Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
rear end problems again.......
Old May 1, 2004 | 07:15 PM
pskel350's Avatar
alright guys, its a shot in the dark, but here it goes......
for some reason, the shop that built my 4.10 rear end last fall put in a 2 series posi and gears. the 4.10's are to much gear for my personal tastes on the street, very hard to keep the tires planted.
any body interested in a posi 4.10 gear setup? any body want to trade me for a 3.73 posi, 3 series?
this setup has very few miles on them, less then 2k miles....
Old May 6, 2004 | 07:12 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Are they 26 or 28 spline? What kind of posi is it (clutch, cone, or PowerTrax)? Does it have alloy axles? Is is completely rebuilt?
I have a 28 spline, 3 series 3:73, Gov-Loc diff, with Moser axles that is completely rebuilt. May consider trade.
Old May 7, 2004 | 12:34 AM
pskel350's Avatar
26 spline, auburn posi (clutch style), richmond gears.....i think they are new axles, dont really remember though. all new bearings, seals, etc.....
Old May 8, 2004 | 01:48 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
If they were 28 spline I would consiter it. I need to keep the 28s.
Old May 8, 2004 | 06:52 PM
Kandied91z's Avatar
possibly...would this work in my stock 10 bolt carrier or no? i have the gm 3.73 setup with about the same miles but my miniram is very low on torque in low end so i wouldn't mind trying the upper.
Old May 9, 2004 | 12:19 AM
pskel350's Avatar
the gears will not work on your current posi Jeff, the only way it would work is if all the inside parts, including axle shafts, posi, gears, etc were taken out of mine and put in yours, and vice versa.
the 4.10's are nice, but a little hard to control sometimes with my 5 speed. they would make your engine rev a little more at high way speeds. at 75mph i am at 2500rpm's. so with your 700 it would be a little higher i do believe.....
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
