Instrument cluster changeout
Car: 1986 WS6 T/A
Engine: 383 stroker
My 86 T/A came from canada and the instrument cluster is all in metric, I recently got an americanized one and was wondering if it's a simple change out or does some sort of conversion have to be done?
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
As long as the new cluster is electronic, it'll plug right in. The only things that might be out a bit would be the coolant temp and oil pressure gauges. You'd have to do the english-metric conversion on paper and see how close the markings are on them - there are a couple different 'ranges' for the readings on the faces.
Car: 1986 WS6 T/A
Engine: 383 stroker
Just changed it out, was alot easier then I thought it would be, only took like 30 minutes. The new one works great and all the gauges seem to be accurate.
James Sutton
Sep 23, 2015 01:56 PM
