Bought a 89 IROC
Subscribe
Mar 14, 2007 | 12:49 AM
Here are some new pictures I took today.
http://img233.imageshack.us/img233/4205/irocbackik7.jpg
http://img233.imageshack.us/img233/3461/irocsideeu2.jpg
http://img233.imageshack.us/img233/276/quartergn5.jpg
Here is a pic of the dent in the quarter. Nothing major. The girl said someone hit her in a parking lot while she was inside the store.
http://img233.imageshack.us/img233/9...ontirocmb0.jpg
I got it for 500 bucks. All that was wrong with it was the battery was old and wouldn't hold a charge. Hooked my "Jump Box" up to it and it fired right up.
L98/Auto. Body has some surface rust, and the driver's door has sagged really bad. The handle on the driver's door has actually ripped the door skin where the handle has been pulled hard, because it's sagged. I'll be getting an entirely new door to replace that. Pretty much take a wire brush bit on my dremel and knock off all the surface rust and hit it with some primer sealant till I get it ready to be painted. I'm excited....
Reply 0
Mar 14, 2007 | 11:04 AM
good deal !
mine used to look just like that ,now its primer grey .I will be building a 92 rs soon and will be using the iroc for parts as the under side is rusted .let me know if you need anything I'll see if i can help.again great deal there .
Reply 0
Mar 15, 2007 | 12:22 PM
Thats a sweet deal!
Reply 0
Mar 15, 2007 | 11:55 PM
bushings might do the trick for the door
forgot to ask what size engine and awesome deal also is it rear discs
Reply 0
Mar 16, 2007 | 10:43 AM
I would just replace the Pin and bushings but the outside handle has ripped the door skin and there is some rust along the top edge. The ripped door skin sealed the deal though. I called the local salvage yard and they said I could get it for 50 bucks. So I'm going to get the whole door and hinge assembly.
Reply 0
Mar 16, 2007 | 10:45 AM
oh then good call
Reply 0
Mar 16, 2007 | 07:27 PM
That's a Badass deal. Why cant't I find an IROC for $500 of a Vert RS for $800
Anyhow check out the swap meet thread for some local parts.
Reply 0
Mar 18, 2007 | 01:33 AM
Congrats and welcome to TGO Calaban007.
His first post says it's an L98 (350).
Reply 0
Mar 18, 2007 | 10:21 PM
Amazingly, I hadn't checked about it having rear disc brakes, even though a guy at work asked me about it. I hadn't even thought about it since.
I just went and looked. Yes, it has rear disc brakes.
I do have a question though. Where is the sticker with the RPO codes? I wanted to know what kind of gear was in it. Thanks a lot.
Reply 0
Mar 18, 2007 | 10:24 PM
2.77 if its stock, the discs make it quite nice for breaking also when you are on the home page of thirdgen.org look on your left and you will see camaro data go to your year and it will have tons of info. also rpo code in the center console.
Reply 0
Mar 18, 2007 | 10:34 PM
I also didn't mention that they had a lot of replacement parts they never installed. They had a set of replacement hood louvers still in the original GM packaging, a starter, a new console (which I really only need the armrest), dash pad (cracked but not as bad as the original), and a she gave me the car cover as well. Which I'll keep on it, hopefully it won't get any worse before I can started on it good. Hopefully this week if the weather cooperates.
Oh, and a set of replacement factory fog lights. The original Driver's side light is broken.
Reply 0
Mar 19, 2007 | 05:43 AM
You got a hell of a deal man good find!
Good luck with the car keep us posted and have fun with it!
Reply 0
Mar 19, 2007 | 01:19 PM
Wow thats a good deal.
It's what i originally paid for mine, but after a few dumb moves it cost me 1200 bucks to get to running condition again lol.
Was a black, hardtop L98 with the 3.27 9Bolt disc rear.
I already miss my Z.
Reply 0
Subscribe
