engine swap 350 to 454
I have had a 97 Trans Am with the LT1 350 for a few years, and it just isn't cutting it. I just bought a 81 GMC 1/2 Ton with a 454. I am gathering my money and getting ready to make the swap. I know the stock 6 speed has to go and that automatic will be the way to go. I also know that the suspension, brakes, drivetrain, exhaust, and rearend will all need to be beefed up. I am sure that there will be more work than that going into it also. I hope to have about $10,000 in the next couple of months to complete this. My problem is that I don't know what to get or where to get it.
I am looking for any advice that can be sent my way.
Car: 1988 Trans Am GTA
Engine: 383
Re: engine swap 350 to 454
Seeing as this is a thirdgen board ('82-'92) I'm pretty sure this will get locked. So hopefully I can get in here before it does. It would be MUCH, MUCH, MUCH, MUCH easier to just stroke the LT1. You could get a 383 or 396 stroker kit, make all kinds of power and not run into the fitment issues your are going to face putting a carb'ed motor into a 4th gen. DId you know you have to cut the top of the firewall to get the carb to fit? Your going from a small block to a big block, so the motor mounts will be different, clearances for exhaust, among many other issues!!
Save yourself the headache and buy a stroker kit!
Car: 1991 Firebird
Engine: 3.1L V6
Just beef up the LT1, $10,000 into the car the way it is now and you'll have MUCH greater power numbers than you will if you try to slap that 454 in there. Thread
theshackle
Mar 5, 2017 06:37 PM
