idk if my car is base or formula? need help
Old Mar 17, 2011 | 05:25 PM
flynnallthetime's Avatar
Car: 1987 firebird
Engine: v8 5.0L 305=]
Transmission: stock=/
Axle/Gears: stock=/
hey guys, im mike. i thought my 87 firebird was a base model, but my dad is saying it is a formula. its a v8 305 5.0 carb. he says bc it has the performance suspension that it is a formula need help thank you
Old Mar 17, 2011 | 08:03 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: idk if my car is base or formula? need help
it could be....need to check your RPO codes
Old Mar 18, 2011 | 01:07 AM
Car: 1987 firebird
Axle/Gears: stock=/
how would i check my rpo codes? what does that even mean?
Old Mar 18, 2011 | 02:58 AM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Look inside the center console there should be a sticker with a bunch of 3 digit codes those are rpo codes each code is an option your car came with. Look for w66 and ws6 also make sure your car's vin matches the vin on the sticker.
Old Mar 18, 2011 | 03:02 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Old Mar 18, 2011 | 03:11 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Check the codes, but it should say on the title for the car...?
Old Mar 18, 2011 | 12:01 PM
86ta-adf's Avatar
Car: 86 Trans Am
Are the wheels on it original? If they are what do they look like? Or you can do what everyone else says and check the codes haha.
Old Mar 18, 2011 | 03:59 PM
Car: 91 Trans Am
Engine: 355 TPI
i dont know if they did that between the firebird base and formula. i know they did for the trans am, i guess it depends on the state you live in but the title for my camaro says camaro z28 and convertable for body type
Old Mar 18, 2011 | 05:09 PM
AmorgetRS's Avatar
The Formula will not show on the title. The base model and the Formula were the same model, unlike the Trans Am.
Indicators of a Formula:
Power Bulge hood
16" wheels
wrap around rear spoiler
V-8 of some level (LG4, LB9, L98 for 87)
WS6 suspension (36mm front sway bar, 24mm rear is the easiest way to tell)
No ground effects (no base model had ground effects in 87, though, unlike 89-92)
Old Mar 21, 2011 | 10:22 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
if it has ground effects its not a formula, if it dosnt well then it is
Old Mar 21, 2011 | 10:58 PM
AmorgetRS's Avatar
That isn't true. You could get a LO3 or LG4 Firebird w/o Ground Effects that wasn't a Formula.
Old Mar 22, 2011 | 08:12 AM
Car: 91 Trans Am
Engine: 355 TPI
i was gonna say that lol.....there is a difference between the base model and the formula model even though they both have no ground effects
Old Mar 31, 2011 | 08:54 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I'm curious what the verdict was here... did u check the RPOs?
Old May 15, 2011 | 03:22 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
aaaargh.
1) Check the SPID sheet in the center console (1987-1991) or the rear storage area on LH side (1991-1992) Look for WS6 or W66 (Formula)
2) If no SPID, look at the drivers door tire information, if it states 245-50R16 then its a Formula.
3) Look at the front sway bar, if it is 36mm thick then there is a chance its a Formula (can be easily changed)
4) If you have ground effects it is NOT a Formula, However some Base Firebirds in 1991 and 1992 had them...
5) Since you have a 1987, then NO Base firebird or Formula had Ground effects, it was not an option until 1988, when there was a Z20 option which was more of a throwback to 2nd gen wheel spats, in 1989 The base firebird had an option to have Trans Am ground effects, but kept the base hood and spoiler... this trend was kept until 1992 as an option.
6) ALL Formulas got the Aero Spoiler, Bulge hood, 16" Wheels, V8, WS6
7) Base Firebirds from 1987-1992 had either a V6 or Base V8
Old May 15, 2011 | 08:20 PM
karl's-92'-z28's Avatar
Car: Too many cars
Post pics of you car...
Old May 15, 2011 | 08:34 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Power Bulge hood
16" wheels
^My title doesn't even say my car is a camaro, just says its a chevy coupe,lol.
As for the Ops ?s I would just decode the VIN plate personally, parts can be changed or added, but the VIN will stay the same.
Jorlain
Aug 24, 2022 05:11 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
B_Dubya
Aug 26, 2015 05:09 PM
Fronzizzle
Aug 9, 2015 01:15 PM
