Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Work without a cat in illinois?
Old Jan 5, 2005 | 06:11 PM
LD1985's Avatar
Car: '91 RS, 1994 Honda Accord LX
Engine: 3.1
Transmission: Automatic
I just got a 91 camaro without a catalytic converter....Someone cut it off a long time ago, just a straight pipe now...I need a little exhuast work done....Will a muffler shop work on it without the cat? I live in illinois.....
Old Jan 6, 2005 | 01:35 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I think they will. But they won't replace that pipe you have installed in the place of the CAT....if the repair work involves that - I think they'd only install a convertor. But it's just a guess.
Old Jan 6, 2005 | 05:30 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Confuzed1 is close.....
In Illinois, a shop that does exhaust work is "required" to replace any type of cat bypass pipes. There are some pretty hefty fines for them if they put an exhaust on it and don't make sure it has the emissions stuff hooked up. Most shops don't have a problem working on them tho, because it is never really enforced. I have a full true dual exhaust behind the dual cats on my car, but could have had them out. Call the shop first and tell them your story. Most that I have dealt with have no probs. If they do, don't go there.....
Old Jan 6, 2005 | 08:52 AM
Confuzed1's Avatar
Car: 83Z28 HO
Well, there ya go.....I've heard of a couple places around here in WI. that will put a complete exhaust on for you without a CAT- but you won't get a reciept, no warranty and cash only.
Old Jan 8, 2005 | 02:16 AM
911rsq's Avatar
Transmission: yes
Pretty much same thing here.... They just have to be careful cause it gets expensive if they get caught.
Old Jan 8, 2005 | 02:09 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
most of the shops around here will only talk to you in person about it.
Old Jan 11, 2005 | 08:41 PM
Roadvoyeur's Avatar
Car: 1987 Camaro Z-28 IROC
Engine: 5.0 305ci TPI
Work without Cat
I know a guy up here in Wisconsin, Milton area who does custon exhaust work..He is the best around and works out of his house..He does guarntee his work,,some of the best welding done I have ever seen..He did my 87 IROC, installed SLP headers, removed the A.I.R, removed the cat, and ran 3" stainless back to the flowmaster, then duals out the back..I have had so many compliments on the system, even at car shows, the judges like it too..Most shops will not install a new exhaust system on your car without the cat..Its against the law in most states..If you want this guys phone number..just give me a holla..
You will love the work this guy does...He can do work for SHOW, RACE, OR STREET... You just tell him what you want..You won`t be disappointed..
Old Jan 12, 2005 | 06:21 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
when i had my el camino noone would touch it unless i gave the okay to put a cat on it. i ended up getting an exhaust guy to do it on the side out of his garage for me. legally they can't as others have explained.
i noticed that you are in urbana. do they have emissions controls there? when i went to school in macomb they had nothing at all and noone had to worry about restrictions. its mainly up here in the big city area where emissions is a primary concern. its not a state thing its a city/county thing.
Old Jan 12, 2005 | 07:19 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
ha ha just tell them it's for off road only use. leave it there and payfor it, tell them you will pick it up after hours when you get your trailer
there is nothing wrong with doing that to a "off road car"
Old Jan 13, 2005 | 01:22 AM
911rsq's Avatar
Transmission: yes
Originally posted by 88 350 tpi formula
ha ha just tell them it's for off road only use. there is nothing wrong with doing that to a "off road car"
Old Jan 13, 2005 | 01:28 AM
Confuzed1's Avatar
Car: 83Z28 HO
Sounds like a good plan! But take your plates off while it's on the rack!!
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
89gtaforsale
Aug 24, 2015 09:32 PM
