Whats it take to get an F-body to 2800-2900 Lbs?
Car: Black 1984 Mazda Rx7
Engine: SBC
Transmission: WC T-5
Axle/Gears: 4.10 LSD
What kind of weight mods does it take to get a Fbody to 2800-2900 Lbs? (3000-3100 with me in it) Is it possible without ripping up the interior and still having a street car?
Chris
Chris
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
you would have to do alot of work to a car with a full interior to get to 2800 lbs. youd have to get alot of lightweight parts like a fiberglass hood and probably lexan hatch glass, lighter wheels, replacing alot of the steel parts with aluminum, like the radiator, heads, electric water pump, things like that. other things you could do with a full interior would be to get 4th gen seats and put 3rd gen tracks on them, get the aftermarket carpet that is lighter than the stock carpet
its pretty tough to get a 3rd gen to 2800 lbs anyway, to get one that light most people would remove alot of the stuff that arent 'necesities' but make life alot easier like headliners, air conditioning, etc..
i bet you could make a street legal thirdgen with a full interior to 2800 lbs, but it would take alot of hard work and probably alot of time and money to go along with the hard work
I just swapped out my steel inner bumper front bumper on my Trans Am for an aluminum one. after I got the old one out I weighed the 2 of thme with the impact absorber still attached to both and the aluminum bumber weighs exactly 14lbs less than the steel one !!! I am not sure ic the general made aluminum bumpers for the Camaros but it would def be worth checking out.
A guy I know that has a pro-street 3rd gen Camaro said he replaced his power steering gear box with a manual one from an S10. for one if this is a straight forward swap then you would def gain hp from not having to run a power steering pump and also you would reduce more weight from pitching the pump. as far as the gear box goes I am not sure of the weight diff. this is def something I am going to be looking into, possibly tomorrow if I make it to the junkyard. I will keep you guys up to date on this one.
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
do a
I have seen several threads with the s-10 manual steering box idea. I am sure one of them have weighed them...
well I went to the junkyard after work today and one S10 had a manual steering box. it was a major puta getting it off the truck b/c it was sitting on the ground, but with a few choice words and alot of sweat I got it off. I asked one guy on Ebay selling a 3rd gen power steering gear box how much it weighs with the pitman arm on and I specified with no packing and he said it weighed 29 lbs. the manual box off the S10 weighed in at 23lbs with the S10 pitman arm on. so it looks like the box alone will reduce 6 lbs plus whatever the power steering pump, brketry, hoses and belt all come to I don't know yet but I will soon. I am going to clean my new manual box up a bit and paint it black then I will post my new steering weight results.
Engine: SBC
I'm still wondering if the weight of an 82 base firebird is actually under 2900 Lbs, sounds a little light to me.
I dont really have to have heat or AC, just a comfortable interior.
Chris
Chris
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I e-mailed you the pdf file which is the page taken from the gm 82 book. I hope this clears it up for you
it would be tough to hit 3000 lbs and keep creature comfronts....
my car weighs in at exactly 3200 without me in it. it has power steering, heat, all power options. the CM 9" will take some weight off, but it will be hard to get to much lighter and still have a "nice" car to drive
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Re: Whats it take to get an F-body to 2800-2900 Lbs?
Chris
Chris
Also IHI anytime you would like to do wheels I am down. Car is starting to come together quickly. All I need is tires and a radiator.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by o2b18
Isn't a base model a V-6?
from 84 onward, yes.
but in 82 and 83, you could get the 4cyl iron duke motor.
the motor was so gutless that chevy thought it was unsafe in such a heavy car... it could bearly accelerate... im talking mid 20 1/4 mile times..... so they made them light... they're what the alum bumpers came in... they usually didnt have AC... ect...
by the time you add a v8, the "lightweight" basemodel 4banger car weighs the same as a minimal option V8 car anyway.. so that route isnt really that great.
really, to get below 3000lbs, you'll need to totally gut the car. you can do some trick stuff to get you close, but you wont actually go below 3k until you ditch the interior and all creature comforts...
Car: 91 Camaro RS
Engine: L03 chip, airfilter,dual exhaust..m
Transmission: 5-spd
Yes that right, I had forgot about that. I was selling Chevy's back then and we had one as a price leader no a/c and the little black 'doggy ear' mirrors, sport mirrors were an option.
I actully thought they were suprisingly peppy thru first second gear, for a 4 banger with a stick, they ran a lower gear then the V-6 or 8.
I remember using a stop watch on my buddy's dad's mint 62 Impala 283 powerglide on a 1/4 mile we had marked off out side of town, about the same et! Sorry reread post, the Impala ran about 20 sec.
Car: 91 Camaro Vert
Originally posted by MikeC.86Roc
An aftermarket K-frame would be a big saver I bet. That factory one is like an anchor from the Titanic!
Car: 91
Yeah
Mods for being lighter.
Removed antenna
gutted doors (until I get enough cash for fiberglass ones)
lexan side glass
Fiberglass hatch piece
fiberglass hood
tons of bolts
heater core box removed
Flaming river manual steering rack
front and rear bumpers gone
aluminum heads
only thing pullied is the low mount alternator
Tubular control arms and cross member
15 x 3.5 fromt wheels
fuel cell (custom aluminum
removed charcoal filter and everything else
manual willwood master cylinder
removed back seat
removed carpet and sound deadening material (autozone carpet 12 pounds for whole roll)
Stock wheel wells and fram gone
Ford 9 inch with aluminum center section.
Rear willwood disc brakes.
Removed wiper motor and assembly
Lighter tranny than stock soon to be an all aluminum deadenbear.
custom thinner sheetmetal rear hatch area.
4 link back half kit (not so much weight but better strength
coil overs in rear
soon to have lexan glass
gutted steering with with painless switch kit for all accessories
no centerconsole
No wiring other than painless
theres more but those are some good starters
basically anything bolted down
Removed antenna
lexan side glass
fiberglass hood
tons of bolts
aluminum heads
removed back seat
coil overs in rear
no centerconsole
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
one of my friends on the westcoast boards has a completey gutted z28, just a steering column and 3 gauges. T5 and 400sbc no computer all carb, dual exhaust dumps before rear tires. and his raceweight is 3085 lbs. goodluck!oh yea, one drivers seat as well.
with myself weighing in at 165lbs and a full tank of gas oh and its an RS
and still got stuff to take off w00t Joined: Dec 1999
Engine: ls1, LB9
well, a sbc does not weight 500 lbs more than an iron duke
so, a base model is what I would start with then do the little things like sound mat removal (you know all the dumb stuff that adds up in the end)
so, a base model is what I would start with then do the little things like sound mat removal (you know all the dumb stuff that adds up in the end) Thread
88SS6SPEED
Nov 11, 2015 07:05 AM
