks fantastic. I love silver IROCs.
Old Aug 13, 2014 | 08:52 PM
  #62
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Is the dash digital?
Old Aug 13, 2014 | 09:39 PM
  #63
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Congratulations on the win!
Originally Posted by RSFreak
The radio is somewhat functional, but I think I'm gonna install a hidden head unit so I can have decent tunes!
I had a standard center console in mine for a while. It takes a couple of modifications but it might be worth considering. You could also swap to a 4th Gen center console as well.
FWIW, Berlinettas lack a couple of triangle braces up by the front frame rails. Easy to pick up a set and install though. Did you upgrade sway bars yet?
Old Aug 13, 2014 | 11:17 PM
  #64
Car: 1992 Camaro RS
The K-member braces?
These black pieces are the factory k-member braces.
Old Aug 14, 2014 | 12:08 AM
  #65
RSFreak's Avatar
I did this build slowly over several years and already had most of the pieces. The paint cost more than the rest of the build (including the price of the car) combined.
Yep, digital dash and pod radio. I love it!
I got a Wonder Bar from an IROC and Z28 front sway bar. The Berli didn't have a rear bar, so that will be a nice upgrade.
Old Aug 14, 2014 | 12:58 AM
  #66
Scorpner's Avatar
Engine: V6, V8
There are actually four IIRC. Berlinetta's only have two.
Old Aug 14, 2014 | 12:59 AM
  #67
Scorpner's Avatar
Engine: V6, V8
Yep, you'll need the end link brackets as well if you don't already have them.
Old Aug 17, 2014 | 10:22 AM
  #68
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
So where did you find NOS red Z28 badges? Or are they repops? I haven't found any that look stock.
Old Aug 17, 2014 | 11:05 AM
  #69
John in RI's Avatar
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The car look GREAT dude !! The black headlight pockets were (very) worth the effort. I had an 86IROC painted silver once and your Berlinetta looks very much like my old ride right now. Silver is my (second!) favorite color on a ThirdGen.
http://berlinetta.info/mypics/86IROC...riverRear1.JPG
Edit: Your Berlinetta is an 85,.... Did it have the front frame rail to cross-member braces from the factory ??? I know 82-84 Coupes/Berlinetta didn't get them, ( only Z28 did ) but thought the braces were added to all cars ( "standard" F41 for all ?) starting in 85 or 86.
Scorpner is giving you some good advise about those Frame-Rail braces. If you plan to keep the car, get some !! There's also a 3rd brace under the drivers side "battery tray" - be sure to get that one too. the 4th one is a rod type brace from the cowl to the pass side hood hinge.
IMO; you REALLY need to install a rear sway bar ! Once you install a rear sway bar your gonna' fell like your driving a totally different car. While installing the rear bar I'd also consider rear springs ( put the front spring swap on hold till the struts need to be replaced. ) Adding a rear sway bar is going to cause a HUGE change to it's handling; so much that you will have to re-learn driving thru the curves !!
Keep up the great work !!
Old Aug 9, 2015 | 01:01 AM
  #70
RSFreak's Avatar
Yup, it's got the digital dash and pod radio:
Just a few more updates:
Got some new wheels, 17" 'Vette replicas, which I need tires for:
Also got some later style IROC wheels on her:
Finally got the louvers on her:
Old Aug 27, 2015 | 08:03 PM
  #71
Billgluckman's Avatar
Great job with the car, love to see a junker turned into a driver.
Old Aug 28, 2015 | 05:24 PM
  #72
ThirdGen1984's Avatar
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
Great project, im getting ready to have all the rust repair on my car done, then she will be sent to paint, or maybe my 16'' chrome iroc wheels, not sure which order,
Old Jan 31, 2018 | 05:08 PM
  #73
Ericklsx's Avatar
I know this thread a bit old but I want to the same with 87 camaro that came with no gfx I was wondering what you did to install the door sideskirt gfx
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
bbernardo94
Aug 19, 2015 05:25 AM
Randomtask2
Aug 13, 2015 01:57 AM
mustangman65_79
Aug 11, 2015 03:17 PM
