I have a problem... my 1986 Trans Am interior cluster lights wont turn on
Old Apr 15, 2008 | 03:21 AM
bad T/A's Avatar
Car: 1986 Trans am
Engine: 350 V8,carburated
Transmission: 700R
Okay so my interior cluster lights wont turn on, on my 1986 Trans Am. Does any one have any ideas?
Old Apr 15, 2008 | 05:32 AM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
Re: I have a problem... my 1986 Trans Am interior cluster lights wont turn on
have you checked the fuse for it,i had the same problem awhile back and it was the fuse,i changed it and havent had a problem since,it should be labled "INS" or atleast it is on my iroc-z
Old Apr 15, 2008 | 08:51 PM
bad T/A's Avatar
Car: 1986 Trans am
Transmission: 700R
Well... I changed out my INS fuse and apparently its supposed to be a 5amp fuse... when I got under my dash I discovered that i actualy had a 10amp fuse in the INS fuse spot... could I have blown something else or is that even the problem at all?
Old Apr 15, 2008 | 08:59 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Yea, a 10 amp fuse in a 5 amp socket usually isn't too good..
Old Apr 15, 2008 | 09:01 PM
bad T/A's Avatar
Car: 1986 Trans am
Transmission: 700R
haha... yea I didn't think so either.
is there anything else that i could be due to the fact that i had a 10 amp fuse in a 5 amp fuse holder?
Old Apr 20, 2008 | 02:11 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
gonna sound dumb but it has happened to a few people including me on an occasion (sp?) sometimes when I'm cleaning the inside I end up rolling the dimmer switch down to nothing but don't notice it so I'd check that cause you never know.
Old May 8, 2008 | 04:16 PM
230 firebird's Avatar
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
Can i assume that the 10amp fuse was not blown?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
Exxon Limited
Aug 9, 2015 08:13 PM
