Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Brand new GMPP crate engine for sale in MD/DC/VA....
Old Dec 14, 2006 | 04:59 AM
just2fast's Avatar
Chevy 350 crate engine for sale
Brand new(still in the crate)
-330 hp
-380 ft./lbs.
-4-bolt main
-Vortec heads
-Holley 600 cfm
-chrome valve covers and timing cover
Asking $3,500 for it.
More info.....
Big power, low cost.
GM Performance Parts brings us their lowest priced performance deluxe complete crate engine in the form of a 350 cubic inch HO with approximately 9.1:1 compression, 330 hp at 5,000 rpm and 380 ft./lbs. of torque at 3,800 rpm. These 4-bolt main engines have a recommended max rpm of 5,500. Dressed to impress with chrome valve covers and front timing cover these engines will look great between the fenders of your favorite street rod, muscle car or grass roots racer. These 350 HO are not intended for marine use and should only be used in 1979 and earlier pre-emissions street vehicles or any year off road vehicles. Parts used in this engine assemblies are 4-bolt main 1-piece rear main seal blocks, nodular cast iron crankshafts, powdered metal connecting rods, Dished cast aluminum pistons. Installed camshafts are hydraulic flat tappet with .435 in. intake lift and .460 in exhaust lift with duration at .050 in. for intake is 212 and 222 for exhaust with a 112.5 lobe centerline. Standard Morse link timing chains are installed. Cylinder heads are Vortec cast iron style with 64cc chambers; 170cc intake runners with 1.94 in. intake valves and 1.50 in. exhaust valves. Stamped steel self-aligning rocker arms are used for reliability. Aluminum dual plane with EGR capability Vortec style intake manifold with a Holley 600 cfm vacuum secondary with electric choke help feed the engines. Spark plugs, HEI distributors are included. Cast iron long style water pumps with standard "V" belt rotation threaded for 1979-89 power steering pump brackets. Standard 8 in. balancer and 12 3/4 in. flexplates, along with chrome air cleaner, and standard cast aluminum thermostat housings with driver side hose connection and a 180 degree thermostat. This kit also includes the oil filter, oil filter adapter, PCV valve, PCV hose, oil dipstick, and tube. Does not include starter, fuel pump, fuel pump push rod, or the fuel pump adapter plate.
Old Dec 15, 2006 | 03:44 PM
just2fast's Avatar
ttt
Old Dec 17, 2006 | 09:02 AM
just2fast's Avatar
uppin
Old Dec 19, 2006 | 11:02 PM
just2fast's Avatar
ttt
Old Dec 21, 2006 | 09:31 AM
just2fast's Avatar
uppin
Old Jan 2, 2007 | 12:39 AM
just2fast's Avatar
PM me an offer
Old Jan 2, 2007 | 12:48 AM
just2fast's Avatar
PM me an offer
Old Jan 15, 2007 | 11:56 PM
just2fast's Avatar
ttt
Old Feb 3, 2007 | 02:47 AM
arnold's Avatar
-330 hp
-380 ft./lbs.
-4-bolt main
-Vortec heads
-Holley 600 cfm
More info.....
According to this article this engine will work in a 1991 RS Camaro and still pass smog. Is this just false advertising?
http://www.chevyhiperformance.com/fe...evrolet_camaro
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
