Long time coming AKA My 91 Z28 Vert build thread
Old May 9, 2023 | 02:08 PM
  #901
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Long time coming AKA My 91 Z28 Vert build thread
Great idea. I remember that previous thread, though not the design.
A couple of questions.
Any idea how thick that master cylinder is on it's end? That's the backside of the bore. Just curious if it can handle the extra load.
Did you round the end of the boot to a smooth bullet nose-like shape to match that hemispherical depression in the end of the master cylinder (assuming it was was hemispherical casting shape?)
That's a good touch on the welder. The QA1 STB I have is also quite thin. Nice a light, but I would not attempt to weld on it. I did weld an air cleaner once, so maybe I could, but I'd be nervous!
Also curious about lateral movement when the chassis flexes. Your application probably won't suffer from that like my stock t-top car will. I wonder if there would be a way to integrate some side to side, or radial movement? Like the socket of a heim joint instead of s stud....think...think...think.
Old May 14, 2023 | 02:44 PM
  #902
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have no idea how thick the master cylinder is at the end there and I hadn't thought of that. It's a good cautionary point. I did smooth the end of the bolt into a round end that fit nicely inside the concave part of the brake master cylinder. It works but it's not a long term solution. A better idea would be to 3D print a plastic cap for the bolt so it wasn't steel against aluminum. You could also map a cap that went over the master cylinder end if you were worried about movement in other directions. I did burn through the STB because I assumed it would be 1/8". It was fine because I was able to fill it back up.
Old Mar 13, 2025 | 08:23 PM
  #903
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
...been nearly 2 years, in for some updates
aarivers
Members Camaros
25
Jun 11, 2014 08:05 PM
CYARS92
Sep 9, 2008 01:08 AM
nabisco
Aug 17, 2008 10:11 AM
SheldonZ28
Jul 27, 2006 05:23 PM
aaron7
Oct 10, 2004 07:19 PM
