Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Gears Install in Michigan
Old Jun 13, 2007 | 04:04 PM
HP junkie's Avatar
Car: 91 Z28
Engine: l98 5.7 TPI
Transmission: 700R4,2600TCI stall,Trans Go
Axle/Gears: 3:73
Hi
Anyone know a shop that install gears in MI? Also how much does labor usually run? Doesnt have to be a shop if someone is for hire.
Old Jun 19, 2007 | 11:50 PM
Kandied91z's Avatar
Re: Gears Install in Michigan
www.motownmuscle.com
search for the name scott koresky.. not sure if i have the spelling exactly correct. does alot for the local guys, use to work for a major gear company.
Old Jul 9, 2007 | 06:50 AM
oldman305's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI, 93 LT1 cam, 081 hds, hdrs.
Transmission: Built - 700R4
Axle/Gears: 3.27 gears from '87 TA w/rear disc
I don't know if you're still looking, but the Ring & Pinion shop on Groesbeck in Clinton Township will handle your gear change. They gave me a price for a set of 373's w/posi for $800 in a 10 bolt, and $600 for gears only in a 9 bolt.
Old Jul 11, 2007 | 03:44 PM
Kandied91z's Avatar
i paid half that with scott.. check it out. you won't be disappointed. $800 for just gears is too much.
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
camaro11j
Sep 19, 2018 08:49 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
