horsepower question
horsepower question
need an estimate on how much horsepower would a 1986 trans am have with a completely rebuilt 307 small block chevy,bored .30 over-with rocker rollers,over sized cam and lifters,eldelbrock high rise intake,850cfc eldelbrock thunder series carburetor w/2inch high rise plate,new true dual exhaust
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
250hp maybe at the engine
PS an 850 carb is great for a 383 stroker or larger, a 650 would be great for that motor.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Is this a 305 bored?which intake?the carb is too big, what are the cam specs?These are the things we need to know to give a ROUGH IDEA.
no the people im getting the car from took the motor from a 1970 chevelle and rebuilt it,not sure on the cam specs. the guy just told me it has an over sized cam and lifters, every thing in the motor is high performance from jegs and summit
Car: 1984 Z28
307 came out of oldsmobiles, some chevies etc i believe in the 70s& 80s. I also doubt you need a 2" spacer under the carb either. Hooker 1 3/4" header on this motor as well? That's a bit overkill as well, but that carb and headers would work great on a much larger combo. Also i'd get a 650 double pumper over another edelbrock carb any day of the week.
Car: 1984 Z28
i do not believe that a 307 motor would put down 358 horsepower at the rear wheels ever N/A.
