Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
I need serious help, frustrated
Old Jul 30, 2009 | 11:39 AM
knightrider64's Avatar
From: Three Rivers, Michigan. I grew up here and decide to come back here after being in the Army 7 years.
Car: Black 89 GTA Trans Am
Engine: 350 V-8
Transmission: what ever the factory put in it
Axle/Gears: not sure yet
I have the black 89 GTA Trans Am and when i first start it, it normally starts up. It runs rough a little bit. If it's shut off then try to restart, it wont start, so i shoot ether in it and it fires right up and starts running again. come to a stop sign and it feathers itself down and stalls. Fuel pressure regulator is new, fuel pressure is at 39 psi, new cap and rotor, new ignition module, wires, plugs. oxy censor says running lean. put a new Mass Air Flow on, didnt help at all. I was told that 6 of 8 injectors have high resistance, but it could be the computer also. I'm tired of putting money in it that i dont have and its driving me nuts. I need some answers please, .
I was told that i cannot have true dual exhaust since there is only 1 Oxy sensor. Is this true?
The injectors look like they are stock.
Old Jul 30, 2009 | 12:34 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: I need serious help, frustrated
The resistance should be between 11ish to 15ish, if it is in the single digits that injector should be replaced. Are they the stock injectors or aftermarket??
Old Jul 31, 2009 | 06:30 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
I notice you didn't list dist cap and rotor....
Old Aug 1, 2009 | 07:56 AM
Engine: 350 V-8
i didn't get the spec list from the dealer but i did see it and only 2 injectors were in the 15 and 16 range. a few of them were in the 11's and down to 3.4. thanks for your help.
Old Aug 1, 2009 | 08:02 AM
Engine: 350 V-8
Yes, they said that the cap was arcing, so i put a new cap and rotor on it. the odd thing is its been on there for 6 years with very low mileage and was put on just before i bought it 6 years ago. I think the garage was guessing like i was. i was told not to buy injectors at Autozone, they are $50 there. Where should i buy them then? Thanks for your reply pearl. Nice car
Old Aug 2, 2009 | 06:00 AM
Car: 89 T/A
Engine: LB9
Try Jon at http://fuelinjectorconnection.com for your injectors, they will fix you up with some nice Bosch III's at a reasonable price.
gta892000
Aug 11, 2019 11:16 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
