i am pissed at my car
350 .040 over
protopline vortec heads
extreme energy 274 h cam
holley 3310 750vs
slp 1 3/4 header
performer rpm intake
t56 / 3.23s
14.2@98mph...wtf?
not sure wtf is going on but i had to dump it from 3000rpms to get that et
that combo is good for 400hpo easy and 98 mph is no 400hp
holley 3310 750vs
slp 1 3/4 header
t56 / 3.23s
14.2@98mph...wtf?
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
very strange my auto runs mid 13's; that being done on slicks but your combo should at least get you there? is your ignition and tuning up to snuff
i have spohn torque arm,lower control arms, sfc and running on comp t/a's...my 60ft sucked but the car should have way more power then this...
ignition is a summit hei with blaster 2 coil and digital 6 ignition
i am thinking my carb needs to be rebuilt..the secondaries may not be opening
my next run will have a flowmaster 3 inch cat back, drag radials and the car redone...if that dont do it i will be really pissed
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
355, 10:1 comp, cast hp heads, performer intake & 650 edelbrock carb, balanced and blueprinted, i ran 15.2 as a best with 3.42's and a th350...feel lucky....feel real lucky...
did you degree the cam?
somebody on the drag racing board was telling me that the secondaries did virtually nothing and were only responsible for a few tenths, i dunno how true that is.
I've looked at everything i can think of, it's not running hot, compression showed 180 in every cylinder (+/- 4), idle is good, no hesitation, no stumble, plugs look good and are toward the rich side, good spark....i'm lost as to why it runs so slow, it feels strong, it pulls strong
Engine: V8
yea, it didn't sound right to me either, but i believed it based on who it was comming from...
https://www.thirdgen.org/techbb2/sho...hreadid=178589
Stephen 87 IROC said it, he's a moderator and campaigning a ten second car with 520 rwhp...a reliable source in my opinion
i think that your carb is to big for your engine....i have pretty much the same setup as you. last night i took off my 750 vs, and put on a 650 dp, gained about 40hp, huge difference, and its not even tuned yet.
see if you can borrow a smaller carb from someone, and see if it makes a difference.
when my 750 secondaries had a bad diaphram, i only gained around 3 tenths back....that would mean a 13.9 for you and still not as good as your engine should be doing.
Linson
Aug 21, 2015 02:12 PM
