Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
View Poll Results: Should i take the ticket or fight it?
Take it.
27.27%
Fight it.
16
72.73%
Voters: 22. You may not vote on this poll
Reckless Driving.
Old Sep 12, 2005 | 04:25 PM
Hexane's Avatar
Car: 87 Camaro
Engine: 2.8 MPFI V6
Reckless Driving.
I live in Wisconsin and on Friday, when i was leaving school, i hit a patch of gravel while turning and it kicked the back end around. When i corrected i over corrected and was faced with hitting a car or a pole. I chose the pole. Since i was in the area of my school, the cops gave me a reckless driving ticket..
Is there anyway i can fight back with Inability to Maintain the Vehicle?
Or should i just butch up and take my punishment, even though i wasn't driving recklessly i got a stroke of bad luck.
Old Sep 12, 2005 | 05:49 PM
mnchevy's Avatar
Car: Chevy
Educate yourself. Did the cop see you hit the pole, how close is near a school. Find out what reckless driving is in Wisconsin. If your going to fight it you better have some facts.
Old Sep 12, 2005 | 07:31 PM
Hexane's Avatar
Car: 87 Camaro
Engine: 2.8 MPFI V6
Thanks for the feedback. I've been doing research since i got home today and i could win and lose it on two facts i found. No, the cop did not see me do it, and my passenger told me he felt i was doing what i could to keep him safe due to the circumstance.
The law says that reckless driving it primarily due to speeding, but may be made an acception due to one who DRIVES without reguard to the safety of those around him.. But! I wasn't driving that way, the only reason i was put into that situation was because the car slid on the gravel.
Also, it was on the road infront of the school.. ><
Old Sep 14, 2005 | 02:30 PM
taturbo's Avatar
Car: 3 3rd Gen F-bodies and 7 others
Engine: 305 CFI, 350 TPI & 3.8 Turbo V-6
Transmission: all automatics (stock)
Fight It, Based on the facts that the state needs to prove their case, you are not guilty of either.
You have a witness to help you with your case, (your passenger)
The state has no witnesses, and that alone could sink their case.
It was an accident, plain and simple, it was not caused by anything that would be considered wreckless driving, at the worst you might tell the judge that you are still a bit inexperienced, due to age and the type of vehicle you are driving (hey, I know it might be tough to admit, but the judge might be more understanding if you at least sound honest) But don't bring that up unless the situation calls for it.
Either way, you should win it. You realy DON'T want a charge like that on your driving record! Guilty = Instant high risk category $$
Old Sep 14, 2005 | 06:31 PM
Tweaked's Avatar
Car: 88 t/a red w/body kit
Engine: 305tpi...355 carbed
u were obviously driven recklessly since you hit somthing... common man its gravel not ice, you really gotta be fukin around to through your car off that hard
Old Sep 14, 2005 | 10:56 PM
davey's Avatar
Car: '95 cutlass supreme, '82 F-150
Engine: 3100, 302
Transmission: auto
yeah it's always worth trying to fight. when i got my wreckless driving(also in wisconsin) i tried half heartedly. i was 17 w/ a camaro and i knew i was being stupid. but now i wish i tried harder. insurance is sky high. try fighting it anyway. given the circumstances, you have a better chance than i did.
Old Sep 15, 2005 | 06:52 PM
Tweaked's Avatar
when i get in **** wit the law i usually getta bars lawer usually run me about 100-150 but it beats having **** on my record. u might just want to call a few free lawers and offer them how ever little you want to pay.
Old Sep 16, 2005 | 02:31 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
You lost control of your vehicle, that is wreckless.
Old Sep 16, 2005 | 03:32 PM
Hexane's Avatar
Car: 87 Camaro
Engine: 2.8 MPFI V6
It was on a single lane road with cars parked on the one side in a distance of not even 30 feet. I would have been able to regain control, if not for the cars along the road.
Old Sep 16, 2005 | 06:53 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
If anything it should be failure to maintain control.
Old Sep 19, 2005 | 03:48 PM
85blackberlinet's Avatar
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
take it
take your ride back up there and make that ticket worth it
Old Sep 21, 2005 | 03:39 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
One option you might be able to use is that you shifted into 2nd while turning causing the tires to break loose because of the gravel. As an inexperienced driver, you overcorrected and chose to not hit a car. Explain to the court that you will be willing to take advanced driving classes thru the professional drivers/racing schools to learn how to better control this type of car.
Was the gravel light or heavy? Do you have posi? These all will help with the situation. Also explain that the car is a V6 and there really is no showing off needed with the car. If the car is not posi, then your screwed. A one wheel wonder should not lose control going around a corner under light acceleration.
Old Sep 21, 2005 | 02:27 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
The point the police will make is right in your statement that the car is a v-6 and he had to be showing excessive driving behavior in order to do what he did in other words this ticket will most likely stick like glue....sorry to hear
but next time you will look at the elements of the area around you and decide how you should take off
Your lucky you were able to hit a pole instead of someone elses car or even worse some one else.....next time be carefull ...
Old Sep 29, 2005 | 12:37 PM
Slowmaro95's Avatar
From: Straight outta the red light district of Highland
Car: 2001 SS
Engine: guess...
Transmission: 4 spd w/OD
Axle/Gears: 3:73 Posi
I gotta say, you musta had a little momentum going to slide on a turn.
I'd fight it simply for the fact the cop didn't see you. There's no way for him to correctly evaluate the conditions if he wasn't there. Plus you had a witness! I had a similar situation happen to me about 4 years back. Except it was a dusting of snow and a pot hole, slid right into a front yard of a house. And I was only going 5 over...
Old Oct 2, 2005 | 03:37 AM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
Get a lawyer. I tried to fight an illegal speed contest in a school zone. I was not drag racing. The cop said I was but I had witnesses that testified for me and the judge says GUILTY!!! I should have got a lawyer.
Old Oct 2, 2005 | 09:51 AM
darrel88's Avatar
my brothers camaro isnt a posi and when we were comin home one time and gettin on the highway, he got on it a tad and it swung out on him a little bit farther than normal and we were facin the ditch in the median and he corrected and got on the brakes and we still ended up sideways in the middle of the highway, luckily no cars were comin
Old Oct 2, 2005 | 08:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, get a lawyer. it will cost you now but, trust me it is worth keeping this off your record.
I had a case in a old 6000 that was very tired and worn out. well long story short a cop heard tires squeeling (this is right off of a main road in town and noon during the week) saw me driving and figured hey it's a kid must be him. gave me a ticket so I went to court and I had took pictures of the intersection and where the cop was ..... nope guilty! I even pointed out how tired the car was and how I would have to be on ice to even turn the tires over they don't care if it is a kid disputing it you are just a kid
Old Oct 2, 2005 | 10:23 PM
Hexane's Avatar
Car: 87 Camaro
Engine: 2.8 MPFI V6
Thanks guys. Depending on how much the ticket is when i get it and what the court says will make my decision.
blackz281le
Jan 11, 2016 07:51 AM
lanceflame44
Sep 25, 2015 12:28 PM
cking99
Sep 22, 2015 11:33 AM
BWilcox
Sep 20, 2015 12:19 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
