Is the vin decoder right?
Old Feb 28, 2016 | 06:48 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Brake - front:
Disc
Brake - rear:
Disc
Brake system:
Non-ABS
Consumption in the city:
16 miles/gallon / 14.7 liters/100 km
Consumption on the highway:
26 miles/gallon / 9.0 liters/100 km
Curb weight:
3318 lbs / 1508.2 kg
Driveline:
RWD
Engine series:
V-8 5.0L
Engine type:
5.0L V8 OHV 16V
Fuel tank:
15.50 gallon / 58.7 liter
Fuel type:
Gasoline
Overall height:
49.70 in / 126.2 cm
Overall length:
190.50 in / 483.9 cm
Overall width:
72.40 in / 183.9 cm
Standard seating:
Steering Type:
Recirc
Tires:
245/50R16
Trim level:
Formula Coupe
Turning Diameter:
32.60 ft / 9.9 m
Wheelbase:
101.00 in / 256.5 cm
Old Feb 28, 2016 | 06:49 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Re: Is the vin decoder right?
I ask this because I have drum rear brakes. This is a 88.
Old Feb 28, 2016 | 06:56 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Brakes won't show up in your VIN.
If you post the vin here one of the guys may be able to get the info off comp9 that breaks out all of the RPO codes.
Old Feb 28, 2016 | 07:05 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Thanks that will help because I have no rpo codes have looked in all places. 1G2FS21F2JL######
Charlz B.
Jan 21, 2017 12:41 PM
86_firebirdTA
Feb 19, 2016 05:06 PM
HamSpiced
Mar 12, 2004 08:09 AM
junkyarddog
Apr 29, 2001 09:50 PM
MikeS
Oct 22, 2000 09:52 PM
