Just bought her a few weeks ago Still have to change out the heater core, but it's still winter here so can't really drive her much anyways. Got 17" Hawks gold wheels on the way for her as well.
mine is white, and im thinking of sprayin it black since they look so dang good in dark coloring...
If you can afford it go for it. It's hard to tell in the pics, but in the sunlight it has a gold sparkle in the paint, I believe the color is called Rootbeer.
Car looks great good luck with it, I had to do my headliner two years ago also, I did it myself bought the foam backed headliner, pealed the old cloth off and wire brushed off the old foam, I fiberglassed the board to make it a little stronger than it was, not sure if anyone ever recommended or did it like that but man if looks like factory and adding the glass gave it just enough rigidity cause the board felt like it would snap in two if you held it the wrong way.
I did this too, well something similar. I cleaned the substrate with a nylon bristle vacuum attachment then coated the whole thing with fiberglass epoxy, like probably a quart and a half. I did put some glass mat in weak areas like the corners. Once it had cured I could probably use it a battle shield. Make sure you have a couple helpers to apply the new fabric though, drop it down straight and easy. A very light touch to secure it.
