Iowans listen up!
Iowans listen up!
IOWANS! I NEED YOUR HELP!! I LIVE IN NEVADA (50201) AND NEED NEAR BY OWNERS THAT KNOW HOW TO FIX A FUEL PUMP ISSUE!!!!!!
Things i done
1) checked fuses
2) took hose off and turned key. nothing came out
3) added gas and still nothing
4) let car sit in nutral for 30 minutes with key on
HELP!
Things i done
1) checked fuses
HELP!
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
Re: Iowans listen up!
Maybe fuel pump needs replaced??? I live in Ames and I replaced the fuel pump on my 94 twice... I used the access panel though, had to cut the sheet metal above the gas tank. Some people say not too but it is not a structural part so whatever. So idk if it really is the pump but if it is it is a pretty easy fix. When I did mine I went with an aftermarket Walbro like everyone said and it went bad so I bought an ACdelco and it ran better than my Walbro ever did. btw I now have an 89 camaro.
Well I don't remember if you have fuel injected or carb, but when I had my 94 the pump would work sometimes and then it would just die on me. I believe pumps can go on and off before they completely stop but not 100% for sure. Anyways if it does run again you should check the fuel pressure while driving and idle. It's prob. easier on the fuel injected since it has to run a much higher pressure and then you can really tell if it is off. On the carb the psi is so low it may not be easily detected. I guess unless you could check the pressure before the regulator?
redbird_400
Car Audio
Nov 13, 2001 01:31 AM
