1985 Firebird
Old Mar 12, 2012 | 12:16 PM
baileysup's Avatar
1985 Firebird
Hi everyone. I just picked this car up a few days ago, and thought I'd share some pictures of it. The car is in pretty good shape with zero rust underneath. 84,000 original miles. No Trans Am here, just a plain bird, but it is a factory 5 speed LG4. This car is 100% reliable, and healthy. I love it
Attached Thumbnails 1985 Firebird-004.jpg   1985 Firebird-006.jpg   1985 Firebird-009.jpg
Old Mar 12, 2012 | 01:14 PM
baileysup's Avatar
Re: 1985 Firebird
More pics. This will be my daily driver for the summer. First thing will be an oil change followed by all other fluids (except brakes). I'm thinking of just staying with a good conventional oil.
Old Mar 12, 2012 | 02:02 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
Re: 1985 Firebird
that looks great! how much did you pay for it
Old Mar 12, 2012 | 02:22 PM
baileysup's Avatar
Re: 1985 Firebird
I paid $2400.
Old Mar 12, 2012 | 02:27 PM
baileysup's Avatar
Re: 1985 Firebird
needs a fender, I think (dinged up). Has anyone heard of epoxy primer, and Duplicolor Color Match? I have a rust spot that I want to handle (you can see at bottom corner of driver side door). Thanks, and I'm glad you like it
Old Mar 12, 2012 | 02:39 PM
baileysup's Avatar
Re: 1985 Firebird
The horn doesn't work. There is a fuse blown, but I'll replace it. The wire under the horn cap looks good. There are wires sticking into the fuse box (maybe for radio?) Should I just pull them out?
Old Mar 12, 2012 | 02:55 PM
Mudluver27's Avatar
Car: 1988 Firebird
Transmission: 6-speed
Axle/Gears: 2001 ss 10 bolt 342's
Re: 1985 Firebird
Looks just like my 88. Like the look without a spoiler. Im considering that if I cannot find a reasonably priced wrap around spoiler.
Old Mar 12, 2012 | 03:06 PM
baileysup's Avatar
Re: 1985 Firebird
I have some more interesting pics for you guys. It looks like He has a line plugged up. What should I do with this, as I have the stock air cleaner. Please help. Should I use that line and put the stock air cleaner on? what is best for the engine? thanks
Old Mar 12, 2012 | 03:08 PM
baileysup's Avatar
Re: 1985 Firebird
I love it without a spoiler. You don't see a clean trunk that often. different
Old Mar 12, 2012 | 03:11 PM
Mudluver27's Avatar
Car: 1988 Firebird
Re: 1985 Firebird
This is why I went to LT swap. NO damn vacume lines... wow what a cluster "F"...
That damn 350 tpi setup was such a rats nest. Hated even looking under the hood.
Old Mar 12, 2012 | 03:26 PM
baileysup's Avatar
Re: 1985 Firebird
Holy Cut AC compressor lines. that what it is? That line is hacked WTF smh. It idles high too. I think maybe cause the stock air cleaner/fittings are not equipped, ey???
Old Mar 12, 2012 | 04:07 PM
baileysup's Avatar
Re: 1985 Firebird
I just found some new pics. Is this some stuff or what? WS6, or just Rally suspension? Did someone just put that piece in there?
Old Mar 12, 2012 | 04:20 PM
Mudluver27's Avatar
Car: 1988 Firebird
Re: 1985 Firebird
I have that same piece of trim. Mine is a formy 350. Also had a friggin camaro center console and 82-84 taillights with formula center piece lol... hate jerkoffs that just piece together a bunch of crap. Now about the "performance" tag, I have no idea.
Old Mar 12, 2012 | 04:24 PM
baileysup's Avatar
Re: 1985 Firebird
looks like a junkyard piece to me. They didn't even bother to wipe off the crayon/chalk. WTF. SMH. I guess I have a WS6 dash panel. great
Old Mar 12, 2012 | 07:53 PM
baileysup's Avatar
Re: 1985 Firebird
I just took it out today. Whenever I drive it, all doubt is eliminated. So much fun to drive.
Old Mar 15, 2012 | 04:19 AM
baileysup's Avatar
Re: 1985 Firebird
well, the time has come to do some work on the bird. This Sunday I will be doing an oil change with a K&N oil Filter and some good conventional 10w30 (maybe Penzoil). My buddy told me that if I go to synthetic oil, I can not go back unless I change the oil pickup (something about metal particles in the pickup.....engine go boom....ect). I need to research more about this, but money is tight, so a clean conventional is 10x better than any dirty oil. I will also be timing the car because it has a high idle at around 1100 RPM, so i figure to check timing first, but something tells me its the carb, cause if I barely crack the throttle open the RPM drop as if the car will stall, and then go back up to 1100 RPM. It will continue to go up and down with my foot resting on the gas pedal, but 1/8 to full throttle seem to function flawlessly. It also feels like it has a slight miss. It's hard to feel but It's there. I will do a fuel filter as well. The coolant will be flushed eventually but I don't think I will have the funds to do it this week. I will be installing a Mr. Gasket 160* T-stat, so that the engine runs cooler. Eventually the rear end fluid will be changed out along with the Trans Fluid. What are your thoughts on running synthetic trans and rear end oil, and what brand of oil would you recommend? It is a 5 speed trans ( m5?). Also I need to figure out why the horn doesn't work. I will replace one blown fuse, and check the horn relay. I guess that about covers it for now. I'll you guys posted on everything. Also, if anyone has any input on what I said, it would be greatly appreciated. Thanks
usafirebird
Exterior Parts for Sale
Oct 19, 2017 02:00 PM
Reddeath210
Oct 6, 2015 08:20 AM
Ducati900ss
Sep 2, 2015 09:05 AM
Thornburg
Aug 27, 2015 11:34 PM
Thornburg
Aug 26, 2015 07:22 PM
