Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Can anyone recommend a good shop that has a frame rack?
Old Mar 26, 2008 | 05:15 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
I'm going to have some SFC's welded on my car soon, but I want to take it to a place that has a frame rack first to make sure it's perfectly straight and then have them do any straightening if it's necessary. Can anyone reccomend a shop? If they can weld them on while the car's still on the rack too, that would be even better. I'm willing to travel a distance too, if the place is really good.
Old Mar 27, 2008 | 03:52 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
Re: Can anyone recommend a good shop that has a frame rack?
try e&b auto body up in street on route 1 its right across from forge hill rd, about a half mile south of route 136, im pretty sure he had 2 or 3 frame racks the last time i was in there, and im sure they would weld in sfc
Old Mar 28, 2008 | 02:28 PM
huntman21014's Avatar
Car: 84 Trans Am
Engine: 350 mystery engine
Hey nothing to do with the thread but its good to know someone else lives in bel air lol. I thought I was the only one on here
Old Mar 28, 2008 | 07:41 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
I don't think you need a frame rack, rather just a drive on lift. It's my understanding that the car just needs to be sitting level. I'm going to install my using the alignment rack at work.
Old Mar 29, 2008 | 10:06 AM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
yea but he wants to check and make sure that the frame is straight before the sfc get welded in
Old Mar 31, 2008 | 08:41 PM
83 Crossfire TA's Avatar
Unless you’re pretty sure that it’s messed up it’s probably a waste of time. Get a plumb bob. Drop it off each fender lined up with each hub, measure in to the hub and mark it on the floor. From that you should be able to get pretty reasonable wheelbase (on both sides) measurements showing that it’s not banana shaped and diagonal measurements showing that it’s not just plain crooked. If I remember right factory tolerances are something on the order of ¼”, and I’ve seen undamaged cars as bad as almost 3/8” off. Depending on how **** retentive you are, measuring this way you can probably get within 1/16”-1/8”, which is more than close enough to tell if the car is messed up.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
gta90
Sep 15, 2015 04:00 PM
