Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Back in a third gen...
Old Oct 7, 2007 | 01:55 AM
1_BaD_86's Avatar
Car: 1985 Chevrolet Camaro Z28 IROC Z
Engine: Been too lazy to check....
Transmission: 5 Spd. Manual
hello everyone its been awhile since ive been here well now that im back im here to stay Bought an 85 Iroc with a 5 spd and im lovin it. This is my third 3rd gen (Other 2 was an 85 sport coupe and an 86 z28). Heres a couple of pics:
Attached Thumbnails Back in a third gen...-iroc2.jpg   Back in a third gen...-interior.jpg   Back in a third gen...-iroc3.jpg
Old Oct 9, 2007 | 10:23 PM
cam383's Avatar
Car: 89 and 91 Camaro RS
Engine: 350ci TPI and 305ci TBI
Axle/Gears: 2.73 One-wheel wonder
Re: Back in a third gen...
Congrats on the purchase. Great to see another back into a thirdgen
Old Oct 10, 2007 | 07:04 AM
Pontiackid's Avatar
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
looks like a nice clean car. nice purchase. i always loved red irocs.
Old Oct 10, 2007 | 08:39 AM
dirtymeat80's Avatar
Car: 87 Trans AM GTA
Engine: V8 350 - Stock
Transmission: 4sp AT - Stock
Axle/Gears: Stock
looks very nice, good luck with it
Old Oct 10, 2007 | 03:01 PM
1_BaD_86's Avatar
thanx everyone. i was wondering how difficult is it to turn it into tpi? runin tbi right now.
Old Oct 10, 2007 | 07:47 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Pretty easy, just drop your Iroc off in my driveway and drive away in mine. Then you will have TPI. J/k But that is a really good lookin Iroc and I really wish mine was a 5-speed.
Old Oct 11, 2007 | 03:03 PM
1_BaD_86's Avatar
sounds like a plan haha
Old Oct 11, 2007 | 03:20 PM
cam383's Avatar
DON'T DO IT!!!! lol j/k It's easy and at the same time can be a nightmare. It all depends on how you go about it. There are alot of articles on this sit about swapping to TPI that are very helpful. Pre Planning is the key!!!
I picked up a 89 RS Roller project that was originally a TBI and I am in the process of dropping in a 350 TPI motor in See Here
If you do a TPI swap make sure that ALL the parts you need come from the same donor car i.e. The TPI setup, computer, chip, harness. One of the pains is that you'll have to swap the fuel pump to a high pressure/high volume pump. TBI pumps put out about 10psi and the TPI needs 35-40psi. Plan on half a day to a day doing this...pump is in the tank. If your going to upgrade exhaust this is the time to do it because you can just cut the old off out of the way and not worry about it.
You also have to switch little things like throttle cable and stuff.
If you have the time, a warm place to work on it over winter,all the tools with a little bit of patience added in, then its not as bad as you think to do the swap. If you get all the parts in advance and have time it shouldn't take more than a few days or a week to get done.
Old Oct 11, 2007 | 03:40 PM
1_BaD_86's Avatar
Thanx for the info. Kinda hard to find a donor car in chicago though. Scrapyards in chicago are crap.
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
