Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
welder for sfcs
Old Dec 12, 2005 | 04:52 PM
I-rocin's Avatar
Car: 87 iroc-z28
Engine: vortec tpi 350
Transmission: built 700r4
welder for sfcs
i need an experienced welder to weld in my sfcs, will drive up to an hour and a half
i'm in the hampton roads area
Old Dec 12, 2005 | 07:51 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
how experienced?
Old Dec 12, 2005 | 10:15 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
My buddy Tyson at Performance Auto Fabrication in Glen Burnine MD. Just south of Baltimore. 45 minutes from the WW bridge with normal traffic. He charges $90 and does the best work.
Old Dec 13, 2005 | 04:36 PM
I-rocin's Avatar
Car: 87 iroc-z28
how long of a drive is that from hampton roads/richmond area?
Old Dec 13, 2005 | 05:39 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
if there is no performance shops around try a local muffler shop. they should be able to do that with no problem. i know that ELD performance from crofton maryland opened up a shop in richmond so try looking them up they are a performance shop.
this is ELD sites i didnt see a number for the richmond store but i ma sure if you call the crofton line they can connect you.
http://www.eldperformance.com/xindex.html
Old Dec 13, 2005 | 09:37 PM
Dialed_In's Avatar
I would strongly consider staying away from ELD. Being a member of the performance industy myself, it would be unprofessional of my to say why or say anything negative about another company, but heed my advice.
Old Dec 14, 2005 | 03:32 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
i agree totally but i dont know of any other shops in richmond area so thats why i threw that in there
if you want to drive all the way up here to annapolis maryland then i can weld them in for you but thats kind of far for sfc
Old Dec 14, 2005 | 05:37 PM
DucksChevy's Avatar
Car: '89 IROC-Z Convertible
ELD here in Richmond closed awhile ago.
Old Dec 14, 2005 | 07:33 PM
Steve86TA's Avatar
Car: To many to list
Cant imagine why
Old Dec 14, 2005 | 07:37 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Having Tyson do the work is more than worth the drive. He does top notch welding work.
Old Dec 15, 2005 | 08:09 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
I will be in Richmond the week after christmas and could do it for you but I can't put the welder into the car with my suitcases and crap.
Old Dec 16, 2005 | 06:20 PM
mjustdie's Avatar
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
i weld professionally for a living and i must say DO NOT just go to an exhaust shop to get your sfc's welded. 9 times out 10 they are using puny 110v welders. go to a shop that uses the big toys. this way there's less of a chance in a weld cracking or looking like crap. i personally hate using anything under 220v. so, if you can find a decent welder, machine, and shop, go there. you're honestly better off finding a fab shop locally and speaking with someone there.
Old Dec 16, 2005 | 07:54 PM
I-rocin's Avatar
Car: 87 iroc-z28
could anyone do it over christmas break if i dropped my car off for a couple days? wheres teh best shop in marlyand
Old Dec 17, 2005 | 05:36 PM
Dialed_In's Avatar
YES.
Tyson @ Performance Auto Fab.. 443-277-6800. Call him up. He can have it done in a little over an hour. $90. Probably 45 mins. from where you are.
Old Jan 14, 2006 | 06:42 PM
I-rocin's Avatar
Car: 87 iroc-z28
YES.
man, tyson does some good work. i just got home from there, everything looks great, it w3as well worth the 3 hour drive
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
mrdevontay
Sep 2, 2015 08:04 PM
