Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
350 shortblock still needed!!!
Old Dec 25, 2003 | 07:28 PM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
I still need a 350 complete shortblock in good shape with either standard or .040" bore max. Need no more than 9.7:1 CR with 64cc heads. Anyone has anything or know of anything let me know please!!!!
Conner
Old Dec 27, 2003 | 09:07 PM
restoIROC's Avatar
Car: 2000 Monte Carlo SS
Engine: 3.8 V-6
350
yeah...I have a 350 out of a 78 truck. It is a two bolt main and all together. All I have done is pulled the heads off and had them done. I also pulled the oil pan and got a new one- I would sell it for $300 if you came and got it in Iowa City, Iowa.-
Ben
Old Dec 27, 2003 | 11:41 PM
Car: '86 IROC
How many miles does the engine have on it and whats the condition? Would it need a rebuild?
Old Dec 28, 2003 | 12:39 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
You do realize you could get a running junkyard 350 for the same price, and add rings, bearings and seals at a minumum.
Try Sturtevant auto salvage....I was real close to buying a complete Caddy 500 for 300 bucks from them...complete with a 30 day warranty. And they would run it for me on a stand!! I'm sure a 350 would be at least the same price. Maybe cheaper.
I'd never go through the hassle of just installing a short block w/o going over it first. Too much work later on to find out you have a bad bearing....
Just my opinion....flame suit on!!!
Old Dec 28, 2003 | 12:48 AM
Car: '86 IROC
Yeah i thought about getting one from the junkyard- didn't know they offered a warranty or anything, i'll go check some out around here. The thing that drew me away from them is that (like most engines there i would guess) if it needs to be rebuilt, it will most likely need to be machined/bored, and then i would have to spend another $300 on pistons and all that little stuff that adds up to a lot. Do you think i should just get one from a junkyard? I'm really on a pretty tight budget so im trying to get my 380hp combo the cheapest way possible but still be reliable. thanks for the help!!
Old Dec 28, 2003 | 12:49 AM
Car: '86 IROC
And where is Sturtevant auto salvage?? Got a phone number handy??
Old Dec 28, 2003 | 12:53 AM
funstick's Avatar
Im near pontiac in michigan. I have a 020 4 bolt 2 peice seal block rods and pistons.
The rods are stock pinks with ARP bolts.the pistons at 020 over are TRW forged flaptops with 4v relifes. With 62cc heads it 9.8:1
motor died of flat tappet cam death ugh. but its since been diassebmled and cleaned and stoed for a long while now. A crank kit ( i have a good core ) and it could be up and running no trouble.
Djfreggens@aol.com
Old Dec 28, 2003 | 01:52 PM
Confuzed1's Avatar
Car: 83Z28 HO
As I recall while asking about the 500 CID caddy engine, they wanted 250 bucks - no warranty, or either 300-350 for them to put it on thier stand and run it. That's the only way they'll give you a 30 day warranty...
I know what you mean about getting one from a junkyard though, and some may need to be rebuilt. Not all the engines they have are like that - some were pulled out of cars that were totalled - and they ran fine before that. I'd ask them about something along those lines with relatively low milage. Just an idea. I PM'd you the phone number.
Good luck - but 380 HP will be hard to get cheap....or at least 380 RELIABLE HP....
Old Dec 28, 2003 | 11:35 PM
restoIROC's Avatar
Engine: 3.8 V-6
ok...
I hope I clear up so questions....
The motor is out of my girlfriend's uncle's pickup. The motor was rebuilf is 1997, and then parked in 1998 because he got a new truck. Unfortunately the truck rotted away with time so last year I took the motor out. I pulled the heads and oil pan to hopefully get a sense of the shape of the motor. While I am sure the motor has less than 20,000 miles, everything still had oil, no steel shavings, or rust. The oil pan was removed and I am sure that it would run fine. If you don't want it, that is fine......but here in Iowa I have checked around and it is harder to find a newer running 350 for less than $450. Motor has a new oil pan and heads are bare but redone. Can give you those or stock heads that have been removed whole.
I hope I helped-
Ben
Old Jan 4, 2004 | 07:33 AM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Well
I have a 383 short block for sale. 10.9 compression with clevitte bearings and scat crank. I have over 1000 in rotating assembly and 800 in machining. Its been decked, cleaned, magnafluxed, blanaced, polished crank and bored. It is a 4 bolt out of 1971 Cargo van. The block was in awesome condition before the stroker kit and I am rebuilding it again before I sell it. Comes with pan and a brand new timing chain. I will throw the balancer in but I think the chrome timing cover leaks from the crank seal. I think I might get a plin jane timing cover. But will be willing to part with her fresh on the stand for 1,000 bucks which isn't a bad deal.
Old Jan 4, 2004 | 07:47 AM
Deimos140's Avatar
Car: 91
oh yeah
It also ran a best of last year of a 12.22. This including driving up to the track having five minutes to race and driving home after two trips down the quater, but doing a power steering delete, and electric water pump, she got in to the 11's.
IROCZ1989
Jan 24, 2016 03:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
