Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
EXTREME HELP NEEDED TRANS IS PISSIN ME OFF!!
Old Sep 25, 2006 | 11:58 AM
1_BaD_86's Avatar
Car: 1985 Chevrolet Camaro Z28 IROC Z
Engine: Been too lazy to check....
Transmission: 5 Spd. Manual
Ok this is the story, I was goin to work when my throwout bearing went out on me, so i dropped the trans, threw in a new bearing, (and a new clutch while i was at it), threw the trans back on, adjusted the big red screw that regulates the shifter throw, and was up and running again. the very same day my slave cylinder went out, so i threw in a new one, bled the air out, and got that workin too, but now my car doesnt want to shift into gear. so i took the trans off again, checked the throwout bearing, looked at the fork, everything seems to be in order, so i threw the trans back,readjusted the big red screw on the trans, but it still doesnt want to shift into gear. Please help this is driving me nuts ive dropped the trans like four times already and i cant figure out why its not shifting into gear. odd thing about it is that when the car is off it DOES shift into gear but when i start it up it wont get into ANY GEAR. the clutch disk and pressure plate were aligned when installed, the clutch disk is not on backwards, the new slave cylinder appears to be doing its job of pushing the fork in. PLEASE HELP!!! It would be greatly apreciated.
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Exxon Limited
Aug 9, 2015 08:13 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
