Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Installing a new clutch.
Old Sep 16, 2007 | 07:20 AM
midnightebwx's Avatar
Car: 1984 TA
Engine: 355 SBC Mild cam.
Transmission: 5 speed
Axle/Gears: Stock
I'm gonna need a new clutch. trying to do this on a tight budget. how much of a pain is to change on my 84 ta. Also I an thinking about putting on a new flywheel. Can i settle for the good old auto zone 60 buck stock or should i go ahead and spend alittle more. It's on my daily driver and it doesen't get drivin really hard..... ok maybe a little hard sometimes.
Old Sep 16, 2007 | 11:25 AM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: Installing a new clutch.
If it doesnt get driven hard that often just put in a stock replacement. Clutch Kits are cheap like $100-200. Take your flywheel to a shop and have them resurface it.
Changing it out is pretty simple its all straightforward. You can bench press a T5, 6 bolts, DS, torque arm, Unplug 2 connectors(thinks thats all there is), remove the slave, pull the fork off the TO bearing. Lower X-member.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Bryan F
Aug 18, 2015 02:28 PM
