Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Traction! What is that?
Old Feb 22, 2004 | 12:45 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Well people I have serious issues here now. I drove the car for the first time today. I am excited and worried all at the same time.
I give it the gas(about a quarter peddal) and nothing but tire spin.
After It finally gets going and I idle to about 45 or 50 I mash on it and nothing but tire spin. Im thinkin sand bags or something for help. I've got money for suspension mods just need some help buyin the right stuff.
The car is d*mn scary to drive. It scream's like no other. I love this car!
Old Feb 22, 2004 | 03:20 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I wish I had that problem....maybe different tires would help.
Mostly I'm wondering where you get gas for a 13.77:1 compression ratio?
Old Feb 22, 2004 | 03:34 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Let me guess hm............ either Car Shop or what is that a Phillips 66 down on State St. in Bettendorf, does he still let you put it right into the car
Old Feb 22, 2004 | 03:52 PM
Car: FBODYS
Engine: ALWAYS 8'S
Yes phillips 66. I bought it when I was at work with a gas can. I love the smell of this stuff. It makes me crazy. For example: I went out and bought another third gen this afternoon. 89 RS T-tops. I had my eye one it for a couple days. Thought I needed another daily driver. I can always throw the Goodwrench crate motor from the wagon in. I am having a GREAT weekend. Just thought i'd share the good news with everyone.
The RS needs some minor work but I have most of the parts layin around. So it shouldn't be a big deal.
One more F-body has a good home!
Old Feb 23, 2004 | 08:06 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Transmission: fairbanks turbo350
If you'r not running sticky tires its going to do that. i have the same problem on the street. get some M/T et streets and you wont have that problem, but you will have to do a burnout first to heat them up or they will spin to.
Old Feb 24, 2004 | 01:01 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
From the sounds of it, it seems like u have have stock suspension? Well the first place to start is adj. Lower control arms, adj. panhard bar, and adj. torque arm. These will deffinatlly make u hook up. then get some better rubber on there. Also u better get some Sub-frame connectors on there or u'll twist ur chassis. Nice soundin motor though, I'm fightin the same proble u are...no matter the speed, put it to the floor and tire spin Woohoo. But tire spin sux
Jason
Old Feb 24, 2004 | 01:23 AM
Car: FBODYS
Engine: ALWAYS 8'S
Thank you for the responses. I am still runnin' completely stock suspension. The car was originally a V6. That is most of it's problem.
I want to buy the right stuff the first time. 355SS gave me some pointers on Sunday but i'm blind as a bat(can't weld) so I am shopping for the best options.
As for tires, i'm runnin' the same junk the wheels came with(dunlop garbage performance radials). I will have new rubber soon. This set is just to keep the car off the garage floor.
Old Feb 24, 2004 | 10:00 AM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
http://www.jonaadland.com/Z28/Mods/L...minumLCAs.html
http://www.jonaadland.com/Z28/Mods/PHB/AluminumPHB.html
Kevin here are the links I was telling you about for making your own bars. Get the rear control arm relocation brackets I gave you plans for on your car. Don't you still have the open diff in your car if so you need better tires and a posi. Don't forget the stb, subframes and the torque arm. When you pick out your parts give me a call if you want to talk about them.
Brian
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
